Rear coil springs - Mercedes Benz SLK Forum
 6Likes
  • 1 Post By Avel Du
  • 1 Post By Robjess
  • 2 Post By Avel Du
  • 1 Post By WoZ53
  • 1 Post By Robjess
#1 Old 06-01-2018
Vehicle: 2013 SLK 250 CDI AMG
Quoted: 9 Post(s)
Rear coil springs
I took my car in for an MOT and it failed on a broken rear coil spring, I had the garage replace both springs but the rear of the car seems/is sitting higher than it was before. The spring broke at the bottom so I know it will be a bit higher but I don't think it should be this high. The part number on the invoice is A1721241245, I am just wondering if they have fitted standard springs and not ones for an AMG model which should be 25mm lower. I do have the old springs which have 3 blue stripes on them and have been replaced with the same. They might just need to settle down a bit, has anyone else replaced the rear springs on their car and do they take a little time to settle.
Robjess is offline
#2 Old 06-01-2018
Moderator/RoTMorganiser
Quoted: 2198 Post(s)
I'll check vs your datacard.
Avel Du is online now
#3 Old 06-01-2018
Quoted: 9 Post(s)
Thanks very much, that would be great.
Robjess is offline
#4 Old 06-01-2018
3 blue stripe is sport AMG.
So you got A1721241245 & it says A2103243404.
Just in case I am missing something I'll ask Tim to review @WoZ53
Code 486 just says sports suspension
WoZ53 likes this.
#5 Old 06-01-2018
Quoted: 9 Post(s)
Thanks for your help on this, the part number you quoted does come up on the internet as a rear coil spring but the part number I have doesn't.
WoZ53 likes this.
Robjess is offline
#6 Old 06-01-2018
Let Tim take a look. He better with these things, but I am confident of the one I provided.
However, I am but mortal.
WoZ53 and Robjess like this.
#7 Old 06-01-2018
WoZ53's Avatar
Vehicle: 2006 280 SLK Caspian Blue Metallic
Quoted: 378 Post(s)
The part number Myk listed is the correct one for sport suspension.
Welcome to the forum
Where search is your friend
and the info never ends
Tim Wozny/ WoZ
Eureka,CA
WoZ53 is online now
The Following User Says Thank You to WoZ53 For This Useful Post:
#8 Old 06-01-2018
Quoted: 6441 Post(s)
And this thread not in suspension section
Because mods?
#9 Old 06-01-2018
Oh yes it is!
Not sure about Tim, but I thought only Jeff could do that
#10 Old 06-02-2018
Quoted: 9 Post(s)
Thanks for your help, I will give the garage a ring on Monday. If someone has a standard AMG styled SLK CDI and gets a chance could you please measure the distance from the centre of the rear wheel to the underside of the wing, i can't find that information anywhere.
Robjess is offline
#11 Old 06-02-2018
@DaveR. might be able to help. He'll check in soon.
DIY Rear Differential Jack Pad for SLK55 AMG AMGPilot SLK R171 Class DIY 3 02-27-2018 12:06 PM
Front & Rear Coil Spring Shock Replacement gringott SLK R170 class DIY 4 07-10-2015 10:56 AM
Just replaced the rear cats in my wife's 2002 SLK 32 AMG wallew AMGs 16 09-15-2014 06:35 PM
Sagging rear? halcyon0 SLK R170 General Discussion 7 01-24-2012 07:49 PM
