What pressure should I use for winter tires? - Mercedes Benz SLK Forum
#1 Old 10-25-2018
Founding member #7
mtiede's Avatar
Vehicle: 2017 SLC 300R
Quoted: 25 Post(s)
I usually set the tires to the recommended pressure. But now I have winter wheels and tires on. These are the SAME size for front and rear. The dealer just pumped them all up to 37. Shouldn't those fronts still be lower pressure? Or should they all be the same since they are all the same size?
mtiede is offline
#2 Old 10-25-2018
LeonardoDaBenz's Avatar
Quoted: 1011 Post(s)
Tirerack suggests 3-5 PSI increase.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#3 Old 10-25-2018
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 190 Post(s)
Tire pressure is critical when at highway or higher speeds for long periods of time (higher speed needs higher pressure to avoid overheating and tire failure)(also higher loads, particularly for smaller tires).
Higher pressure means reduced contact patch which equals reduced grip.
Which brings us to your winter tires, winter tires are sensible to overheating on non winter weather so if for some reason you are getting on the highway and its warm you need to pump them up to the higher end of the range.
For normal winter conditions you do not need to worry about it too much, lowering the front will increase grip but since you are not racing around it would be hardly noticeable.
VII7 is offline
#4 Old 10-25-2018
Founding member #7
mtiede's Avatar
Quoted: 25 Post(s)
Thanks for both replies. Both make sense. However, I guess what I was trying to find out was if the SIZE difference of the front and rear tires was what was dictating the difference in recommended pressures.
Any opinions on that?
mtiede is offline
#5 Old 10-25-2018
Other Toys: CLS63
Quoted: 190 Post(s)
Yes and no, in general smaller tires need higher pressures.
However the difference that you see in the gas door between front and back is actually driven mostly by:
1. Weight distribution
2. Power distribution
3. Desired balance (understeer)
VII7 is offline
#6 Old 10-25-2018
Founding member #7
mtiede's Avatar
Quoted: 25 Post(s)
Ok, sounds like the benz shop didn't do the right thing then.
mtiede is offline
Pirelli offering colored tires, tires that talk to an app jbanks15 Off Topic 3 03-15-2017 12:31 PM
tire's air pressure NMBruce SLK R172 General Discussion 9 06-30-2015 11:45 AM
And they let people that ask questions like this drive... jbanks15 Off Topic 1 12-20-2014 11:06 AM
Tire Basics for Dummies carid CARiD.com 0 09-05-2013 09:01 AM
New Tire surprise, recommendations ASAP Brian_74 Tires, Wheels, Brakes & Suspension 54 09-28-2009 12:09 AM
