Pirelli or Michelin ? - Mercedes Benz SLK Forum
  • 1 Post By etyu
  • 1 Post By rhartson
#1 Old 04-05-2016
Keith Robin's Avatar
Vehicle: Facelift 2008 SLK 280
Other Toys: Wife won't allow me to have a bike !
Quoted: 20 Post(s)
I will soon need to refit the summer tyres to my 2008 ('58) SLK 280 but notice that they have barely 3mm tread left.
Currently I'm running Pirelli P Zeros, 245/40 R17 (91W) rear
225/45 R17 (91W) front
Any ideas on replacing these with another brand, ie Michelin ?
I must add I've had no problems with the Pirellis and am only
looking for new ideas !
Keith Robin is offline
#2 Old 04-05-2016
AND MABEL
DAVIETHESCAFF's Avatar
Vehicle: 2008 AMG 55
Other Toys: "Red Mist" 2004 Battistini Hardtail Chopper
Quoted: 592 Post(s)
I've ran Continentals Contact 3s and 5s, Goodyear F1s, and am now using Michelin Pilot Sports. I can't fault them for grip, but I've noticed my petrol usage has gone up slightly. Small price to pay for the added confidence I have in the wet.
.........Happiness is not getting what you want, it's wanting what you have.........Daviethescaff
DAVIETHESCAFF is offline
The Following User Says Thank You to DAVIETHESCAFF For This Useful Post:
#3 Old 04-05-2016
I've had OEM Pirelli PZero when I got the car 9 years ago, but quickly changed them after one year to Goodyear Eagle F1 Asymmetrics. I've also tried Kumho.
Currently on Michelin Pilot SuperSport on all four corners.
I am most pleased with the Michelin Pilot SuperSports, performs better than the Goodyears and better wear. Not at all pleased with Pirelli's or Kumho's.
DAVIETHESCAFF likes this.
#4 Old 04-05-2016
Gordosoar's Avatar
Vehicle: 2001 SLK 320
Other Toys: 1100 Yamaha customized.
Quoted: 107 Post(s)
Bridgestone.
Or 17" check it out.
Gordosoar is offline
The Following User Says Thank You to Gordosoar For This Useful Post:
#5 Old 04-05-2016
Quoted: 2301 Post(s)
Fitted Michelin a short while ago and very happy with them.
Not used winter mode since. Always summer and not one traction control moment.
Can't speak for longevity, or MPG. More interested in grip.
Ł375 for all 4 and Ł50 love to shop vouchers. So Ł325 real cost.
#6 Old 04-05-2016
CHELZEE's Avatar
Vehicle: 2012 SLK 55 AMG
Quoted: 130 Post(s)
Currently I am keeping the ContiSport Contact 5P on mine but I will have to look at changing them for next year...been ok so far but like you I might look at another brand.
I am certainly no auto engineer but are the cars not set up with a certain tire / tyre at the point of manufacture and by changing the tires the handling etc take on different characteristics? Most of the MB's have Continentals, while some models have Bridgestone and even Michelin, so I assume the set up on each model is different from the other.
Does anyone know how certain tires are chosen? And does it affect set up if the type of tires are changed without making adjustments to the cars set up? It might be worth exploring if you are going to change brand.
CHELZEE is offline
The Following User Says Thank You to CHELZEE For This Useful Post:
#7 Old 04-05-2016
Vehicle: SLK 230 2002
Other Toys: No toys...just other cars!
Quoted: 43 Post(s)
I've just put a couple of Hankook Ventus Prime 2 on the back of my recently aquired 230. I have pirelle's on the front but these will be changed for Hankook when they wear down. I have a full set on my VW and rate them rather highly for a good value mid range tyre.
Biohazard is offline
The Following User Says Thank You to Biohazard For This Useful Post:
#8 Old 04-05-2016
rhartson's Avatar
Vehicle: 2013 SLK 55
Other Toys: Tesla Model X
Quoted: 19 Post(s)
tires
Originally Posted by Gordosoar View Post
Bridgestone.
Attachment 280857
I got S04 Potenzas....great tires on my 55
Gordosoar likes this.
"You may all got to hell, and I will go to Texas" Davy Crockett
rhartson is offline
The Following User Says Thank You to rhartson For This Useful Post:
#9 Old 04-05-2016
Vehicle: 2006 SLK350, 6 speed manual
Other Toys: Y2K Honda VFR800s (1 street, 1 track), 2013 Honda Civic Hybrid, 2010 Ford Escape, 2002 Volvo XC70
Quoted: 17 Post(s)
I recently installed the Michelin Pilot Sport A/S 3+ on all 4 corners and don't have any complaints in the 1k miles I've put on them. The previous tires on the car when I bought it were shot... down to the steel belts on the inside edge of the right front; so, I really don't have anything to compare to on this car. I've used Michelin tires on three other cars with great success.
BTW... any alignment tips on how to improve on the known inside front tire wear on these cars?
Rush2112 is offline
The Following User Says Thank You to Rush2112 For This Useful Post:
#10 Old 04-05-2016
Quoted: 17 Post(s)
PS: Love Pirelli tires on my bikes!!! That's all I put on my motorcycles...
Rush2112 is offline
#11 Old 04-06-2016
Quoted: 20 Post(s)
Thanks Davie.
Wet weather driving not too much of a problem as in winter I fit the Vredestein Quatracs.
In summer I only drive when weather is good (hence the low mileage)
Looks like it may be Michelins.
The recommended ones for the car are Primacy, but the Pilot Supersports look nicer.
Your reason for getting the latter ?
#12 Old 04-06-2016
Elmer Fudd's Avatar
Quoted: 190 Post(s)
I also have PS3's all round
the car feels really planted with them. I'm not sure they were available when our 320's were made, but Primacy's certainly were, as I fitted some to my C280 back then.
I had a 'moment' in the unexpected blizzard we had here a few weeks ago which caught me out. it also caught out nearly every other car and van and truck heading up that hill at the time. However, once I'd got going again thanks to a push from another motorist, they were fine. In normal conditions around here ( torrential rain) they are really confidence-inspiring.
Elmer Fudd is offline
The Following User Says Thank You to Elmer Fudd For This Useful Post:
Pirelli to Michelin tyres Delucas Tires, Wheels, Brakes & Suspension 34 01-21-2016 06:35 PM
Pirelli Calendar to feature first-ever plus-size model Berliner Heckflosse Off Topic 3 08-25-2014 04:26 PM
Pirelli The worst tyres in the world , Common Poor Tire Build on AMG Balearic Pete Tires, Wheels, Brakes & Suspension 37 05-27-2013 06:43 AM
New Michelin Tires .. jbanks15 Off Topic 8 01-23-2012 08:26 PM
Goodyear F1 asymmetrics fjgfreddi Tires, Wheels, Brakes & Suspension 11 12-10-2010 01:57 AM
