EIBACH 2552.140 Pro-Kit Performance Lowering Springs - Mercedes Benz SLK Forum
#1 Old 06-20-2016
Vehicle: 2000 SLK230 R170 Silver
Hello all,
Today I replaced the stock springs of my 2000 SLK230 with EIBACH Pro-Kit Performance Lowering Springs which lower the car about 1.2"
The car looks great now and performs and corners much better. but I now notice some squeeking when going over speed bumps. Is this normal? is there a solution for it?
jassem23 is offline
#2 Old 06-20-2016
I've also noticed the that the front does not look lowered at all! on the contrary! it looks rather higher than before??
see photos attached
jassem23 is offline
#3 Old 08-14-2016
Vehicle: 2000 (Facelift) SLK 200 Kompressor
Send a message via Skype™ to Skyflex
Hey there - I stumbled upon this thread because I am thinking of using the pro kit on my 2000 SLK. I in fact have got lowering springs but I don't know which ones the previous owner had installed. The end result though is that my car is definitely much lower than yours, though I must say that brings too many of it's own challenges - much harsher ride and also awful camber that requires extra kit to sort out. I take it that you have done an alignment after these were installed, and if yes, are your camber settings alright?
As to your questions - I understand that these cars use a "pads" system that go between the springs and the chassis to essentially determine the initial height. You could check to see if you have a thick pad and if necessary switch to thinner ones. As to the squeaks, are they from the suspension or elsewhere in the car. I do not think squeaks should occur, at least not from the suspension itself. But a stiffer setup (springs in this case) could potentially expose other loose or rubbing components. Just my 2 cents on the issue.
Skyflex is offline
#4 Old 08-14-2016
Vehicle: SLK55 AMG R171 (2007)
Other Toys: Corvette C6 Z06
I also once had squeaks after spring change. Resolution in that case was to lubricate the rubber pads.
Pyry1975 is offline
Eibach Pro-Kit Lowering Springs Durkatlon Performance MODS for the R171 46 01-08-2013 05:32 PM
Trying to find eibach pro kit lowering springs cutrufelli SLK Parts Wanted 1 12-19-2010 12:25 PM
