brake lines - Mercedes Benz SLK Forum
  • 1 Post By Roxanne7169
#1 Old 08-17-2016
Vehicle: 1999 Mercedes SLK 230 Kompressor 5sp Manual
Quoted: 50 Post(s)
brake lines
My rear brake lines (both hard lines underneath) are corroded and need replaced. This was also noted on the so-called "safety inspection" last year.
I went to the dealer to order them yesterday and the guy said he thinks they come in sections/lengths and I would have to bend as required and flare and install fittings myself.
My question is: is this normal? Has anyone ordered these from dealer? Do they come pre bent? I don't have bending/flaring tool and you can't rent jack$hite for car tools here in Germany.
I'd prefer to order pre bent lines, is this possible from anywhere else?
Thanks.
clown is offline
#2 Old 08-17-2016
Bobbybenzino's Avatar
Vehicle: 98 Slk230 Just bought it a week ago..Driven Mercedes all my life..
Other Toys: 99 C240
If it's just copper tubing you should be able to buy the size use a flaring tool flare it bend as desired and use the old fittings and you should be good to go.. per tubing is very cheap.. Flaring tool should be less than $20
Sent from my HTC One M9 using Tapatalk
Bobbybenzino is offline
The Following User Says Thank You to Bobbybenzino For This Useful Post:
#3 Old 08-17-2016
Vehicle: 2005 SLK 350
Other Toys: H20 V-Dubs, MK1s
Quoted: 411 Post(s)
I have purchased sections of brake lines (metric-for European cars) here in the US at a common parts store like AutoZone. They come in sections like 1,2,4,6 feet and have the fittings installed already (no flaring involved). The pre-measured sections sometimes were longer than I needed, so I used a tube bending tool to make loops in them (picture a roller coaster loop).
The trick is to buy the line with the right kind of flare. The other trick is to not pinch the line while you are bending it.
Bobbybenzino likes this.
Roxanne7169 is offline
The Following User Says Thank You to Roxanne7169 For This Useful Post:
#4 Old 08-20-2016
Quoted: 50 Post(s)
I'm bumping this thread.
Has anyone replaced any fuel or brake system hard lines?
Are pre-bent lines not an option for either?
Thanks for any help.
clown is offline
#5 Old 08-21-2016
Quoted: 411 Post(s)
I'm $ure that pre-bent tube$ are among your option$, providing of cour$e you can find $ome. I'm al$o $ure that buying $ections (fitted for Euro car$) i$ a more economical choi$e.
R172 Rear Brake Pad Replacement WhiteRabbit SLK R172 Class DIY 33 02-13-2019 09:48 AM
Removing & Replacing the Brake Light Switch on the R170 Series sckothmann SLK R170 class DIY 12 01-06-2019 02:23 PM
55 AMG Rear Disc Replacement and Hand Brake problem HarryH SLK R171 Class DIY 2 06-18-2016 08:58 AM
New Front Brakes 2000 SLK230 SLK R170 class DIY 20 12-28-2014 01:46 PM
