Tyre recommendation - Mercedes Benz SLK Forum
 6Likes
  • 1 Post By Avel Du
  • 1 Post By 55russamg
  • 1 Post By frogfoot
  • 1 Post By Windinmyhair
  • 2 Post By Robbie4T
#1 Old 10-13-2018
simont's Avatar
Vehicle: R171 SLK350 08 Facelift
Other Toys: CLA 250 Sport 4Matic SB, Cooper S Sidewalk Conv, Ducati Monster 1100 Evo, BMW R32
Quoted: 30 Post(s)
Tyre recommendation
Applied some throttle exiting from a junction to join the main road yesterday and experienced some wheel spin in the dry which was unexpected, a quick look at rear tyre revealed that the driver side one is close to legal limit. As all 4 corners are of different (budget) makes, plan to change the rears now and the fronts when the time comes.
Any make/model recommendations on tyres for the 350? I favour Michelin PS4/5 but they are close to £300 for a set of rears 245/35/18. Are there any alternatives which offers similar performance/better value for money at a lower price point?
I heard good things about the Goodyear NCT Eagle F1 Asymmetrical but they are only £30 cheaper per tyre. Usually go with Blackcircles fully fitted as they seem to be price competitive.
simont is offline
#2 Old 10-13-2018
Moderator/RoTMorganiser
Quoted: 2198 Post(s)
@frogfoot uses contis I believe. He seems pleased with them.
@jbanks15 used to have a 350, although US and a while back, he is a believer in value for money.
We are trying Bridgestone on our 350.
Comparing with the PS4s on my 55 I'd say better wear, less grip (especially in the wet).
There's better grip than PS4s out there, but higher cost.
Tyres on the drive offers discount for 2 or more, but our local one twice turned up with the wrong tyre!
55russamg likes this.
Avel Du is online now
#3 Old 10-13-2018
55russamg's Avatar
Quoted: 660 Post(s)
Question
You can probably spin up any make of tyre when pulling away.
Generally the main brands are all good, I have Continental and maybe they don't grip as well as the Pirelli I had on previously but it's marginal and I only noticed the difference on a track.
Maybe you may want to try a slightly bigger rear tyre? A bit more rubber should help
You will need to go up in width and down in side wall ratio. Someone will come along and advise I am sure.
If you can afford it I would change all 4 if you have cheap tyres now.
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is offline
#4 Old 10-13-2018
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
Mine had Michelin on when I bought the car at three years old , the guys I work with recommended conti sport contact MO.
Never had anything else on the car since , gone through conti sp3 sp4 and on third set of sp5 now.
Fantastic summer and wet weather tyre and it does get used in ice and snow now and again but you will find the little yellow light flashing on regular in those conditions if pushing to hard.
Mine runs 17 inch rims , rear tyres around £115 fitted and fronts £95 fitted
The rear tyres will do two summers before replacement and the fronts dont seem to where out ! I change them as a pair on age once to every second set of rear
frogfoot is offline
#5 Old 10-13-2018
Robbie4T's Avatar
Vehicle: SLK55 AMG 2008,
Other Toys: SuzukiGt200X5(1979),YamahaFZ6(2009), Honda Firestorm(2000),
Quoted: 81 Post(s)
I have had 3 conti-sport 5's and 1 Pirelli P zero on the car since i bought it abut 10,000 miles ago. they had about 6mm tread depth originally and now have about 3-4. Rears seem to wear quicker than the fronts. I like the Conti's, they grip fine in the dry and i don't push hard in the wet. Also the sidewall protrudes 3mm or so outboard from the rim which is great, as any accidental kerbing tends to be taken by the tyre, not the wheel rim. They do tend to pick up small stones in the grooves and the Pirelli seems to do this less as it has wider grooves, so that's a downside for the Conti's. The other consideration is how noisy they are. If you go on some tyre site like -
https://www.atseuromaster.co.uk/cons...5248,100054956
they give comparisons of fuel consumption, wet grip and noise which may further help you to choose. Ultimate grip in the wet or dry doesn't really concern me. I've had no trouble in the dry but if you go fast enough on roundabouts/bends, the back end does come out a bit ! And in the wet just take it easy !!! Riding bikes for 40 years gives you a healthy sense of self preservation that i use in the car as well, especially in the wet.
SLK55
(2008) with -
performance pack,
most factory options,
NTG 2.5 comand upgrade
+ boot cargo nets
Go Fast ! Stop Faster ! Love those 6 Pots
Robbie4T is offline
#6 Old 10-13-2018
Mugs's Avatar
Vehicle: 2012 SLK55 AMG, Calcite white with Bengal red leather, AMG performance pack.
Other Toys: BMW X3 3.0i Msport & Subaru Impreza wrx 1994 (auto)
Quoted: 112 Post(s)
I usually have Michelin pilot sport 4 but they were not available at the time I bought my new tyres so I went for Goodyear eagle f1.
They seem to give as much grip as the PS4 in the wet and dry so I am happy with them but I’m not sure how many miles I will get out of them on my 350, time will tell.
I have some 18” f1 rears that we’re on the wheels when I bought them. They seller told me they have only done 1k miles and to be honest they look like new so I well believe it.
I will be selling soon them if you’re interested? They are 245 35 18, let me know.
Mugs is offline
#7 Old 10-20-2018
simont's Avatar
Quoted: 30 Post(s)
Thanks Mugs for offering the solution - the car now features rubber it deserves!
simont is offline
#8 Old 10-20-2018
Mugs's Avatar
Quoted: 112 Post(s)
Glad I could help.
SLK55 AMG - ‘Valkyrie’
Mugs is offline
#9 Old 10-21-2018
Robbie4T's Avatar
Quoted: 81 Post(s)
Not planning to buy new tyres until next year, but i am keen to get some "quiet" tyres and i have one pirelli p zero fitted at the front that i have had no trouble with. Looking on the ATS Euromaster website there seems to be 2 similar pzero tyres. One 72Db, one 68Db ! Anyone have any ideas or experience as to why the big difference in noise ?
SLK55
(2008) with -
performance pack,
+ boot cargo nets
Robbie4T is offline
#10 Old 10-21-2018
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 328 Post(s)
Well with the first one marked XLMO TL, the MO stands for 'Mercedes original' whilst the second one isn't as no MO.
Both are extra load and tubeless so maybe the MO version is a very slightly different compound or has stiffer walls.
All else being equal, I wouldn't be inclined to pay the extra for the privilege of having MO moulded in and the extra 4Db, bearing in mind that the Db scale is exponential.
Robbie4T likes this.
Windinmyhair is offline
The Following User Says Thank You to Windinmyhair For This Useful Post:
#11 Old 10-21-2018
Robbie4T's Avatar
Quoted: 81 Post(s)
Yes, i was thinking something similar. But, I have had trouble in the past with Michelin bike tyres with soft sidewalls giving me a tankslapper or weave at high speed. strangely enough, it comes from the rear tyre. Wouldn't want this on the car ! Although i could give Pirelli technical a ring, i suppose and ask them.
SLK55
(2008) with -
performance pack,
+ boot cargo nets
Robbie4T is offline
#12 Old 10-23-2018
Robbie4T's Avatar
Quoted: 81 Post(s)
Got a reply from Pirelli technical yesterday, who i'd emailed the day before. Hatty said this -
Good Morning Robert,
Thank you for your email,
I have searched our system for size 225/40ZR18 92Y and can confirm you are correct that their are two fitments we can recommend for your Mercedes. The first one would be the P ZERO which is homologated and approved for the Mercedes SLK, Therefore the tyres are tailor made for the vehicle, chassis and the requirements of the vehicle manufacturer. This is the older P ZERO pattern.
The second option would be the P-ZERO which is not homologated for any vehicle and is a universal fitment which means this product can be fitted to any vehicle that has the size. This is the new P-ZERO pattern.
There are a variation of differences within the compounds used for the P ZERO (MO) and the P-ZERO. They also have different tread patterns.
Kind Regards,
Hatty
So there doesn't seem any reason for not going with the new quieter tyres. I now now what i will definitely be buying !!
SLK55
(2008) with -
performance pack,
+ boot cargo nets
Robbie4T is offline
Skinny tyre for a R172 SLK55 AMG Cookiecrew SLK R172 General Discussion 10 10-20-2018 07:57 PM
space saver wheel and tire adrose Tires, Wheels, Brakes & Suspension 45 12-30-2017 09:14 AM
R171 18 inch tyre recommendation? Seyley Tires, Wheels, Brakes & Suspension 12 10-13-2017 03:19 AM
Mercedes-Benz patents water-cooled tyre system Berliner Heckflosse Off Topic 2 07-03-2016 06:08 AM
Tyre Pressure Paul10000 SLK R171 General Discussion 5 09-21-2010 11:56 AM
