TPMS pic - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By LeonardoDaBenz
  • 1 Post By jbanks15
  • 1 Post By AMG-UFO
  • 2 Post By Seanhump
#1 Old 11-03-2016
LeonardoDaBenz's Avatar
Quoted: 1064 Post(s)
TPMS pic
My build sheet says I've got TPMS but I'm not sure as there were replacement tires on Schwarzie when I got her. Looks like plain metal caps. Any pics of what it's supposed to look like is quite different from what I thought they should be. OR does it just look like a regular stem (on the outside)?
Someone take of pic of their tire/valve stem so I can see what it should look like?
Assuming that mine weren't replaced, would these make a suitable replacement?
4PCs Car Auto Tire Pressure Monitor Valve Dust Cap Indicator Sensor Eye Alert | eBay
I don't want to spend $3-4-500 (from what I've found for OEM) for these things.
LeonardoDaBenz is offline
#2 Old 11-03-2016
Quoted: 6554 Post(s)
Here ya go!!
rxjr22 likes this.
#3 Old 11-03-2016
Vehicle: Former SLK/350/55 Owner
Other Toys: C43AMG Cabriolet, A 220 4MATIC, W114/8
Quoted: 228 Post(s)
I thought that the tpms is a sensor at the wheel hub that records differences in tyre rotation. Or at least this is what they told me when I changed tyres and noticed that there was no difference between my wheels and some others.
But this may apply to R171 pre facelift models.
Tapatalking
Charlie350 is offline
#4 Old 11-03-2016
yes, 2 kinds. the one you described and the one I posted
#5 Old 11-03-2016
Vehicle: 2013 SLK55 AMG
Other Toys: Trek Madone 6.5, Gios Torino, Richard Sachs
Quoted: 65 Post(s)
As Jeff said, two different versions of sensor.
What is TPMS & How Does it Work? | Bridgestone Tires
Beware of using aftermarket metal caps on the active version. Galvanic action causes corrosion and stem failure. The Mercedes OEM and accessory caps are plastic.
AMG-UFO is offline
#6 Old 11-03-2016
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
The rotational TPMS uses the ABS sensors in the wheels and detects differences in the speed of wheel rotation ...
It can be enabled via software on all R171's
The 'smart' TPMS uses sensors in the wheels and another ECU in the back of the car, plus need an instrument cluster with a certain software version to work, but it can all be retrofitted ....
Then you get the actual tyre pressuses in your upper display - this one has the valve stems like Jeffs ...
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#7 Old 11-03-2016
Mine are not like Jeff's pic. Plain metal caps on mine so I'm assuming it's a "non TPMS" setup. I'll check with the dlr next time I visit.
So Sean, seeing as I don't have the AMG caps, would I still get to see that display (albeit with no info)?
#8 Old 11-03-2016
Seanhump's Avatar
Quoted: 424 Post(s)
It's not the caps that determine the TPMS, but the valve stems - look at JB's pics and you'll see a nut holding the stems in place, instead of the straight valve stem.
You can get the pic up on the upper MFD, but you'll also get the associated errors too, every time you start the car, as the TPMS system isn't there / functioning.
DAS needed with developer mode to enable the meun on a 171, not sure on the 172 ...
Sean
Mods so far...
Seanhump is offline
#9 Old 11-03-2016
Tks. I'll have to check further. I get no messages so...... we'll check it out
TPMS Info needed Seanhump General Modifications R171 6 10-09-2018 03:35 AM
TPMS Retrofit... its started.... Seanhump General Modifications R171 228 01-19-2018 12:03 PM
Aftermarket TPMS for Mercedes carid CARiD.com 0 10-22-2015 10:43 AM
DIY Brake job dsb SLK R171 Class DIY 39 01-17-2015 06:01 PM
TPMS alert during engine shutoff duckman General Discussion 8 09-02-2011 06:01 AM
