SLK 200 rear brake caliper piston ( uk 2005) - Mercedes Benz SLK Forum
#1 Old 05-26-2018
Vehicle: SLK 200 R171 silver 2005
Other Toys: Kawasaki Versys 650
Quoted: 20 Post(s)
Hi to all,
Just about to change brake pads on the above. I did take the old pads out just to check the right fitting before I ordered new ones they Are fine. I did put the old pads back in and had to push the piston back using just a bit of pressure and a screwdriver. My question is , when I do this should I be winding the piston back in. Also is it necessary to remove the caliper to change the pads it just a single pin holding them in
Marauder
marauder1964 is offline
#2 Old 05-26-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 897 Post(s)
No need to remove the calipers to change the pads. I use one of those to push back the pistons. Make sure you open the brake fluid reservoir cap.
i860 is online now
#3 Old 05-26-2018
Delucas's Avatar
Quoted: 1133 Post(s)
Originally Posted by marauder1964 View Post
Hi to all,
Marauder
Simple procedure to do no special tools req
And the piston just slowly pushes back
Just make sure inside is cleared of any debris and some copper grease is used on pads edges etc and pins .
Delucas is online now
#4 Old 05-27-2018
Quoted: 20 Post(s)
SLK 200 brakes
Hi
Thanks for replies , job done
Fairly straightforward. Just pushed the Pistons back slowly as there were no notches in the piston.
I take it the front is just as simple ?
Thanks again
Marauder
R172 Rear Brake Pad Replacement WhiteRabbit SLK R172 Class DIY 33 02-13-2019 09:48 AM
