Expensive tyre valve - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By Jules555
  • 1 Post By bigboyows
  • 1 Post By Sgooter
  • 1 Post By Grumpydev
  • 1 Post By Avel Du
  • 1 Post By Slkworm
  • 1 Post By Quaser8386
#1 Old 06-20-2018
Jules555's Avatar
Vehicle: 2013 SLK 250 CDi AMG
Other Toys: Aston martin DB9 Coupe 1/18 Aston Martin DBR1 1/18
Quoted: 223 Post(s)
Decided to check my tyre pressures this morning, as I often do. Rear drivers side first, checked and fine, took off foot pump and the the valve was not sealing, air leaking as if the valve was not there. Tried again same thing, managed to pull needle valve up with a small screwdriver but still not seating, leaking less but still leaking.
Off I go to my usual tyre depot, and they sort it for me free of charge, put new innards in the valve.
Then the chap asks me if I have had the tracking checked lately as the camber of the front wheels looks as if it is out, it was checked when they last fitted the front tyres not that long ago, says I.
I then remember going down an enormous pot hole fairly recently and suggest this may be the reason for it. I ask them to check the alignment for me. This they do and sure enough the fronts are both out. I ask them to correct it for me.
Five minutes later the guy comes back with the news that there is no adjustment without buying special bolts from Mercedes. So to cut a long story short, parts from Mercedes £60, cost of labour and the re-alignment a total of £230! Hence my thread title expensive tyre valve.
Life is too short to drive a boring car!
Jules
Jules555 is offline
#2 Old 06-20-2018
Delucas's Avatar
Quoted: 1132 Post(s)
Special bolts to do what for car ?
Wishbone damage ?
Bent tie bar ?
And £230 is that for a service also ?
Delucas is offline
#3 Old 06-20-2018
Vehicle: 2008 Jasper Blue R171 Facelift SLK350
Other Toys: 525d Touring, Aston Martin V8 Vantage
Quoted: 54 Post(s)
That sounds a bit fishy to me..
Grumpydev is offline
#4 Old 06-20-2018
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
Jules, did they give you a printout?
I remember a local MB dealer quoting £1000 for laser alignment!
Only ever use them for parts now.
I found a tyre specialist that does this for £40-50.
£950 mark up for using MB.
Quality costs.
On the plus side, is your car handling sweeter now?
#5 Old 06-20-2018
bigboyows's Avatar
Vehicle: SLK 55 AMG MY2016
Other Toys: Cars - 2015 Touareg R-Line 275 bhp, and yes Fiat 500 Sport 7, Bikes, Boats, Holidays, Dogs, Chickens
Quoted: 29 Post(s)
love what you've done to your wheels, car looks very nice
Jules555 likes this.
bigboyows is offline
#6 Old 06-20-2018
Vehicle: 2015 SLK350 Palladium/Beige, Sport
Quoted: 8 Post(s)
...Five minutes later the guy comes back with the news that there is no adjustment without buying special bolts from Mercedes...
Sounds like caster bolts. I needed them several years ago when my SL500's front wheels would not fully align. I feel your pain.
Sgooter is offline
#7 Old 06-20-2018
Jules555's Avatar
Quoted: 223 Post(s)
£230 this is for the cost of the bolts from Mercedes that are needed to be able to adjust the camber angle, the cost of the labour to fit the bolts and the cost of the alignment inc VAT. Job not done yet awaiting the parts.
I did ring my local MB dealer to check the cost of the parts and the £60 ish is correct. The bolts alone are £13 each X4 without washers or nuts.
Jules
Jules555 is offline
#8 Old 06-20-2018
Jules555's Avatar
Quoted: 223 Post(s)
That could be it Caster not Camber.
Jules
Jules555 is offline
#9 Old 06-20-2018
Quoted: 54 Post(s)
That makes more sense.. must have been one hell of a pot hole! Not that I want you to have another big bill, but have they checked the wheels to make sure there's no cracking/buckling
#10 Old 06-20-2018
Jules555's Avatar
Quoted: 223 Post(s)
It was one hell of a pot hole, I thought the bottom had dropped out of the car at the time. Wheel okay as far as i know, I did check myself and could not see anything.
Jules
Jules555 is offline
#11 Old 06-20-2018
Quoted: 54 Post(s)
You sometimes can't tell without taking the wheels off, and sometimes can't without taking the tyre itself off - fingers cross its sorted anyway. The worst I have done (touch wood!) is whack a kerb in my old TT going about 30mph when I was avoiding something, took a lovely couple of chunks out of the rim, and knocked the alignment out something rotten, but the rim was repairable and the alignment was sorted by my local protyre.
#12 Old 06-20-2018
Happened to the 350.
Couldn't track down the issue until tyres were replaced.
Wheel a write off, but could only tell when tyre was off.
#13 Old 06-20-2018
Slkworm's Avatar
Vehicle: Slk 200k 171, 2010, silver with sports pack
Other Toys: ASTRA VXR RACING LTD, RENAULT Captur
Chats: 2
Quoted: 48 Post(s)
Have them put it all in writing, and claim off council, re pot hole damage
Slkworm is offline
#14 Old 06-20-2018
Quaser8386's Avatar
Vehicle: Was a 2013 SLK 250 CDi - Alas! Gone Forever
Other Toys: Vauxhall Cascada (the wife's really)
Quoted: 183 Post(s)
Great advice there for @Slkworm Jules.
Hope it wasn't Welly Council - they'll likely put up our Council Tax to pay your compo.
Laughter aside....ouch!
John
Alas! No more SLK
Protected by the Sword of Truth and the Shield of Honour
Quaser8386 is offline
Metal tyre valve caps... greenmanslk Tires, Wheels, Brakes & Suspension 17 02-04-2018 07:53 AM
space saver wheel and tire adrose Tires, Wheels, Brakes & Suspension 45 12-30-2017 09:14 AM
DIY: Valve Cover Breather Cover Job PapCan514 SLK R171 Class DIY 9 01-26-2015 11:35 AM
Bought a new check valve and shut off valve Bradley61496 SLK R170 class DIY 11 02-26-2014 10:42 PM
DIY : R170 : '98 Benz SLK 230 How to exchange engine cover gasket and valve gaskets w PIC dr.Benz SLK R170 class DIY 13 08-06-2013 01:40 PM
