Upsizing of wheels - Mercedes Benz SLK Forum
  • 1 Post By b82012
  • 1 Post By trilby27
#1 Old 07-12-2018
Vehicle: SLK 350 -06
Upsizing of wheels
Hi guys.
I’ve tried to search on forum for some answer but I’m getting different answers all the time.
Background: I found a set of wheels online; that is 19x8.5 with 245/35-19 square setup(all the wheels are the same).
My question: according to some in forum;
-You should keep your wheels at max 26 inches in diameter.
- maximum 5% difference in diameter, recommended 3%.
If not the ABS and cruise control may malfunction.
With 245/35-19, the wheel diameter is 25.7 inches which is under 26 inches.
However. The percentage is relatively.
I’ve currently got:
Front: 225/45-17
Rear: 245/40-17
Which gives higher percentage of difference compared to:
Front: 225/40-18
Rear: 245/35-18
My plan is to use the square setup of 245/35-19 since the tyres are brand new.
And when those tyres are worn, I’m getting:
Front: 225/35-19 or 235/35-19
Rear: 255/30-19 or 255/35-19
Anyone else running the this setup and having issues with ABS and/or cruise control?
Do you think a profile of 30 so to low?
Thanks in advance!
//Phil
Pickupphil is offline
#2 Old 07-13-2018
Quoted: 205 Post(s)
What is the offset of the wheels? I have 18x8.5 and 18x9.5 on mine with 235 and 265. The front is VERY tight, offset needs to be perfect to run a 235 on a 8.5 wheel. Rear still has a little room and I think I can run a 275 no problem. I am running michelin PSS which are known to be wide too.
jet_fl is online now
#3 Old 07-13-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Agree, the offset is the key. Too little and a big tire will rub the front inner wheel well at full lock. Also the tire may contact the upper outer fenderwell lip (171 has more clearance than a 170). 171s have the front issue of a very high caliper that may also be a problem.
Problem is that the correct offset varies with the wheel width and style.
Padgett is offline
#4 Old 07-19-2018
b82012's Avatar
Quoted: 302 Post(s)
Originally Posted by Pickupphil View Post
Hi guys.
Ive tried to search on forum for some answer but Im getting different answers all the time.
Ive currently got:
Front: 225/45-17
Rear: 245/40-17
Front: 225/40-18
Rear: 245/35-18
And when those tyres are worn, Im getting:
Thanks in advance!
//Phil
@phil, first off, I will counsel AGAINST running a square setup... there is a very good reason MB made them staggered.. but if you must, it's your decision....
To your question regarding a "low" 30mm tire, here is my setup...
rims: 19x8 (front), 19x9 (rear)
tires: 235/35/19 (front), 265/30/19 (rear)
Drives like a dream
Chippyslk350 likes this.
Omo
b82012 is online now
#5 Old 07-19-2018
trilby27's Avatar
Vehicle: 2006 SLK350, standard (at the moment). Black with white interior
Upsizing of wheels
@phil. Im also running the 235/35 19s on my SLK350, and consider these at the limit of narrow. Ride is firm and right, but I can feel every one of the 1/2 seed pods in my driveway on the way out. On the front.
trilby27 is offline
Tires for 8.5" wide wheels (front) conleyjb Tires, Wheels, Brakes & Suspension 21 03-09-2019 12:07 AM
How do I select a new set of wheels for a 55? NL-SLK55 Tires, Wheels, Brakes & Suspension 9 09-26-2016 01:15 PM
AMG/OZ 3-piece "classic" wheels on SLK 32 AMG SLK_32_AMG General Discussion 5 08-27-2009 05:24 AM
