help.need oem wheel alignment specs for 55 - Mercedes Benz SLK Forum
#1 Old 06-25-2016
Vehicle: 2006 SLK 55 AMG
Hi.
Can someone please post up the oem factory specs for the correct wheel alignment for my 55 please.
I had a wheel alignment done on the Hunter machine but my steering wheel is slightly offset.
When driving in a straight line I need to keep to a couple of degrees to the right!
I have the results of my alignment so if someone could post the oem ones I can compare these.
Thanks.
hugy is offline
#2 Old 06-25-2016
Search feature (⚲) is your friend: https://www.slkworld.com/153176-post41.html
There is also a scanned pdf document on the above link (at the bottom of the post).
IIRC, the steering wheel being off-center with the vehicle driving straight may have to do with the clock-spring (misalignment) located in the center/core of steering wheel (there is thread on this also). Perhaps the wheel alignment was off initially and the misaligned steering wheel compensated for this. Now that wheel alignment is within spec, the steering wheel misalignment comes to light. (Just a speculation on my part).
#3 Old 06-25-2016
Thanks Eddy
I went back to the shop today and they said they would have to do another 4 wheel alignment to center the steering wheel.
Getting it done on Monday.
hugy is offline
#4 Old 06-27-2016
Update.
Just back from the shop.
The guy had to re-do the 4 wheels and adjusted the front (Toe) on both sides.
Its much better now and I think its more or less perfect.
hugy is offline
#5 Old 06-27-2016
Originally Posted by hugy View Post
Update.
It's either perfect or not
#6 Old 06-27-2016
OK,its Perfect
hugy is offline
#7 Old 06-27-2016
Vehicle: GONE - 2005 SLK350 Auto Caspian Blue/Beige Trim ,Heat, Light, Comfort, Premium, Ent. w/Nav
Other Toys: 1967 Chevrolet El Camino.2015 Charger R/T R&T B5 Blue
Quoted: 213 Post(s)
"perfect enough"
Pioneer4x4 is offline
#8 Old 06-27-2016
OK,its Perfect
Originally Posted by Pioneer4x4 View Post
"perfect enough"
Wheel Alignment Now in Doncaster pj1racing Where to get R170 SLK Items 0 04-20-2008 05:53 AM
steering wheel alignment jfsully SLK R171 General Discussion 5 12-17-2006 06:30 PM
