Will these fit? - Mercedes Benz SLK Forum
#1 Old 02-24-2013
nakulan7's Avatar
Vehicle: 08 SLK 55 AMG
Other Toys: Lexus IS250
Chats: 2
Quoted: 33 Post(s)
Will these fit?
http://www.alloywheelsdirect.net/mer...poke_wheel_213
I am not sure whether the rear offset will fit. IIRC fronts have 36 and rears have 30 offset.
Opinions welcome.
nakulan7 is offline
#2 Old 02-24-2013
Yes they will fit It just means your rears will be 4 mm closer in to the car which is minimal. The 8.5 x 18's I just took off mine have a 35 offset and even with 255 tyres on they were still far enough away from the shock absorber to get my fingers between the two. The only reason I went for spacers on the ten spokes is that they are only 7.5 and have an offset of 35.
Interestingly when I measured the width of the tyres on the 18 wheels the rear 255's measure 9.5 inches from wall to wall and the 225's measure 9 inches. Considering the rims are an inch wider doesnt mean the tyre will be.
You wouldnt have any problems with those wheels
JonB is offline
The Following 2 Users Say Thank You to JonB For This Useful Post:
#3 Old 02-24-2013
-1-
Don - Founding Member #4
-1-'s Avatar
Should fit OK. I believe the factory offset is 37mm front and 30mm rear. Four mm difference for the rear shouldn't be an issue.
-1- is offline
The Following User Says Thank You to -1- For This Useful Post:
#4 Old 02-24-2013
nakulan7's Avatar
Chats: 2
Quoted: 33 Post(s)
Thanks guys.
nakulan7 is offline
#5 Old 02-24-2013
Its 36 and 30 Its really to throw the rears out as they are wider, but 4 to 5 mm is nothing. The rears are less of a problem as you dont have a dirty great big caliper to avoid so if the wheels sit in a bit its not a problem as long as they dont get too close to the shocker
JonB is offline
#6 Old 02-24-2013
nakulan7's Avatar
Chats: 2
Quoted: 33 Post(s)
Were these wheels available as an option for R171? Any one remember? Thanks
nakulan7 is offline
#7 Old 02-24-2013
-1-
-1-'s Avatar
Jon's very knowledgable on wheels and offset. I have a MB accessories brochure. Interesting, the standard USA 10 spoke SLK wheels are 36mm front and 30mm rear. The 17" AMG series III wheels (five spoke) are 37mm front and 30mm rear. The SLK 55 18" multi spoke wheels are 37mm front and 30mm rear. Most R171 17" wheels are 36mm and 37mm front. Not many subjects as confusing as wheel offset. Offset also varies between wheel diameter (16"-19").
Best to check with wheel manufacturer and seller when purchasing aftermarket wheels. When in doubt, ask.
-1- is offline
#8 Old 02-24-2013
Unless they made them with a 36 and 30 offset then I would say no they wernt.
JonB is offline
#9 Old 02-24-2013
nakulan7's Avatar
Chats: 2
Quoted: 33 Post(s)
That could be an issue
nakulan7 is offline
#10 Old 02-24-2013
Offset is a complex subject and as far as I can figure out seems to be a combination of accommodating the design to avoid clashing with other components and styling of the car. It has a bearing on where the centreline of the wheel is in realation to the centreline of the hub. There is a formula on the net that tells you about tyre wear and scrub based on offset etc. I find this is the most informative chart if your looking at MB wheels and the models they fit
http://www.alloywheelsdirect.net/inf.../mercedes-benz
JonB is offline
#11 Old 02-24-2013
I think those wheels are designed for some of the C Class
But if you look at the section on SLK the AMG wheels have a 37 34 offset
JonB is offline
#12 Old 02-24-2013
Why would it be an issue ???
JonB is offline
#13 Old 02-24-2013
-1-
-1-'s Avatar
The brochure I'm referencing is the "Genuine Mercedes-Benz Accessories Wheels". Published 2005-2007? It shows a wheel for the R170, "Celaeno", 7 twin spoke wheel, which appears as the wheel in your link. The specs shows 7.5Jx17 ET 37 (B6 647 1821) and 8.5Jx17 ET 30 (B6 647 1822). Here's the LINK: http://www.ragtop.org/mbbrochures/2006/wheels.pdf . It's a 2006 version and a large PDF file. Give it time to load.
-1- is offline
#14 Old 02-24-2013
nakulan7's Avatar
Chats: 2
Quoted: 33 Post(s)
As the damned insurance will consider this a modification, wouldnt they?
nakulan7 is offline
#15 Old 02-24-2013
Ram I wouldnt worry about them. The offset is OK for AMG wheels for a 171 so they are going to fit. At least they are OEM. Must be thousands of cars on the roads with aftermarket alloys that arent causing any reported problems. My 18 fronts are aftermarket alloys and you were there when we all hit that pothole and there isnt a mark on my offside front rim
JonB is offline
#16 Old 02-24-2013
nakulan7's Avatar
Chats: 2
Quoted: 33 Post(s)
So that is a different part number to the one that i have posted.
nakulan7 is offline
#17 Old 02-24-2013
-1-
-1-'s Avatar
So that is a different part number to the one that i have posted. Do you have the brochure as a pdf to link here please?
Check post #13. Page 34 of the PDF.
-1- is offline
#18 Old 02-24-2013
Ram I doubt if the average insurance company or assessor has a clue what offset even means let alone what offset is specified. The only way you can tell is by taking a wheel off and looking in the back of it. As the spec for AMG wheels for the 171 is 36 34 I doubt they would have a clue. Plus its not really a modification as your not straying from OEM spec. If that were the case them fitting any none OEM part like brake pads or discs etc could be classed as a modification
JonB is offline
#19 Old 05-08-2013
Airmousam's Avatar
Vehicle: 1999 SLK gone....2007 CLK550 & 2010 E550, now looking for a SLK55
Other Toys: 2009 Suzuki M109R
Learning more about offsets than I could imagine
Airmousam is offline
Will My Wheels Fit R171 SLK? andrew c230k Tires, Wheels, Brakes & Suspension 2 07-13-2010 02:49 AM
OEM 17" needed for SLK 350 or similar fit s2kwik SLK Parts Wanted 0 03-23-2010 11:52 AM
