Brake pads and rotors? - Mercedes Benz SLK Forum
  • 2 Post By Gromit3528
#1 Old 04-13-2016
Gordosoar's Avatar
Vehicle: 2001 SLK 320
Other Toys: 1100 Yamaha customized.
Quoted: 107 Post(s)
Hi friends,
I have a little dilemma and I would like some opinions from you guys.
Here's the deal,,, I bought a set of pads and now after looking at the ones on the car, I can see there is about 40% left on them, so now I have to decide if I should leave them on for another year or two, or change them now.
Also,, if I change the pads and leave the old rotors on will that be ok,, or should I change pads and rotors. Or just leave it all alone and go have a beer.
I really impressed with the stoping power of the set on the car right now.
What would you do?
Please respond.
G
Gordosoar is offline
#2 Old 04-13-2016
Gromit3528's Avatar
Vehicle: Iridium silver 2007 SLK 280
Other Toys: V8 Landrover Discovery, Triumph 900 Trophy, BSA Rocket3, Honda Africa Twin XRV750
Quoted: 62 Post(s)
Leave it all alone and go and have a beer!
When the pads are due to be changed you may need discs as well so change the set then.
Just my twopenneth.
Idiot101 and Gordosoar like this.
Gromit
You've got to be lucky sometimes!
Gromit3528 is offline
The Following User Says Thank You to Gromit3528 For This Useful Post:
#3 Old 04-13-2016
Idiot101's Avatar
Vehicle: 2004 slk32 amg
Other Toys: 69 GTX - Red!
Quoted: 265 Post(s)
If it ain't broke, and you are happy with the way it stops, leave it alone!
The Toy
Idiot101 is offline
The Following User Says Thank You to Idiot101 For This Useful Post:
#4 Old 04-13-2016
Vehicle: 2005 SLK 350
Other Toys: H20 V-Dubs, MK1s
Quoted: 411 Post(s)
At 40% I would leave them alone. Scotty Kilmer on you tube says you have to change the rotors because they wear and a lip or ridge fiorms around the edge and causes noise when new pads are installed. I don't know it that's the gospel or not, I'm sure some of these fine folks will have their say and I will be all ears (eyes).
Roxanne7169 is offline
#5 Old 04-13-2016
Gordosoar's Avatar
Quoted: 107 Post(s)
Yes I noticed a ridge on the rotor when I inspected them,, and thought to myself,
Is that going to come in contact with the new pads? I can't tell, but it's not worth the chance. Right now I'm leaning to not doing anything until they really need to be changed due to wear.
So now all I have to do is change the center link check the hubs for movement and put the new wheels and tires on. I have the new hubs already, if needed.
Thanks,
G
#6 Old 04-13-2016
Vehicle: 2005 Granite Gray SLK350, SmartTop, M2Pro Bluetooth, Reverse & Dash Cam, TPMS, Smartphone Mirroring
Quoted: 32 Post(s)
I recently changed all four pads to ceramic pads because of the break dust. I left the rotors on. No squeaks.
AjarnMichael is offline
The Following User Says Thank You to AjarnMichael For This Useful Post:
#7 Old 04-13-2016
Gordosoar's Avatar
Quoted: 107 Post(s)
Good to know.
The disks were smooth and didn't have any ridges on the surface, just the outer edge. But I'm still going to leave well enough alone.
I still may have to change the hubs if there is any movement in them after I replace the center link.
#8 Old 04-13-2016
Quoted: 411 Post(s)
I've done dozens of brake jobs but never MB. My rotors have the ridge and out of prudence I bought rotors too. I have actually toyed with the idea of taking the old rotors and putting the grinding wheel to them to take off that ridge. I know it sounds crude but hey I could save a few bucks. I don't have time to play with, or I would just slap the new pads on and see what I end up with.
#9 Old 04-13-2016
There are wear indicators for the brake pads (although I am not familiar with R170), change them only when the indicators say so.
As for the brake discs/rotors: only a proper measurement with calibrated caliper and comparing them to the specs from MB will tell you whether they need replacement.
Commonly it takes 2 brake pad changes before the discs have worn down enough for replacement.
#10 Old 04-14-2016
Quoted: 411 Post(s)
I bought new sensors also. I will use this oppurtunity to ask if when I change them, it will cause the system to throw a code. I wonder if I can disconnect the battery to avoid that, and I think perhaps the best answer is yes, to disconnect the battery anyway. After all it can't hurt.
#11 Old 04-14-2016
I only had the brake pads changed/replaced once (together with new brake calipers and brake discs) and that was when I "retrofitted" the brakes from the 2008 model year (when MB changed from 6-pot fronts to 4 pot on the SLK55) to the 2007 standard. The technician (and MB recommends this) always replace the brake sensors when pads are changed. I do not believe that doing so (replacing the brake sensors while replacing brake pads) will throw any error codes.
#12 Old 04-14-2016
Gordosoar's Avatar
Quoted: 107 Post(s)
Hi Roxie,
Won't disconnecting the battery throw a code also.?
I've watched a lot of videos about changing pads and never seen anyone disconnect the battery. Even on SLKs.
#13 Old 04-14-2016
Quoted: 411 Post(s)
[QUOTE=Gordosoar;2768977]
Hi Roxie,
I don't think so. I don't have any way to read codes but I'm ASSUMING that if my display reads "No Malfunctions" then no codes are stored. If you'd like, read the thread "Smart Top does not work with remote start". During that hell storm I had many error messages pop up suddenly and without good reason. Also during that time I disconnected the battery several times. Now things are back to 'normal', with "No Malfunctions". I have no idea whether the ECU has stored all those codes (errors) or not. I would think not.
#14 Old 04-14-2016
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
I think you will find that there is only one sensor and it is on the right front wheel. It is a simple sensor has when the pads wear down a metal tip on the sensor touches the rotor and make a ground and the dash light will turn on. When my pads wore down the light would only come on if I did a hard brake and then go out when I let off the brakes. No code.
Gbarringer100 is offline
#15 Old 04-14-2016
Quoted: 411 Post(s)
Well FOOEY I bought four of those bad boys. %}#? *+#??. IT!!
#16 Old 06-25-2019
Vehicle: 2016 SLK 300 White/BLK
Unbelievable the responses I am reading here....It doesnt matter whether is a Mercedes or a Toyota, the disc always gets a ridge around the area that doesnt come in contact with the pad. Years ago, you would put it on a lathe and cut it down. You would never put new pads on a car without turning the rotors. But nowaday, the rotors are made differently, with out a bearing/race seat to fit over the spindle. The rotors are easy to pop off and replace without messing with the wheel bearings. So it is cheaper as well to replace (standard types). No one will turn these new type of rotors either, not worth the time. Dont be cheap, just replace them. End of story.
worldavi is offline
Front Rotors and Pads 2012 SLK 250 gregorywilliams100 Tires, Wheels, Brakes & Suspension 7 01-26-2017 09:39 AM
New brake pads need new rotors???? Aranofly Tires, Wheels, Brakes & Suspension 24 04-15-2016 04:53 PM
Replace ROTORS and PADS 05 SLK mrdougie SLK R171 Class DIY 27 01-11-2015 10:49 AM
SLK 350 replacement Brake pads & rotors SuzaFan Performance MODS for the R171 12 04-14-2014 06:20 PM
New tires, brake pads, and lighter rotors on the way! MarkR171 AMGs 44 03-29-2013 12:57 AM
