Help! Wobble when braking - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By Adrian Abshire
  • 1 Post By jbanks15
  • 1 Post By Hui Sweetcheong
#1 Old 06-25-2016
Vehicle: 2006 SLK280 White stock... So far
Other Toys: 1998 45' Newell Dual Slide Coach, 2012 Jeep Wrangler Unlimited Rubicon
Send a message via MSN to Adrian Abshire
We picked up the wife's 2006 SLK280 yesterday and it has a wobble/shimmy/shake only when braking. I would venture to guess this is the rotor that is warped... Should I replace the rotor with vented rotors and what pads to use. I want to get this done today if possible and do the work myself. Will NAPA/AutoZone/Oreilly have the brakes (ceramic?) and rotors I need? NAPA had some slotted rotors but not sure of the quality... $145 but I like to stop as quickly as possible so money is not really a problem...
http://www.napaonline.com/napa/en/p/...400_0249144975
Adrian Abshire is offline
#2 Old 06-25-2016
Quoted: 6580 Post(s)
from your vin
#3 Old 06-25-2016
Wow, thanks! So you think I need rotors and pads? Are the parts stores going to carry the sensor (I think that's what it's called)?
#4 Old 06-25-2016
sorry, i am not the expert. others will chime in when they are not enjoying the weekend and their meets in the UK
those pdfs have the part numbers so you can get exactly what you need.
you might head to mb parts either at dealer or online sites
#5 Old 06-25-2016
I found ceramic pads and drilled rotors at Advance Auto Parts - never thought they would have them in stock but they do! NAPA - nothing in stock, Oreilly had rotors but not drilled and no ceramic pads... So off to Horrible Freight to get a jack and stands to change the brakes... Hopefully bleeding these brakes is not difficult... I do have a brake bleeder from my Miata days that I can use hopefully...
Off to YouTube for some tips!
#6 Old 06-25-2016
or our diy section
WoZ53 likes this.
#7 Old 06-25-2016
Hui Sweetcheong's Avatar
Vehicle: Merc SLK 200 (171) 2008. Right hand drive - Japanese spec
Other Toys: Self balancing personal transporter, elec bike, etc
Quoted: 75 Post(s)
Hi
Good day.
Your problem could be because of the front wheel bearings and not necessary the disc or brake pad.
Please do a simple test if it is due to the front wheel bearings. (left & right wheels)
Jack your left front wheel up. (wheel hanging in the air)
1) Using both hands, grab the wheel on 1 o'clock & 6 o'clock' position.
Try to shake or rock the wheel.
If there is a slightest movement, then it could be the problem.
2) Then do it again on 9 o'clock & 3 o'clock' position but in this positions, please make sure the steering wheel is locked or get someone to hold it tight.
Also make sure all the steering system are of no movement when you do this test. eg: ball joints, lower arm ball joints, etc.
If it is only just the movement as in (1) then it is mostly your wheel bearing is at fault.
If you have no "grinding sound" when free wheeling, the the wheel bearing is just simply a wee bit loose.
DIY?
Remove the wheel & then tighten the wheel bearing.
Simple as that? not really if you don't know how.
Open the wheel bearing cap & tighten it according to manufacturer' spec.
Rule of thumb: tighten the wheel bearing hand tight until the wheel cannot spin with your hand.
Then Loosen it by a a quarter or half turn.
check again as in (1)
At the same time apply as much grease as possible to the bearing.
This should solve your problem.
Thank you & have a nice day.
ps: must do this check for both wheels.
slk320chick likes this.
Hui Sweetcheong is offline
#8 Old 06-25-2016
After running the jack stand through the side of the car (don't ask) I decided to take it to a local brake shop...
They are saying the rotors I bought from Advance are not correct because I bought the 'Sport' package and I have the non-Sport package... I know the Sport brake pads don't fit but are the rotors different?
#9 Old 06-25-2016
Quoted: 549 Post(s)
Yes, they are probably larger, fronts 330 mm instead of 300.
Sneaky Pete is online now
Tags
brake, pad, rotor
Clutch Pedal Drops to Floor Under High RPM Engine Braking Rush2112 SLK R171 General Discussion 20 05-25-2016 06:46 AM
VW Designed a Baby Stroller With Automatic Braking After Joking About It in an Ad Berliner Heckflosse Off Topic 0 08-12-2015 03:37 PM
Braking with the 7G - how do you do it? Roy350 SLK R171 General Discussion 25 04-23-2015 03:48 AM
High pitch noise when braking in slow speed li174 SLK R171 General Discussion 3 10-11-2012 02:19 AM
