Brake Flushing - Mercedes Benz SLK Forum
 6Likes
  • 1 Post By dbgrn
  • 2 Post By cewhite3
  • 3 Post By raffid
#1 Old 09-15-2016
raffid's Avatar
Vehicle: 2009 350 SLK
Brake Flushing
Hello everyone,
I have an 09 350 slk. with around 79K.
My dealer has recommended have the brakes flushed. They want $400.
I contacted another dealer (much smaller company) and they told me they don't recommend the service unless I was having issues (which i am not). They said the brake fluid is guaranteed for life.
I bought the car with 49K and I don't know if had been done before.
Thoughts????
raffid is offline
#2 Old 09-15-2016
Quoted: 6580 Post(s)
#3 Old 09-15-2016
Brake fluid guaranteed for life!?????
NOPE!
check your maintenance manual. every 40000 miles
#4 Old 09-15-2016
dbgrn's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 1035 Post(s)
As Jeff has already mentioned, it would be great if you could make an introduction thread here please: New Members Introduce Yourself Here - Mercedes Benz SLK Forum
... and I think the MB maintenance manual says brake fluid should be replaced every 2 years. $400 sounds expensive, but then I'm not sure I'd want to trust a garage that says brake fluid is guaranteed for life! Perhaps try finding somewhere else, if you really don't want to pay the MB prices (do you have a reputable independent nearby?).
- Dave
Mods:
(MB p/n A1718202075)
wind deflector
• Post-FL wing mirrors
• CF-effect interior trim
• AMG LED puddle lights
• Piecha DRLs
dbgrn is offline
#5 Old 09-15-2016
Vehicle: 2006 SLK 280
Quoted: 26 Post(s)
Originally Posted by raffid View Post
Hello everyone,
Thoughts????
This is one of those things where European and US manufacturers often disagree. While the brake fluid might not "wear out," it can become contaminated with water and wear particles from the various moving parts in the system. Likely your car is using DOT 4 Brake Fluid. The following information from Wikipedia is a good staring point for learning more about brake fluid (https://en.wikipedia.org/wiki/DOT_4):
"DOT 4, like DOT 3 and DOT 5.1, is a polyethylene glycol-based fluid (contrasted with DOT 5 which is silicone-based). Fluids such as DOT 3, 4, and 5.1 are hygroscopic and will absorb water from the atmosphere. This degrades the fluid's performance, and if allowed to accumulate over a period of time, can drastically reduce its boiling point. In a passenger car this is usually not much of an issue as the brakes are generally not used so hard, but can be of serious concerns in police vehicles, race cars or motorcycles due to the higher heat generated during their much more aggressive braking, and trucks where higher heat can be generated while braking hard and fully loaded."
In addition to the concerns regarding the lowering of the boiling point, water in the system can also promote corrosion, although I have never seen this as a big problem on modern cars (it used to be a real problem with older cars with less well sealed braking systems).
I assume that Europeans manufacturers (particularly the Germans) recommend the changing of brake fluid because they are more concerned about brake fade than manufacturers in the US where typical speeds used to be significantly lower, and therefore less of a demand on the brakes. These days speeds in the US are much higher than just a few years ago. On the other hand, most modern braking systems are much better and fade is not as big an issue. The Japanese recommend brake fluid changes because it is a Japanese thing to do.
Personally I change my brake fluid every three years. It can't hurt and I feel that it can help keep the components in the brake system in better shape (I worry about the effects of moisture on the very expensive ABS pump). On the other hand, I do it myself and brake fluid is cheap. A $400 charge for changing the brake fluid seems ridiculous. 1 Liter of Pentosin 1204116 Super Dot 4 Brake Fluid costs around $13. The garage will likely use a pressure bleeder (the Mercedes recommended method). This connects to the master cylinder reservoir and pressurizes the system. The car is lifted in the air and the mechanic walks around to each wheel and opens the wheel bleed to allow the old fluid to be pushed out and replaced by the new. Start to finish it can't take more than an hour. Even with $120 labor rate, taxes, disposal fees and equipment charges, the whole process should not cost more than $175 at a high end dealer.
I changed my SLK280's fluid earlier this year using a vacuum system and a floor jack and did it in less than 2 hours. The vacuum system is much slower because you have to attach it to each individual wheel and "suck" the old fluid out. Since you are only working with atmospheric pressure to force the fluid through the system, it is much slower. I also had to use the floor jack to lift the car at each corner and remove and replace the wheels one at a time.
You can also just use the old manual pump the pedal system to change the fluid, but that takes two people and a lot of leg work.
I think changing the brake fluid is a good idea and that you should be able to find a decent independent shop to do it for a lot less than $400.
Ed
JimF and Past60 like this.
cewhite3 is offline
#6 Old 09-15-2016
raffid's Avatar
Thanks for the help everyone.
After looking at the bill, I realize there was some kind of a glich or entry error. They included the cost of materials for the front brakes on the flushing quote.
The cost to flush is $170. (sounds cheap now after thinking it was $400!)
Appreciate the quick responses.
jbanks15, dbgrn and Past60 like this.
raffid is offline
#7 Old 09-16-2016
Quoted: 1138 Post(s)
5 lt of brake fluid approx = £15.00
you will use 500ml - 1lt so £6.99
An hour labour = £40.00 - £60.00 approx
So £75.00 max you should pay.
And id run if they quoted £400.00 dollars
Even if it was a mistake .
Delucas is online now
R172 Rear Brake Pad Replacement WhiteRabbit SLK R172 Class DIY 33 02-13-2019 09:48 AM
Removing & Replacing the Brake Light Switch on the R170 Series sckothmann SLK R170 class DIY 12 01-06-2019 02:23 PM
55 AMG Rear Disc Replacement and Hand Brake problem HarryH SLK R171 Class DIY 2 06-18-2016 08:58 AM
Help : Replace front & rear pads and Brake Fluid flushing robbiemarcelo SLK R170 General Discussion 11 03-12-2013 11:34 AM
