Time to spend some money... =( - Mercedes Benz SLK Forum
 8Likes
  • 4 Post By Godfrey
  • 1 Post By rya96797
  • 1 Post By etyu
  • 1 Post By etyu
  • 1 Post By jbanks15
#1 Old 11-18-2016
SLO
Vehicle: 2006 SLK55
Quoted: 13 Post(s)
So - a question and a lamentation here.
Question first - I've gone through a bunch of archived threads, but haven't found a consensus on whether rotors and pads should always be replaced together. My service tech says yes - but in the next breath says that the rotors are in good shape. Car just hit 30k miles - and I don't believe it's been tracked. I'll get a caliper reading to be sure, but I'm curious what everyone's gut says.
Lamentation is that it also got stuck in gear the other day (autobox)... I'm guessing conductor plate. Seems lie that's been a common problem for a lot of folks. Time to see if the warranty is any good...
SLO is offline
#2 Old 11-18-2016
Vehicle: 2006 SLK 280 Black
Other Toys: None
Quoted: 101 Post(s)
If the pads are worn to the wear limits and the rotors are in good shape (flat, not scored, etc) and not yet near the wear limits, I see no point to changing them unless they're close enough to the wear limits that it's likely the rotors will wear past the limits faster than the pads do.
If they're on the edge, change them.
G
etyu, dbgrn, SLO and 1 others like this.
Godfrey is offline
The Following User Says Thank You to Godfrey For This Useful Post:
#3 Old 11-18-2016
Vehicle: I like it a lot
Other Toys: slk55
Quoted: 11 Post(s)
i guess ymmv, but i hear about people changing rotors at 60k miles = 2 sets of pads, then rotor change. Like the other poster said, depends on the condition of your rotors.
Are your pads done already at 30k miles? my service advisor said there's like like 40% left, and I just hit 30k miles. Of course, I rarely do hard braking. A lot of freeway driving; even in the city, I don't brake really hard. Letting off the gas on the amg lets the car coast to the stop. Also, I downshift sometimes, if you keep the car in the 2k range, you can stop pretty much without braking.
etyu likes this.
rya96797 is offline
#4 Old 11-18-2016
Quoted: 6579 Post(s)
I did not have to change my rotors until 102000
#5 Old 11-18-2016
Other Toys: None
Quoted: 101 Post(s)
I changed all four rotors in the SLK230K at 129,000 miles. The fronts were right at the wear limit when the pads were worn out (probably third-fourth set), and the rears were close enough at that point that I went for all of them.
At 85000 miles in the SLK280, pads were replaced just before I bought the car and the original rotors are fine, should run another 30-40K miles easily.
G
Godfrey is offline
#6 Old 11-18-2016
No need to replace brake discs/rotors if they are above the wear limits (based on micrometer measurements).
I am still on the original front and rear brake pads from when I "backdated" (from 2008 to 2007) my front and rear brakes. That was about 60K miles ago. The front pads may need replacement at next service, however. Current mileage is near 94K miles.
Addendum:
Test values for front brake discs:
Model 171.473 (SLK55):
new: 32 mm,
wear limit: 30 mm
wear limit for maintenance service: 30.6mm
Models 171.445/454/456 (SLK 200/280/350):
new: 28 mm
wear limit: 25,4 mm
water limit for maintenance service: 26 mm
Test Values for rear brake discs:
Model 171.473:
new: 26 mm
wear limit: 24 mm
water limit for maintenance: 24,6 mm
Models 171.454/456/458, model 171.442/445 with code 952:
new: 10 mm
wear limit: 8,3 mm
wear limit for maintenance service: 8,8 mm
Vernier caliper part no. 140 589 00 19 00
#7 Old 11-18-2016
SLO
Vehicle: 2006 SLK55
Quoted: 13 Post(s)
Thanks all - pretty much confirms my gut. I don't mind changing the pads out, since I've been itching to go to Akebonos since I picked Heidi up. I rarely use the brakes, but I can't vouch for what the prior owner did! We'll measure them out and go from there.
Probably no escaping the conductor plate issue, though!
SLO is offline
#8 Old 11-18-2016
conductor plate issue was usually for m272 engine but M113 has it but very rare in my opinion
#9 Old 11-18-2016
This is not related to the engine type but related to the (sensors in the conductor plate) part used in the transmission itself: 722.9 transmission W7A 700 variant.
I did get this conductor plate failure (on the R171), service advisor states the replacement is an updated part (hopefully will be longer-lasting). Glad it occurred while under warranty.
#10 Old 11-18-2016
engine, transmission, tomato, potato
etyu likes this.
Daylight savings time changes tonight 2 am for those that participate. jbanks15 General Discussion 31 11-05-2018 10:16 AM
AMG SLK55 KLEEMANN Motor Widebody *TAX WRITEOFF* CorbinWidebody SLK Cars For Sale 14 11-11-2016 12:07 AM
11 psychological tricks restaurants use to make you spend more money jbanks15 Off Topic 4 07-31-2016 04:08 PM
My first time servicing car >> Quick Q re oil etc. SLKEIRE SLK R171 General Discussion 25 02-23-2013 10:53 PM
Help Contribute to SLK World Forum! jbanks15 General Discussion 14 04-30-2009 10:54 PM
