R171 Wheel Restoration (US) - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By Terminal
  • 2 Post By Trev5
#1 Old 09-22-2018
sskenned58's Avatar
Vehicle: 2005 SLK 350, 723U Cubanite Silver Metallic over 844A Brown Leather.
Other Toys: 1967 Mustang coupe (showgirl) & 1968 Datsun 2000 roadster (restoring), 2015 Nissan Rogue SL (Daily)
Quoted: 9 Post(s)
Question R171 Wheel Restoration (US)
I have a question/problem. I want to restore the wheels on my r171 (2005 slk 350). Has some road rash and the clearcoat is peeling off in places. Not sure where to ask this question. Thoughts?
sskenned58 is offline
#2 Old 09-22-2018
Moderator/RoTMorganiser
Quoted: 2198 Post(s)
Do you mean that you want to do this yourself, or have it done by professionals?
Avel Du is online now
#3 Old 09-23-2018
sskenned58's Avatar
Quoted: 9 Post(s)
Smile It depends...
I would like to do them myself, depending on whether the process is doable for me. If it turns out to be beyond my ability I'll have someone else redo them.
First I would like to know whether these are alloy, steel or aluminum wheels?
Then I'd like to know if anyone here has restored their own and what was involved?
Thanks.
#4 Old 09-23-2018
55russamg's Avatar
Quoted: 660 Post(s)
Cool
I can only assume they will be Aluminium (Alloy, short for Aluminium) if they are magnetic they will be steel.
You will need to rub them down to remove any raised bits and re spray.
Unless you are prepared to remove your wheels and clean them and rub down all over so as to take a new coat of paint that will last I would get them done by a professional. You may be able to find a mobile wheel refurbishment company but it may only last a year or so?
The more you pay the better it should be.....m
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is offline
#5 Old 09-23-2018
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 531 Post(s)
Huh? Alloy means a combination of metals (or other elements), and is derived from the Latin alligare, to ‘bind’.
With respect to aluminium, the most common elements used are copper, magnesium, manganese, silicon, tin and zinc, to produce an alloy with specific characteristics.
55russamg likes this.
Terminal is offline
#6 Old 09-23-2018
55russamg's Avatar
Quoted: 660 Post(s)
Lightbulb
You are correct but people use the term Alloy to describe Aluminium style wheels as a general term without being Engineers or Scientists. Mag wheels was also used back in the 70's but people didn't have Magnesium wheels.
The Post was about how to repair the wheels on the owners car.
Cheers Russ
SmartTop
#7 Old 09-23-2018
Trev5's Avatar
Quoted: 303 Post(s)
I had a rough granite curb "jump out" on Me while doing a few mph....
A local mobile Alloy wheel repair person quoted ~Ł90 to repair it, with out taking the tyre off...
But ended up taking the single wheel (lucky I have a spare R171 wheel!) to "My Alloys" in Basingstoke who did a complete strip & re-sprayed it for Ł72.
They said that the lacquer was quite thick on My R171 "BBS" alloy wheels, so the actual damage to alloy wheel was minimal, which You can see in the before & after picture:
But back to You question, here is a SLKworld.com member who repaired His own wheel(s):
>> Details: https://www.slkworld.com/slk-r171-ge...-pictures.html
55russamg and sskenned58 like this.
Trev5 is online now
The Following User Says Thank You to Trev5 For This Useful Post:
#8 Old 09-23-2018
Vehicle: 05 55
Quoted: 531 Post(s)
Actually, they did. However pure aluminium or pure magnesium were found to have too many limitations, so alloys were developed. Aluminium, with primarily magnesium added were termed 'Mag alloys'.
Here, knock yerself out:
https://uacj-automobile.com/types_and_applications.html
https://en.wikipedia.org/wiki/Alloy_wheel
ps33fount likes this.
Terminal is offline
Steering wheel black leather & vavona wood a1714600203 mercedes slk r171 05-08 DvintSLK SLK Parts For Sale 0 02-29-2016 01:30 PM
R171 slk280 steering wheel button clusters DaleLucas SLK Parts Wanted 11 07-18-2014 02:11 PM
SLK200K R171 16" wheel fitting problems Sonic SLK R171 General Discussion 6 11-11-2012 06:37 PM
Will the R172 Steering Wheel work on R171? MarkR171 AMGs 0 09-20-2012 03:50 PM
looking for slk55 r171 steering wheel (030)and instument cluster jippo Where to get R171 SLK Items 1 11-21-2011 11:22 AM
