Offset difference & spacers? - Mercedes Benz SLK Forum
  • 1 Post By curro101
#1 Old 01-15-2016
cockneyrick's Avatar
Vehicle: SLK 230 03MY
Quoted: 34 Post(s)
Question Offset difference & spacers?
I have just fitted a set of double 5 spoke C Class rims to my 03 SLK.
I need to know what size spacers i should fit?
Here are the figures:
SLK 7.5J 225/45/17 ET 37 to C Class 7.5J 225/45/17 ET 47
SLK 8.5J 245/40/17 ET 30 to C Class 8.5J 245/40/17 ET 58
So the rims size & tyres are the same, just the offset has changed.
The fronts are in by 10% according to calculators.
The rears are in by 20%
I have fitted 5mm spacers to the rears because of fouling, but doesn't seem enough, even though they do not foul anymore.
The fronts are no spacers, but the hub centre protrudes more, so centre cap only just fits.
Any suggestions people?
cockneyrick is offline
#2 Old 01-15-2016
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
In theory you need 10mm spacers on the front and 25-28mm ones on the rear to be at the same point as the original wheels..
Col likes this.
curro101 is offline
#3 Old 01-15-2016
Quoted: 34 Post(s)
Well that theory must be way wrong, as 28mm spacers on back would be clearly unworkable!
#4 Old 01-15-2016
Col
Col's Avatar
Quoted: 738 Post(s)
Curro is correct. You need bolt on type at that thickness
- SmartTOP
- Chrome Bonnet Fins
- Front Camera (Kerb Cam)
- Dash Camera (Hard Wired)
- Gel Resin Number Plates
- Acrylic Wind Deflector
- Ambient Lighting
Col is online now
#5 Old 01-18-2016
Quoted: 34 Post(s)
So i have ordered a pair of 22mm Hubcentric bolt on spacers for the rears & 10mm hubcentric spacers for the front.
Hopefully that will sort it & get rid of the very mild shake @ 70mph even after balance.
#6 Old 01-18-2016
Elmer Fudd's Avatar
Quoted: 190 Post(s)
bolts rick, bolts
Make sure your wheel bolts will go through and grab enough thread. I have a nasty feeling they won't.
Elmer Fudd is offline
#7 Old 01-18-2016
Quoted: 34 Post(s)
If i am goingg back to stock gap then the OEM bolts will be fine, although the rears inc new bolts anyway.
#8 Old 01-18-2016
curro101's Avatar
Quoted: 528 Post(s)
You're back to stock gap, but the spacers between the wheel and the hub mean you'll need longer bolts, depends slightly on the thickness of the seat of the wheel, but basically whatever you put in spacer thickness, is the length you need to increase the orignal bolts by...
curro101 is offline
#9 Old 01-19-2016
Quoted: 34 Post(s)
Original bolts could not be used "as is" cos they passed thru too much & fouled the caliper.
If i move the rim out 22mm (6 under stock) then the original bolts will work fine (6mm more turn thread).
As for fronts, they work fine with the 5mm universal spacers, so going back to stock 10mm out means the bolts again should be fine.
I cannot see the logic of your argument?
Max difference between front and rear Sneaky Pete Tires, Wheels, Brakes & Suspension 0 08-22-2014 05:31 PM
Wheel Offset Calculator jbanks15 Tires, Wheels, Brakes & Suspension 0 07-15-2014 09:51 PM
dumb questions 30 offset vs 58 offset boomie Tires, Wheels, Brakes & Suspension 5 02-02-2011 11:29 PM
Wheel spacers help jameslk55 SLK R171 General Discussion 1 04-13-2010 01:46 AM
Spacers void warranty? mjia Tires, Wheels, Brakes & Suspension 4 01-01-2010 06:47 AM
