Best replacement front brake pads 2007 SLK280 - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By Maxcaddy
  • 1 Post By chtahoe
  • 1 Post By Gbarringer100
#1 Old 06-16-2016
Vehicle: 2007 Black SLK 280
Quoted: 48 Post(s)
I just hit 60K miles on my 07 SLK 280 and I like to be proactive with my little whip. I was thinking to change out the front pads..I suspect they are original so they are probably due now or soon to be changed. I found these which i know Brembo is a good line and this seems like a pretty sweet deal.
Mercedes W203 W209 R171 C230 CLK350 SLK300 Front Disc Brake Pad Brembo P50045N | eBay
DvintSLK is offline
#2 Old 06-16-2016
Vehicle: 2007 SLK280 RHD
Other Toys: Vmax 1200
Quoted: 18 Post(s)
Someone (Especially MB) will tell you that pads are matched to the discs and should not be altered as the braking efficency and wear would be dramatically reduced/affected. However, as MB would not have done any extensive trialling of different combinations, that would be very worse case, if at all.
Add that to the fact that many manufacturers if fact buy in their discs and pads from a part supplier, you could find that you are actually using say a EBC pad, marked up as an MB one.
What that all means is that you could actually improve your braking by using the Bembro pads, or it could stay the same, or it could be worse. So unless the savings were really worth it, or that you like to experiment, stick to the originals.
All that said I did put another make Pads on the Front of the wife's Grand Voyager, and it did signicantly improve the braking. What the wear rate is remains to be seen, but it has improved the braking.
desmodromic likes this.
Maxcaddy is offline
#3 Old 09-20-2016
chtahoe's Avatar
Vehicle: 2007 SLK280, Caspian Blue, Ash leather, AMG sport suspension, paddle Gtronic, chrome 5-spoke AMG
Other Toys: '75 BMW 2002Ti (euro spec), '99 ML320, '12 C300 4matic
RE: Best replacement brake pads
TO me and most of my competition buddies, Brake pads are personal choice as there are a wide variety of compounds and friction coefficients provided for general to specific uses. I recently changed out my front rotors and pads on my 07 280 w/AMG sport package, (MB oem which appear to be semi-metallic or aramid compound).
From past experience, I've found Brembo extremely reliable so I went with Brembo cross-drilled rotors and Hawk carbon ceramic HPS (High Performance Street) pads due to their good friction co., good initial bite, consistent pedal modulation/feel, rotor kindness, low dusting and good life-span. Other colleagues are fond of Akebono (also ceramic compound) but over the years I've become partial to Hawk, Ferodo and Brembo (all ceramic compounds). I've also had reasonable results with Porterfield, but found them to be quite aggressive and generated excessive heat during prolonged use (mtn roads, twisties, etc.).
As MAXCADDY stated, many private label brands are produced by a handful of manufacturers but the one's I've mentioned are not made by others and rebranded. It is recommended that when changing pads, you should change rotors as well because the friction material from the old pads is embedded in the surface of the rotors. You can scuff them in attempt to remove the residue but you can't really get it out and as a result the effectiveness of the new pad material is compromised. It is essential to change rotors when changing compounds or manufacturers.
Our cars are High End machines that deserve the best service we can provide them, so it makes sense to spring for the new rotors when changing to new pads. Just my Humble Opinion. Cheers.
Weather likes this.
chtahoe is offline
#4 Old 09-20-2016
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 102 Post(s)
Many have been happy with Akebono ceramic pads. They are very much dust free. Have on all four corners on mine and very happy and the wheel are always clean of brake dust.
AZ SLK likes this.
Gbarringer100 is offline
#5 Old 09-21-2016
Quoted: 48 Post(s)
Thanks for the info. Next question which I am not sure I got the answer is I have a standard non-performance 2007 SLK280 so would these work? Front and rears.
More Information for AKEBONO EUR779
More Information for AKEBONO EUR872
But there if I have a brake sensor these will not work? I dont think slk280's have brake sensors do they? I imagine the AMG 55 or something probably does. How can I tell if I do so I don't buy the wrong pads?
Thanks again
DvintSLK is offline
#6 Old 09-21-2016
Quoted: 102 Post(s)
You can get the Akebono from a Napa store and the brake pad wear sensor will still work, they should come with a new sensor. AS you will find in many posts the sensor is only on the right front wheel. Thy have pads for front and rear and yes they will work on your non-performance 280.
#7 Old 09-21-2016
chtahoe's Avatar
You can check application on tirerack.com. The Akebono's come with a new sensor (right front) and anit-vibration grease in the box with the pads, along with bedding instructions. You might want to do some research to discover the testing results of various pads and compounds to get the ones best suited to your needs. Most brand websites have info available you need to make an informed decision.
Happy motoring.
chtahoe is offline
Front Rotors and Pads 2012 SLK 250 gregorywilliams100 Tires, Wheels, Brakes & Suspension 7 01-26-2017 09:39 AM
Front brake pads job GusSLK SLK R170 General Discussion 14 08-30-2014 06:08 PM
SLK 350 replacement Brake pads & rotors SuzaFan Performance MODS for the R171 12 04-14-2014 06:20 PM
Front Brake Job Pricing ssteinjr SLK R171 General Discussion 11 10-03-2013 08:03 PM
