Conti DW verses Michelin Pilot Sport - Mercedes Benz SLK Forum
 3Likes
#1 Old 03-14-2013
Sadly Gregg has passed away
Gregg's Avatar
Vehicle: 2009 SLK 350
Chats: 5
Quoted: 17 Post(s)
I've narrowed down tire choice to Conti DW or Michelin Pilot Sport. The Pilot Sport is a little more expensive, but beats the Conti DW in every category when compared side by side on the Tire Rack comparison chart. The Tire Rack consultant says the Pilot Sport is a much better tire all around. Any advice or suggestions would be appreciated. Thanks!
Gregg is offline
#2 Old 03-14-2013
Quoted: 6496 Post(s)
Gregg, i'm gonna move this to the tire section, ok?
I recommend contis as I have had both
#3 Old 03-14-2013
SLicKer's Avatar
Vehicle: 2003 SLK320
Other Toys: 89' Waggy - 77' 280z - 68' TR250 - 66' 1600 Roadster
Michelins are more expensive initially but the value comes from their performance and great wear characteristics. As with any tire; regular rotations and maintaining correct tire pressure is critical to longevity. All of my cars shoes are Michelins with Pilots on the SLK.
Gregg likes this.
SLicKer is offline
The Following User Says Thank You to SLicKer For This Useful Post:
#4 Old 03-14-2013
Gregg's Avatar
Chats: 5
Quoted: 17 Post(s)
OOPS! Forgot we had a tire section! Do we have a tire section? Yes...we do!
Gregg is offline
#5 Old 03-15-2013
Chats: 2
Quoted: 13 Post(s)
Which PS are you thinking of getting? There are 5 different "models" and none listed have the correct 17" sizes.
The "SuperSport" does come in the correct sizes...
Also, you tell me you want ride comfort and noise comfort and the DW is rated higher than the SS, per the TR test results.
Think outside the box!
Galo is offline
#6 Old 03-15-2013
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Slickr... unfortunately, with the staggered tires on the SLK "rotation" requires pulling the tires off all four rims. In addition some are also asymmetric and unidirectional (not sure about the tires being discussed here) which precludes rotation, period. But I hear you!
Good luck with your pick Gregg.
I have Rykens (a Mich derivative) still on the fronts - horribly noisy tire...
FUN 4 2
Der Flieger is offline
#7 Old 03-15-2013
Gregg's Avatar
Chats: 5
Quoted: 17 Post(s)
My bad! Actually, I did order Pilot Super Sports.....wouldn't want to order tires that wouldn't fit now would I? However, the Pilot Sport A/S Plus does come in the correct sizes.
We must not be looking at the same info.....the Pilot Super Sport had higher ratings than the DW in every category on the Tire Rack Customer Survey Data site. We will see how they work out and report back.
Gregg is offline
#8 Old 03-16-2013
Chats: 2
Quoted: 13 Post(s)
Gregg, try reading the actual "tests" performed by the TR staff, not a consumer who hasn't back-to-back tested the tires on the road.
Also, the PS A/S is an ALL SEASON tire(like the DWS, but not as good) not in the same class as the PS or DW.
Galo is offline
#9 Old 03-16-2013
cheahk's Avatar
Vehicle: 2008 SLK 350
Send a message via Yahoo to cheahk
What tires do you have now, Gregg? Would like to hear about your before/after experience.
-K
cheahk is offline
#10 Old 03-16-2013
06SLK-Noob's Avatar
Vehicle: 2006 SLK280 - Silver
Other Toys: 2014 CLA250, 2013 Nissan Leaf
Quoted: 28 Post(s)
I just put Pilot Sport A/S Plus on mine. Very happy with them. Of course, that was only 2 weeks ago, so I can't give a long-term eval yet.
Gregg likes this.
06SLK-Noob is offline
#11 Old 03-16-2013
Gregg's Avatar
Chats: 5
Quoted: 17 Post(s)
-K
I have Conti CS3 all around and have been very satisfied with them since purchasing the vehicle. 2nd set of rears are near the wear bars so I thought something different might be worth a try. Wanted something quiet and smooth. Pilot Super Sports are very highly rated by actual customers who run them on similar vehicles and I value consumer opinion. They were also recommended over the Conti DW by the Tire Rack Consultant I spoke with on the phone. The PSS is a more expensive tire, but not by a huge margin. I'll report back after fitment and test.
Gregg is offline
#12 Old 03-18-2013
ponia003's Avatar
Vehicle: 2006 SLK280, 2005 E500 (W211)
Other Toys: Horses
Quoted: 29 Post(s)
I have the Pilot Sports and I'm enjoying them so far. I'm sure you will too.
Dan
2006 SLK280
Engine: 272.942 V6
Options: Iridium Silver Paint, Harmon Kardon Sound System, Heated Seats, Air Scarf, Vavona Wood Trim
Modifications: 18" AMG wheels, Brembo Sport Pack Front Rotors and Calipers, 290 mm Rear Rotors and Calipers, SmartTop, Akebono Ceramic Brake Pads, Mid-Size R171 Facelift Antenna, Clear Sidemarkers, Chrome Turn Signal Bulbs, Mercedes Star Valve Stem Caps, Custom Cabin Air Intake Screen, AMG Tinted Tail Lights and 3rd Brake Light, Xenon Low Beams, OEM Sport Air Cleaner with Custom Port Screens, LED License Plate Lights, LED Parking Lights, Lamin-X Fog Light Films
ponia003 is offline
The Following User Says Thank You to ponia003 For This Useful Post:
#13 Old 03-18-2013
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
Check the Conti's DWS they are all season, hi marks for dry and wet. I have them on the rear and projecting near 30k. to wear bars. Even if you do not drive in snow they are still good. Great ever day driving in all weather.
Gbarringer100 is offline
#14 Old 03-18-2013
Ynot's Avatar
Quoted: 23 Post(s)
Michellin is quieter too, it's all an around better tire but of course you have to pay the premium. Nothing wrong with the Conti's though. They make good tires.
997 TPC turbo C4S
981 Boxster S
06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR. (Gone but not forgotten)
Ynot is offline
The Following User Says Thank You to Ynot For This Useful Post:
#15 Old 03-18-2013
paultalb's Avatar
Vehicle: '04 SLK32 //AMG Needswings upgrades -- 4Sale
Other Toys: F150, A3 quattro, XC70 Polestar, MB Sprinter
Chats: 7
Conti did away with the mileage warranty on the DW, my second set was covered.
paultalb is offline
#16 Old 03-19-2013
slickBenzGirl's Avatar
Vehicle: 2012 SLK 250 totaled - current car: 2016 Dodge Challenger SRT392 in Plum Crazy Pearl Coat (purple)
Other Toys: my husband's 2016 Dodge Challenger SRT392 in GoMango (orange)
Quoted: 36 Post(s)
Michelin has tire warranty with their Supersports - i think most of their tires (including the PS) have that + roadside assistance
slickBenzGirl is offline
#17 Old 04-10-2013
Gregg's Avatar
Chats: 5
Quoted: 17 Post(s)
I've had time to put a few hundred miles on the new Michelin Pilot Super Sports (MPSS) and here are my comments.........
1) The MPSS tires have a significantly smoother ride when compared to the Conti CS3s. This is true on both smooth and rough pavement types regardless of vehicle speed. Subtle pitching moments and general vibration are much decreased.
2) The MPSS tires are markedly more quiet than the CS3s. There is virtually no road noise from the MPSS on smooth pavement....reminds me of my Cadillac w/ touring tires and it was kind of eeire at first.
3) The MPSS seems to have a tad more side wall flex when compared to the CS3. It is only noticeable when cornering very hard at moderate speeds (50-80 mph). Traction feels about equal for both tires. The car feels more sure footed on low speed curvy roads, but there is clearly a different feel that takes a little getting used to. The car is more controllable and linear at speeds over 100 mph (not as much side to side drift).
General Comments -
According to the tire technician, very little weight was required to balance the tires as compared to what was in place on the CS3s. To me this indicates a more uniform construction, but there may be other reasons I'm not considering.
I liked the CS3, but I have to agree with the Tire Rack Consultant's comment that the MPSS is in another league. At least for my use, the MPSS seems ideal. Of course the CS3s were worn to within 2mm of the wear bars so its not really a new tire to new tire comparison.
Finally, the Tire Rack people were very helpful and tire price was much better than local tire stores. Shipping cost was washed by no sales tax since the items shipped from out of state. Just so happens that my favorite local tire shop was a Tire Rack authorized installer so that all went very well too. I'm waiting on Michelin to issue the rebate card.
Good luck to everyone who goes down the new tire road. It's safe to say that Challenge is very happy with his new shoes!
Gregg is offline
#18 Old 04-10-2013
Fanatical Member
Stinger's Avatar
Other Toys: yes
Hey Gregg. I am not sure about the Conti's, but I just replaced my original Pirellis with the Michelin Super Sports as well. I agree with everything that you have stated vs. the original equipment with one exception. I notice a bit more road noise. Nothing that is really bothersome, but road noise from the Pirellis that came with the car was not noticeable at all, but now I definitely am aware of a "quite" humming of the tires.
Having said that, smoothness, ride comfort and cornering are huge improvements! While I still had some tread left on the fronts (but I replaced them to have a matching set anyway) the rears were shot after 13k miles. I am just hoping for a longer life on the rears cause those puppies ain't cheap!
The width on the new Brabus wheels went from 7˝/8˝ to 8˝/9˝ respectively so I am not sure if the wider wheel has anything to do with the noise or not.
Overall, so far I have to say I'm a happy camper. We should check back on this topic 12000 miles down the road.
Gregg likes this.
Steven
Stinger is offline
#19 Old 04-10-2013
Vehicle: 2013 SLK55 AMG
Other Toys: BMW M3
Another choice
How about looking at the New Michelin Super Sport?
A great tire!
dlomshek is offline
#20 Old 04-13-2013
Quoted: 36 Post(s)
I'll be getting SuperSports soon. I'll let you know how they are after driving on them. They're supposed to be pretty good via anecdotal evidence from other drivers of higher end vehicles with whom I have spoken.
Michelin Pilot Super Sport Sway Tires, Wheels, Brakes & Suspension 11 06-25-2013 03:39 PM
Michelin Pilot Sport A/S Plus Brian_74 Tires, Wheels, Brakes & Suspension 18 04-03-2011 07:10 PM
Michelin Pilot Sport Cups for my SLK55 AMG alroumi Tires, Wheels, Brakes & Suspension 17 08-12-2010 09:18 AM
Michelin Pilot Sport All Season not approved by MB Tslick General Discussion 3 11-18-2006 05:45 AM
