Front wheel bearing (hubs) - Mercedes Benz SLK Forum
#1 Old 08-27-2018
Tullamoredew's Avatar
Vehicle: SLK r171 2005 200 kompressor
So my both front bearings are bad, they have too much play and im planning to change them. Did anyone here change them?
Shall i replace hubs aswell? Can be marked area on photo problematic?
Tullamoredew is offline
#2 Old 08-27-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 895 Post(s)
Did you try adjusting them first?
If not yes is not a bad job I change mine a few weeks ago.
File Type: jpg JPEG_20180703_154855_560716082480781529.jpg (60.8 KB, 7 views)
i860 is offline
#3 Old 08-27-2018
G0RSQ's Avatar
Quoted: 151 Post(s)
Worn or damaged wheel bearings are not (or better to say "should not") be adjustable. Adjustment is just for setting up new bearings.
Just because you can, does not mean you should!
If they are worn, then they are damaged, and need replacing.
How many times have they been "adjusted" already??
The surface treatment of modern bearing components is very shallow (tens of microns in many cases), and once worn away they will deterorate rapidly, or catostophicaly .
G0RSQ is offline
#4 Old 08-28-2018
They cant be adjusted anymore...
I just dont know if i should buy bearing kit (skf) or whole hub with bearings installed (swag).
Is damage on hubs (photo in first post) bad?
#5 Old 08-28-2018
Delucas's Avatar
Quoted: 1132 Post(s)
If they have very slight play they can be tweaked / adjusted up .
Its a common thing for merc front bearings to have a very slight / play in movement after even if the car is a few years old .
Common practise is to adjust the the free movement up .
But all depends on a few factors is the bearing feel rough / is making a noise / mileage / loss of bearing grease / missing or punctured hub cap ?
Delucas is online now
#6 Old 08-28-2018
Quoted: 205 Post(s)
Changing the front bearings is pretty easy. If you wrench on cars at all you will be fine. It is just like most other RWD cars and took me 3-4 hours to do both and I wasn't rushing.
jet_fl is online now
Wheel bearing, please help! Melania Tires, Wheels, Brakes & Suspension 9 08-24-2018 04:25 PM
2001 Rear Wheel Bearing sage toolguy SLK R170 General Discussion 1 04-21-2014 10:35 PM
Front wheel hub torque? tcrankwa SLK R170 General Discussion 9 01-17-2012 05:56 AM
FS: H&R 10mm Front Wheel Spacers glennslk350 SLK Parts For Sale 2 10-30-2011 08:01 PM
