Goodyear Eagle F1 Asymmetric 2 - Mercedes Benz SLK Forum
  • 1 Post By etyu
  • 1 Post By slickBenzGirl
#1 Old 02-12-2013
Vehicle: Black SLK200K Sport Auto Tip 2009
Hi All,
I understand that the Goodyear Eagle F1 Asymmetric 2 have some sort of rim protecting the alloys from damage...is this true?
How effective is it and, equally important, how does it look?
Thanks,
A.
animajazz is offline
#2 Old 02-13-2013
IIRC, on the Asymmetric 1, there is a small circumferential ridge that is supposed to minimize minor incidents but these will not protect the rims if there is moderate force and the rubber flexes. They are of minor benefit IMHO. Best is to drive with care when parking or going around a curve to avoid the sidewalk cement (often called curb in the US).
slickBenzGirl likes this.
#3 Old 02-13-2013
You havent said what size rims your on 16's and 17's are less prone to kerbs as the tyres bulge a bit but 18's and bigger are much more prone to kerbing as the tyre walls are much smaller. Some makes do offer better rim protection than others Have a run through a few tyre sites
JonB is offline
The Following 2 Users Say Thank You to JonB For This Useful Post:
#4 Old 02-13-2013
slickBenzGirl's Avatar
Vehicle: 2012 SLK 250 totaled - current car: 2016 Dodge Challenger SRT392 in Plum Crazy Pearl Coat (purple)
Other Toys: my husband's 2016 Dodge Challenger SRT392 in GoMango (orange)
Quoted: 36 Post(s)
had my wheels replaced under warranty d/t imperfections in the clear coat - however these imperfections were nowhere near the curb rash that occurred on my wheels last summer so I got my rash taken care of at no additional cost
slickBenzGirl is offline
The Following User Says Thank You to slickBenzGirl For This Useful Post:
#5 Old 02-13-2013
You can get cream for a rash
JonB is offline
The Following User Says Thank You to JonB For This Useful Post:
#6 Old 02-13-2013
ZeroZero's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 257 Post(s)
Hi Animajazz
I have Goodyear Eagle F1 alround on our 55 & they have a curb/rim protection on them , The other thing with the rears i when up one size from 255 to 265 to give the rear rims abit of extra protection , on the 18" rims the 255 looks under size on the width & the 265 look just right & match the fronts offset from tire side wall to rim edge . Im on my 2rd set of F1's on the back the grip is good wet & dry .
Andy
P.s. check prices at mytire.co.uk
ZeroZero is offline
The Following User Says Thank You to ZeroZero For This Useful Post:
#7 Old 02-14-2013
Quoted: 36 Post(s)
I don't like opaque cream... it stains... it's better to use clear... there are a lot of applications out there available. Just have to find the right vendor...
living on the edge are you?
JonB likes this.
#8 Old 02-14-2013
Hi Animajazz
Andy
Whats the wear pattern like on those over width rears. My tyre bay told me that going up to 265 on low profiles will push the centre of the tyre up and cause it to wear faster than the rest of the tread width
JonB is offline
#9 Old 02-14-2013
ZeroZero's Avatar
Quoted: 257 Post(s)
Hi JonB
Well you could see the steel belt over most of the width of the tire when they fitted the new ones LOL . No the wear rate looked very even across the tire , If anything the centre may have alittle(& i mean very little) more wear than the outer but that could be down too much air in the tires & i got about 16k mile out of them which is about average for the rears on a 55 .
Andy
ZeroZero is offline
#10 Old 02-14-2013
According to my bloke the problem is that low profile walls dont bulge out over the rim so it tends to force the middle up. The more you go over the recommended tyre/rim width the worse it gets. 255 is about the max on 8.5 rims. I am planning on dropping back to 17's From talking to others and the way my car feels on 18's I think it will be better on 245/45 17's I dont think our roads are good enough for low profiles. Too many rough surfaces and pot holes
JonB is offline
#11 Old 02-14-2013
ZeroZero's Avatar
Quoted: 257 Post(s)
Hi JonB
Pot holes are a nightmare , But the road i use normally in the 55 are ok But i do not do alot of around town driving in the 55 more weekend drives out , so maybe im lucky that way , But i just could not put 17" rims on our car , But if you need a better quality ride then its the way to go . I will post a picture of my rears & i think you will see they look like they fit better than the 255's & do not look over wide .
Happy pot-hole hunting
Andy
ZeroZero is offline
#12 Old 02-14-2013
To be honest I think big rims and wide tyres are more about looks than handling or performance. Having been on the sheep chase with cars on 16's 17's and 18's I didnt notice any of them struggling during the spirited driving. I think I was the only one that said they had a sideways moment and that was due to a sharp left over the brow of a hill on a loose surface that I probably hit too fast, but lets be honest how often can you drive an SLK on the limits in the UK regardless of what wheels and tyres your running on. Hopefully if my plans work out this weekend I will be able to do a proper comparison if I get my hands on the 17's I am after
JonB is offline
#13 Old 02-16-2013
Quoted: 36 Post(s)
Those sheep must have had twin turbos on them!
#14 Old 02-21-2013
nakulan7's Avatar
Vehicle: 08 SLK 55 AMG
Other Toys: Lexus IS250
Chats: 2
Quoted: 33 Post(s)
"i got about 16k mile out of them which is about average for the rears on a 55 ."
Thats incredible. I seem to wear them out at less than 10k.
nakulan7 is offline
#15 Old 06-24-2013
1jess4u's Avatar
Vehicle: 06 SLK350
I just put a set of these on my 2006 R171 350, changed from the Bridgestone Protenza Run Flats I had on it from the original purchase ... had only changed the back prior to now 38000+ miles on the car now. Hoping to get better milage out of the Goodyears because they are rotatable unlike the directional ones I had on there. We'll see.
1jess4u is offline
New headlight mod with eagle eye problem kenji187 General Modifications R170 29 08-08-2012 11:18 PM
Anyone have goodyear f1 eagles? mark1simon SLK R171 General Discussion 7 07-15-2012 06:53 PM
GoodYear Asymmetric 2s nakulan7 Tires, Wheels, Brakes & Suspension 1 05-05-2011 04:35 PM
Eagle F1s nakulan7 Tires, Wheels, Brakes & Suspension 5 04-27-2010 05:33 PM
My Son became an Eagle Scout!!! SLKman Off Topic 19 03-09-2009 04:18 PM
