RESOLVED - how to change out tie rod ends (vibration) - Mercedes Benz SLK Forum
  • 1 Post By hugy
#1 Old 08-07-2018
Vehicle: 2006 SLK 55 AMG
I have a small vibration through the steering wheel after I upgraded my wheels to 19 inch.
I have had the wheels balanced twice and they seem correct.
So I thought one of the trackrod ends may be faulty.
I have ordered a pair and would like some help fitting them.
I have had a 4 wheel alignment done 2 years ago with the stock wheels fitted but the vibration started from when I fitted the new wheels.
hugy is offline
#2 Old 08-07-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
What is the width and offset of the wheels ? Rear is not as important as front but the front end geometry centers the contact patch on the intersection of the king pin angle. Deviate and you may feel it in the steering wheel (worst case you get "bump steer").
Padgett is offline
#3 Old 08-07-2018
Hi Padgett
Thanks for the reply.
The wheels are 19x8.5 et30 front and 19x9.5 et32
hugy is offline
#4 Old 08-07-2018
G0RSQ's Avatar
Quoted: 151 Post(s)
Also check wheels are running true!
If the hub gets a knock it can go slightly out of true, causing an inbalance. Spin each wheel and check rim run-out.
I also had an issue on my MG TFwhere the front disks had not centralised correctly (had not tightened up the retaining screw before putting wheel on), and were also running out, resulting in a slight vibration at speed.
Finaly if the trackrod end is worn, you should be able to check it when the front is jacked up and feel for play in the steering on each front wheel.
If you replace track rod ends you still need an alighnment doing, so easiest to just let your local garage do it. Make sure they have a lazer alighnment tool to check it, and give you a printout.
G0RSQ is offline
#5 Old 08-07-2018
I want to install the trackrod ends anyway as if it turns out its not the problem I can rule it out but I hope it is.
the rubber bushings have 60000 miles on them so I would have thought they have become worn enough to cause a vibration through the steering wheel.
hugy is offline
#6 Old 08-08-2018
Delucas's Avatar
Quoted: 1132 Post(s)
1 Simplest thing is to put the standard wheels back on if you still have them ?
2 If vibration is not there then its your alloys or tyres on the rims / wheel balancing issue .
3 If there is no movement in track rod end is not worn or has the slightest movement it is NOT the track rod end !
4 You answered your own question “ I have had a 4 wheel alignment done 2 years ago with the stock wheels fitted but the vibration started from when I fitted the new wheels. “
Delucas is online now
#7 Old 08-20-2018
FIXED
Turns out the alloy wheel spigot rings were faulty(too big).
I just ordered a new set of better quality ones and the vibration is now gone.
Thanks for all the replys guys.
hugy is offline
Common and easy to do DAS 'tweaks' Seanhump DAS/STAR Coding 100 4 Weeks Ago 08:51 AM
DIY Oil Change Coolant/Antifreeze Flush Power Steering Fluid Change Swoley2k SLK R171 Class DIY 5 04-17-2017 05:27 PM
Tesla ends $100 flat fee service promise Berliner Heckflosse Off Topic 0 11-02-2015 03:10 PM
Oil analysis and two year change interval sokoloff SLK R170 General Discussion 23 04-07-2014 09:39 AM
Reckless lane change ends badly jbanks15 Off Topic 4 08-15-2012 05:21 AM
