18" Wheel & Tire sizes - Mercedes Benz SLK Forum
 10Likes
#1 Old 08-06-2018
Vehicle: 2006 SLK 280 - Silver
Quoted: 8 Post(s)
I am new to the SLK World... literally just bought my car yesterday!!
I was hoping someone could help me with wheel/tire sizes.
I would like to get a set of 18" wheels and tires. But this is the first car I have had that has different size tires on the front 205/50-16 and back 225/50-16.
Could someone tell me what the comparable 18" tire sizes would be. As far as I can tell the WHEEL size is the same front to back, 18"x8".
Any advice appreciated.
Corey Malcom is offline
#2 Old 08-06-2018
Quoted: 6431 Post(s)
18 inch front n back but not the same tires size
usually 225 in the front and 245 in the rear
#3 Old 08-06-2018
Lersy's Avatar
Vehicle: Slk 350 AMG Tenorite Grey with Red Leather 2013,X Pipe,Remus Exhaust,AMG front brakes,H&R Springs
Other Toys: Mini Cooper S JCW 280bhp
Quoted: 46 Post(s)
my 18's are 7.5j front and 8.5j rear
Lersy is online now
#4 Old 08-06-2018
Quoted: 8 Post(s)
jabanks15 are you saying 225 40-18 and 245 40-18?
LIL DON SLK likes this.
#5 Old 08-06-2018
usually yes
or 225 40 18 front
and 245 35 18 rear
#6 Old 08-06-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
You want front and rear to be within 3% of the same diameter and do not exceed 26". Mercedes wheels should have the proper offset: 37 front and 30 rear.
Can model sizes at Custom rims, wheel tire packages
225x40x18 is about the same diameter as a 255x35x18 (25.1" vs 25") but the rear offset is critical.
Rod Smith likes this.
Padgett is offline
#7 Old 08-07-2018
Quoted: 205 Post(s)
Padgett nailed it. I have 18x8.5 in the front and 18x9.5 in the rear. I wouldn't go any wider for wheel size. I have 235/40 in the front and 255/35 in the rear.
jet_fl is offline
#8 Old 08-07-2018
Quoted: 8 Post(s)
Ok this is really good information, thank you so much!!!
One more clarification: Related to offset....
I am looking at these wheels I like which have a offset of 40, which means that the rear would stick out an extra 10mm and the front would stick out an extra 3mm, correct?
How much give is there in this offset?
If I understand correctly, I would need to find wheels that come in 2 different configurations/offsets.
What would happen if I put offset 40 all around?
What about 35mm on back and 40mm on front?
Thanks for you're help answering my questions.
#9 Old 08-07-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Have it a bit backwards, as offset goes up, the tire goes in.
Suspension design has always been a bit of an art form, did a lot of modelling when an IBM 370 was my PC, particularly over one gee transients. Must have worked since have a lot of trophies. Pretty sure was the first to model "unladen understeer" and the positive effects of turnin/late braking.
Personally think any profile under a 50 belongs on a racing suspension designed for it. Have no desire on a street car to tell if a cigarette butt in the road was plain or filter.
RLander and Rod Smith like this.
Padgett is offline
#10 Old 08-08-2018
Quoted: 205 Post(s)
The nice thing about buying wheels with too big of offset is that you can put a hubcentric spacer behind it and get the wheel exactly where you want! The fronts should be find and you might need 5mm spacers in the back.
jet_fl is offline
#11 Old 08-08-2018
Quoted: 8 Post(s)
So if I did get these wheels with a 40 offset all around, wouldn't I get a 10mm spacer for the back? And then just leave it as is in the front, which would be 3mm to the inside.
Is there anything "bad" about wheel spacers?
Thanks again all... clearly a newbie when it comes to wheels. It is an art form!
#12 Old 08-08-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
At this point we are really discussing "Kentucky windage" e.g. making a SWAG. If you have the stock wheels on your car now, I'd just try mounting the new ones and see if they rub.
If just a little (e.g. can still turn the wheel but scrapes) then you may just need 3mm spacers. These may be enough and in general the wheel can still register on the hub. 10mm or 1/2" is probably going to need to be machined to maintain the hub and those get expensive.
Or may not be an issue, only one way to tell. Can say that a 19x9x20 is too far out on a R170 for a 255 to clear the lip.
Padgett is offline
#13 Old 08-08-2018
Col
Col's Avatar
Quoted: 713 Post(s)
I always use this website when I’m looking for new wheel and tyre combinations. The illustrations will help you visualise the effects of different rim widths, offsets and tyre sizes. It will also calculate the speedo error based on the new overall diameter.
Www.willtheyfit.com
frogfoot likes this.
I'm not mean... but I am 'roofless' at every opportunity!
- SmartTOP
- Blacked Out Front Grille
- Chrome Bonnet Fins
- Front Camera (Kerb Cam)
- Dash Camera (Hard Wired)
- Gel Resin Number Plates
- Acrylic Wind Deflector
- Ambient Lighting
- Vath X-Pipe and Modified Rear Silencers
- Ispiri ISR6 Alloys Wheels
Col is online now
#14 Old 08-08-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Have to say I am not to sure about that web site, it seems to give wheel sizes only. OTOH this one gives both tire and wheel dimensions.
jet_fl likes this.
Padgett is offline
#15 Old 08-08-2018
Col
Col's Avatar
Quoted: 713 Post(s)
Seriously?! I’m lost for words!
- SmartTOP
- Ambient Lighting
Col is online now
#16 Old 10-14-2018
Quoted: 8 Post(s)
Thanks all for your help and advice.
After obsessing about this forever, I finally landed on these wheels and tires. They came out AWESOME! in my opinion.
Front: 18 x 8.5" with 35 offset & 225 40-18 tires
Rear: 18 x 9.5" with 32 offset & 255 35-18 tires
The overall diameter difference on both were less than 1% difference which was perfect. And my mpg was only affected by about 1.5 which isn't too bad.
See attached before and after.
Thank again!
#17 Old 10-14-2018
Mugs's Avatar
Vehicle: 2012 SLK55 AMG, Calcite white with Bengal red leather, AMG performance pack.
Other Toys: BMW X3 3.0i Msport & Subaru Impreza wrx 1994 (auto)
Quoted: 110 Post(s)
Z
That’s strange as I tried 8.5 x 18 et35 on the front and they hit the suspension strut (although mine is a 2005 350)
The first set I tried were 8 x 18 et40 and they hit the calipers.
Did you fit spacers to the front or did they just bolt straight on?
Mugs is offline
#18 Old 10-15-2018
Quoted: 8 Post(s)
Oh wait...
Sorry about that, I think the 32 offset was on the front. 35 offset on the back.
#19 Old 10-15-2018
Quoted: 8 Post(s)
No spacers. They bolted right on.
I dry fit the wheels to make sure they had the clearance they needed, and both rims came out nice and even front to back. It was perfect.... I couldn't be happier with the fitment. I did report the offset backwards in my post however.
I have been trying to figure out how to edit that post...don't see any way to do that.
#20 Old 10-15-2018
you did not read my welcome post then
you have 9 posts
you need 15 posts to edit and message other members
Best tyre sizes for 18" alloys? Windsor111 General Modifications R171 5 06-06-2012 01:56 PM
Letters and Numbers QSHIP Tires, Wheels, Brakes & Suspension 2 10-30-2010 05:04 AM
will this wheel and tire fit? babyvox_lover SLK R171 General Discussion 1 10-07-2010 10:24 PM
SLK280 Wheel and Tire Upgrade taurusjds Tires, Wheels, Brakes & Suspension 5 04-11-2009 02:33 PM
18" 16 spoke AMG wheels, which wheel bolts? Adamantium General Modifications R171 8 03-26-2009 03:45 PM
