Camber Adjustment (repair bolt) r170 - Mercedes Benz SLK Forum
#1 Old 11-26-2018
GaryLaird's Avatar
Vehicle: 2010 SLK350 r171
Quoted: 111 Post(s)
Have removed the lower control arm and the original bolts. I see in the Merc WIS that they talk about a 'repair bolt'! As I understand it this 'repair' bolt allows you to adjust the wheel camber. So am I right to assume that the car, from the factory has no camber adjustment as the original bolt/washer arrangement is all concentric? The requirement for a repair bolt is only IF your camber is out of whack?
My question therefore is, can I just re-use the original bolt based on the fact that my tire wear is very even and car has 80K miles. I had assumed having rebuilt the suspension that I would need to have a full wheel alignment done but maybe this is not the case?
Original Bolts
IMG_20181126_173541739 by Gary Laird, on Flickr
Repair Bolts
Repair Bolt Camber by Gary Laird, on Flickr
GaryLaird is offline
Add Always Live USB to R170 SLK in glove box Waiheke SLK R170 class DIY 4 09-15-2017 06:10 PM
Replacing Crankshaft Position Sensor Dean-o SLK R170 class DIY 1 07-17-2017 01:37 AM
Replacing the Springs (Coil Springs) Installing Lowering Springs SLK R170 (SLK320) slk320md SLK R170 class DIY 0 07-01-2016 10:52 AM
R171 17" wheels on a R170 Lug Bolt difference. houllahan Tires, Wheels, Brakes & Suspension 4 07-25-2015 09:54 AM
Additional information SLK320 R170 headlight removal – 2001 Anthony in Australia SLK R170 General Discussion 8 05-05-2015 03:19 PM
