Kerbed Wheels - Mercedes Benz SLK Forum
 8Likes
  • 3 Post By Maxcaddy
  • 3 Post By dbgrn
  • 1 Post By Maxcaddy
#1 Old 05-05-2016
Vehicle: 2007 SLK280 RHD
Other Toys: Vmax 1200
Quoted: 18 Post(s)
Kerbed Wheels
Looking on Youtube at how others refurb their wheels, I spotted a video where someone bolted the wheel to a car, ran it in gear with the wheel off the ground, and using the wheel hub like the headstock of a lathe, and then cleaning up the burrs by going down through the grades of Emery.
Original thinking at its best, so I intend to give it a go with the car up on an Axle Stand. However if my SLK has an L.S.D. or some kind of traction control kicks in, it'll drive off the other side , okay I can get both wheels up in the air but I suspect it'll shake quite a bit, whereas 1 up and 3 wheels down is do-able and in fact a good way of testing for wheel bearing issues.
Maxcaddy is offline
#2 Old 05-05-2016
Vehicle: 2012 250 petrol black/red
Quoted: 309 Post(s)
Crikes - even just reading this fills me with fear. VERY dangerous thing to do. Think car rolling off axle stands, running over children, old people, your best mate, the love(s) in your life & those recently planted pansies.
oldmercman is offline
#3 Old 05-05-2016
Gromit3528's Avatar
Vehicle: Iridium silver 2007 SLK 280
Other Toys: V8 Landrover Discovery, Triumph 900 Trophy, BSA Rocket3, Honda Africa Twin XRV750
Quoted: 62 Post(s)
No!
What he said, never mind what it's going to do to your diff!!
These things are only ever supposed to move very slowly as it is not expected that your wheels will ever turn at very different speeds (for more than a second or two) there are often no real bearings on the gear spindles and it's just metal to metal contact. If you spin only one wheel for the length of time it takes to make good a wheel there will almost certainly be pieces of metal filings flying around in your diff and getting into the gears shortening its life dramatically if it doesn't seize while you are doing it.
Don't do it!
Gromit
You've got to be lucky sometimes!
Gromit3528 is offline
#4 Old 05-05-2016
Quoted: 549 Post(s)
Brilliant!
But I'm not even remotely considering doing this myself too....
Sneaky Pete is online now
#5 Old 05-07-2016
Quoted: 18 Post(s)
Yes very good, but I am going to use the axle as a Headstock, not a Wood turning Lathe
So no one knows if it has an LSD, or other built in traction control device ?
Maxcaddy is offline
#6 Old 05-07-2016
Gromit3528's Avatar
Quoted: 62 Post(s)
I'm pretty sure it doesn't have an LSD, they're a bit pricey for original equipment but it most probably does have traction control operated by the brakes system.
You'll soon know if you try and drive it with one rear wheel off the ground on a trolley jack. Good luck
Gromit
#7 Old 05-07-2016
CHELZEE's Avatar
Vehicle: 2012 SLK 55 AMG
Quoted: 130 Post(s)
Cool
Depends how bad the kerb rash is but you could use a Dremel, I did on a CLK I previously owned and it worked well....at least you're not going to take the chance of the car flying off any axle stands and wiping the neighbourhood out
CHELZEE is offline
#8 Old 05-08-2016
Quoted: 18 Post(s)
O good and gentle Townsfolk of the SLK forum, do not worry, there will be no SLK's flying around the streets, no deaths of your first born, no rivers of blood, or any other catastrophes of biblical proportions. A SLK with no wheel on one side, and a bare wheel spinning on the other, is not going very far. In years gone by using such an arrangement was typical for an enthusiastic Land Rover owner, and I would guess is still used in many parts of the world today.
The diff will always drive one wheel in preference to the other, and I’m expecting the braking effect I’m putting on with 120 grit won’t stop it from turning. I'll keep you all posted from the Hospital
DAVIETHESCAFF, CHELZEE and Col like this.
Maxcaddy is offline
#9 Old 05-08-2016
dbgrn's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 1035 Post(s)
If you really MUST do things this way, please set up a camera on a tripod to capture things... that way, if something enexpected does happen, at least you might be able to get Ł250 for it on You've Been Framed!
CHELZEE, Col and Pres like this.
- Dave
Mods:
(MB p/n A1718202075)
wind deflector
• Post-FL wing mirrors
• CF-effect interior trim
• AMG LED puddle lights
• Piecha DRLs
dbgrn is offline
#10 Old 05-28-2016
Quoted: 18 Post(s)
Okay, for those that are interested, this is where I've got to.........
I discarded the idea of running it on the Jacks idea simply because grovelling on the ground cleaning the wheels was too much like hard work. I did have a brainwave inasmuch as I tried running the wheels on the wife’s Chrysler Voyager, as the wheel arches were so much bigger and being FWD could be turned out to make it easier to get to, but although the pitch pattern fitted, the studs weren’t long enough for the thick flange Merc wheels. At that point it became all too difficult so I stopped.
So back to the drawing board and I cleaned up the wheels off the car. They were all cleaned up and sprayed, and then fitted with Uniroyal Rainsport tyres.
Need to do a few miles before I can comment on their performance .
Gromit3528 likes this.
Maxcaddy is offline
#11 Old 05-31-2016
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 540 Post(s)
Photos?
Interested to hear your opinion of RS3s.
Terminal is online now
#12 Old 06-04-2016
Quoted: 18 Post(s)
They look just like what I wanted them to noting that (A) I didn't want a harsher ride from an 18", (B) that their stronger construction suits the gastly potholed roads around here, (C) that I don't have fancy brakes whereby a bigger airgap showed off the Callipers, and (D) they were quite reasonably priced for what they were.
Re the RS3's I need to give them a few more miles, especially when its hissing down, to make a valid comment. However, my choice was from knowing the limitations of my driving, knowing that I'm not going on Trackdays or around the Nordschleife, knowing that the previous tyres, (and I suspect virtually any make tyre of those sizes) were going to be perfect in the dry for what I needed. Lastly to get a tyre that would help grip if I was trying some 'spirted driving' in the wet .
dbgrn likes this.
Maxcaddy is offline
R170, R171, UK - 4 Original Mercedes 17" alloy wheels fitted with part worn winter tyres. PenelopePitstop SLK Parts For Sale 2 11-23-2013 04:13 PM
FS: 17" Five Spoke AMG Wheels ponia003 SLK Parts For Sale 15 04-06-2012 08:10 PM
AMG/OZ 3-piece "classic" wheels on SLK 32 AMG SLK_32_AMG General Discussion 5 08-27-2009 05:24 AM
