Wheel fitment - Mercedes Benz SLK Forum
  • 1 Post By Sneaky Pete
#1 Old 02-29-2016
Vampiretoad's Avatar
Vehicle: 1998 slk230
Wheel fitment
I have a set of 18" rims with 235/40/18 offset of 40mm i will have to get 20mm wheel adapters because they are 5x110. They are brand new. I bought them for another car that i no longer have. I really want to use them. Am i going to run into any problems?
Vampiretoad is offline
#2 Old 02-29-2016
Quoted: 6580 Post(s)
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
#3 Old 02-29-2016
Beekster's Avatar
Quoted: 164 Post(s)
Trouble? I would say yes. Mercedes-Benz uses a 5x112mm bolt circle, not 5x110. Spacers won't do anything about the mismatched bolt circle. Sell the wheels on to someone with the car you used to have, and get wheels made specifically for a Mercedes-Benz with hub-centric fit and proper bolt circle.
Beekster is offline
#4 Old 02-29-2016
Quoted: 549 Post(s)
Well there are special "spacers" that have a 5 x 112 pattern to fit them on the hub and an extra 5 x 110 threaded hole pattern on which you mount the rims. I guess the OP is referring to these. Obviously they need to be pretty thick to mount the rim save. I think the offset will be then way to low to mount the wheel without touching the fenders. So yes, I guess you will run into problems.
You could also consider socalled " floating bolts" like here http://spurverbreiterung.de/index.ph...ml&gw=2&kf=26&
With these you can overcome the few mm difference between a 5 x 112 and 5 x 110 pattern. The head of these bolts is not fixed to shaft but has a little play thus making it possible to mount a 5 x 110 rim on a 5 x 112 hub.
But besides that I wouldn't feel save with that kind of setup. My advice, like Beekster's: sell them and buy a set that fits your car.
Bill98 likes this.
Sneaky Pete is online now
#5 Old 04-06-2016
Vehicle: 99 slk230
Quoted: 9 Post(s)
Redrill the wheels to 5x112. 5x110 is the worst bolt pattern ever. Gm started using it on their smaller cars. And really only a handful of cars use it
Potentialslkowner is offline
Changing the steering wheel, or otherwise know as I like a challenge now and then… Seanhump General Modifications R171 127 03-01-2019 07:08 PM
Yet Another Wheel Fitment ddelcorejr Tires, Wheels, Brakes & Suspension 0 06-17-2015 07:46 PM
Yeah another dang wheel fitment Thread Chuckwick357 Tires, Wheels, Brakes & Suspension 7 01-24-2013 02:30 PM
