Wheel bearing, please help! - Mercedes Benz SLK Forum
 10Likes
  • 3 Post By jet_fl
  • 1 Post By jbanks15
  • 2 Post By i860
  • 2 Post By Delucas
  • 1 Post By Melania
#1 Old 08-24-2018
Vehicle: SLK 250 2014
Quoted: 196 Post(s)
I had my wheel alignment done at Tireplus over a week ago, after the alignment I started hearing 'wob wob wob' noise from the rear wheels so I took it back and they did some adjustment now the noise aren't as loud but it's still there. There was no noise prior to alignment. I was told because my alignment was so off, there was some wear on the tires so now that the alignment are where they should be some worn spots on the tires are making the noise.
I took the car to MB indy shop today and they said the noise is caused by the rear wheel bearing on the left side. Would take about 6 hours and quoted me $900 for just one wheel bearing. To me that sounds very excessive. Does this sound right? I read that wheel bearing on the SLK can be adjusted if they are loose.
Melania is offline
#2 Old 08-24-2018
Quoted: 205 Post(s)
Shockingly it sounds like Tiresplus is correct. A wheel bearing is going to be a pretty consistent grinding noise. If it is reverberating like the wob, wob you talked about, then it sounds like tire noise. If you have staggered tires you are pretty stuck. If you have the same size all around, then you could try rotating them.
jbanks15, Idiot101 and Melania like this.
jet_fl is offline
#3 Old 08-24-2018
Quoted: 6432 Post(s)
you should be able to see if any tire is 'out of shape', bulging, worn, wearing uneven
If your vehicle is making a wobbling noise when you drive, there could be a few possible causes. In an effort to narrow down what is making the noise, be sure to try and pin-point when the noise happens and exactly what you are doing. Then, run through these possible issues, or bring your vehicle in your your local Maryland auto mechanic and tell them about the noise and let them fix it.
Wobbling when Braking
A wobbling noise or feeling when you hit the brakes is a fairly common issue. Usually, it means your rotors are warped for any number of reasons. This is also something which can be felt in the steering wheel when you break. The fix here is to have the rotors checked and possibly made straight again (turned down) by a certified mechanic. Sometimes, rotors are too thin to be turned down and must be replaced.
Wobbles at a Certain Speed—Inconsistent
Does the wobbling occur when you get up to a certain speed, but not consistently? Consistency is key here, if the problem happens every time, then move onto the next cause. If the wobbling occurs inconsistently, then it could be as a result of your vehicle’s suspension. It’s a good idea to bring your vehicle in to a certified suspension repair shop in Maryland and have them assess the issue.
Wobbles at a Certain Speed—Every Time
Above we talked about inconsistent wobbling at certain speeds, here we’re talking about wobbling which happens at a certain speed, quite consistently. These types of wobbles are attributed to tires nearly every time. Now there are a few reason your tire is making your vehicle wobble, such as flat spots, cupping, separation, or an unbalanced tire. Remember the speed you’re having the issue, and get your car into a Maryland tire repair center immediately as the problem could prove dangerous.
Wobbling Under Heavy Loads
When we say heavy loads, we mean giving it a lot of gas to accelerate fast, towing something heavy, or when going up a steep hill. If you notice your vehicle wobbles or makes a wobbling noise in these conditions it could be some worn motor mounts. This is something your local Maryland auto mechanic could easily diagnose and repair, so if you feel a wobble in your vehicle, be sure to get it in to the shop right away.
Melania likes this.
#4 Old 08-24-2018
Quoted: 196 Post(s)
The tires are staggered and not the same size so I cannot rotate them. Tires are pretty new. I guess I'll continue driving til I need new tires or get new ones to take care of the noise.
I hear the noise right about 30 to 50mph. 60 and beyond there's no noise.
Melania is offline
#5 Old 08-24-2018
just cause a tire or tires are new does not mean they are not defective
That would drive me crazy
go to another tire place.
let them throw their opinion into the mix for free
#6 Old 08-24-2018
Quoted: 196 Post(s)
I want to clarify that the vehicle does not wobble. There's just some tire noise. I was informed by Tireplus and MB indy shop that there are some worn spots on the rear tires.
I don't live in Maryland
Melania is offline
#7 Old 08-24-2018
I know no wobble. I was talking worn spots as 2nd video shows
Get new rear tires. bad tires cause other issues and you already paid for the 4 wheel alignment
Melania likes this.
#8 Old 08-24-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 893 Post(s)
Looks like a fairly job to change the rear bearing plus you need some special tools...
jbanks15 and Melania like this.
i860 is offline
#9 Old 08-24-2018
Delucas's Avatar
Quoted: 1132 Post(s)
If your tyres are so called going out of shape that can cause a wobble / wheel bearing type noise etc
Simple thing is safely jack up your car and slowly rotate tyre and from certain angles you should see the tyre flactuate as you manually spin the tyre . [ the tyre should not be perfectly round as you spin the tyre it will have worn spots or be oval as such ]
Delucas is offline
#10 Old 08-24-2018
Quoted: 196 Post(s)
I'll have tire shops check tires to verify. I'll get new tires if that's the case.
Melania is offline
Anybody Changed The Front Wheel Bearing? Mealor Tires, Wheels, Brakes & Suspension 2 07-12-2018 02:36 AM
VERY slight front wheel bearing play nimbusgb Tires, Wheels, Brakes & Suspension 15 06-30-2018 03:02 PM
Rear Wheel Bearing Shalesy SLK R170 General Discussion 7 02-28-2018 11:11 AM
Rear Wheel Bearing Replacement halcyon0 SLK R170 General Discussion 3 01-22-2016 10:14 PM
wheel bearing rogermursick Tires, Wheels, Brakes & Suspension 5 04-01-2012 07:18 PM
