Christmas SLK55 Brake Job - Mercedes Benz SLK Forum
 57Likes
#1 Old 12-07-2015
Col
Col's Avatar
Quoted: 739 Post(s)
So I've known for a while that my front brake rotors are nearing the end of their life and have been considering various routes for replacement.
In the end I decided to go with the stock Brembo 2 piece discs which I got slightly cheaper than from the main dealers by buying from Eurocarparts for 390 per disc, gulp!
Pads wise I decided to try EBC Redstuff ceramic pads which on paper offer slightly better performance over OEM pads with less dust and are apparently kinder to the rotors.
The discs arrived today and look great! I am going to fit them just as soon as I can which will most likely be over the Xmas break, or should that be "brake"
Although I'm an experienced DIYer this will be my first brake job, so any tips welcomed. I will post pics and details of my project here when I've got round to fitting them.
Here are the new discs to whet your appetite, oooh shiny shiny!
Stinger, Seanhump, Trev5 and 5 others like this.
- SmartTOP
- Chrome Bonnet Fins
- Front Camera (Kerb Cam)
- Dash Camera (Hard Wired)
- Gel Resin Number Plates
- Acrylic Wind Deflector
- Ambient Lighting
Col is offline
#2 Old 12-07-2015
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 540 Post(s)
Did you get the pads at Euro too? How much? I might throw a set in mine over the holiday if it's dry and mild. In any case, will be good to have them 'in hand'. Did you buy new sensors too?
FWIW, MBUK quoted me 242.00 for front pads - yeah right....
BTW, consider painting your new disc mounting bell/bolts with clear heat resistant lacquer before fitting them. For 800, might as well keep them looking nice
Col likes this.
Terminal is online now
The Following User Says Thank You to Terminal For This Useful Post:
#3 Old 12-07-2015
Col
Col's Avatar
Quoted: 739 Post(s)
Hi, I bought my pads from EBCbrakesdirect.com
Red Stuff DP31591C 105.13 - this is what I went for.
I also considered these:
Yellow Stuff DP41591R 115.30
From what I've heard MB aren't too bad for the sensors. Going to get them from a dealer I think. Just waiting to check my rear discs before I decide to change them or not before I order what I need.
Have bought new rear pads too
Red Stuff DP31490C 84.98 is what I bought
Yellow Stuff DP41490R 92.76 also available.
Thanks for the lacquer tip!
55russamg likes this.
- SmartTOP
- Ambient Lighting
Col is offline
#4 Old 12-07-2015
Vehicle: 05 55
Quoted: 540 Post(s)
That's odd, from the EBC website, when I enter my reg, they offer me either 345 or 360 mm discs (as usual...), but when it comes to pads, just the yelowstuff part number you mention. Entering the Redstuff part number you supplied, brings up this:
Part Number Search For: DP31591C
We have located DP31591C for you, which can be found by clicking on the Redstuff tab. The part will fit all of the vehicles listed below. For more detail on the position it fits on your vehicle and any advice notes their may be, and further parts, select your vehicle from the list
Pad And Shoe
Make Model Engine BHP Valve Year
MASERATI Quattroporte 4.7 2008-2012 VIEW
MASERATI GRANCABRIO 4.7 2010- VIEW
MASERATI Gran Turismo 4.7 2008- VIEW
FERRARI 599 6.0 2006-2008
Don't you just love automotive web vendors?....
#5 Old 12-07-2015
Col
Col's Avatar
Quoted: 739 Post(s)
Pad And Shoe
Yes no 55 listed for Redstuff. I've seen them on another members car though and found them in the full EBC catalogue listed as fitting our car. Dimensionally they are the same as the Yellowstuff ones just different compound. Guess it's an error with their web configurator!
Terminal likes this.
- SmartTOP
- Ambient Lighting
Col is offline
#6 Old 12-07-2015
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
It's not too bad a job to swap the fronts out (I've not done the rears yet so can't comment there)
Nothing odd or unusual, but the bolts that hold the calipers on are REALLY tight!!
Col likes this.
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#7 Old 12-07-2015
Col
Col's Avatar
Quoted: 739 Post(s)
Figured they would be so bought a breaker bar
Did the retaining screws and the discs themselves come off relatively easy for you? I am considering ordering new retaining screws just in case I knacker one taking them out!
- SmartTOP
- Ambient Lighting
Col is offline
#8 Old 12-08-2015
Seanhump's Avatar
Quoted: 424 Post(s)
Yes - they came straight out, as did the caliper pins etc etc ...
Sean
Mods so far...
Seanhump is offline
#9 Old 12-08-2015
Vehicle: R172 SLK 250d 2015
Defo worth applying some heat resistant finish to the hub and bolts to keep them looking good☺ I expect when you have done the job you will be forever looking at the wheels every time you get in or out 😆 look forward to seeing pictures of the work in progress.
mermoto is offline
#10 Old 12-11-2015
Quoted: 257 Post(s)
Hi All
The front disks & pads are an easy install , Front callipers require hex male socket about a 10 or 12mm , Rears I hear you need to remove the roll bar to get to one bolt , So my indy did the rears for me .
Andy
ZeroZero is offline
The Following User Says Thank You to ZeroZero For This Useful Post:
#11 Old 12-12-2015
Col
Col's Avatar
Quoted: 739 Post(s)
Hi All
Andy
Thanks Andy, another source suggested to me that an 18mm socket (bit of a bogey size) was required for the front caliper bolts? I've bought one of those as most socket sets, mine included jump from 17mm to 19mm.
Good information about the rear caliper mind you I'm hoping to get to that bolt (E14 Torx) by removing the arb drop link rather than the arb itself. I'm still not convinced I need rear discs yet but need to do a closer inspection on them before I decide. Might end up just changing the pads this time round which should be a doddle wth the caliper on the car.
- SmartTOP
- Ambient Lighting
Col is offline
#12 Old 12-12-2015
Quoted: 257 Post(s)
Hi All
@ Col when I did my rear disks I was shocked the state of the inner faces on both rear disks they had circle grooves right across the face & you can only see this with taking the pad out or the calliper off . The Front calliper bolts are Cap-head bolts ie hex hole/female in the top of the bolt & not a normal bolt head ie outer hex shape .
Andy
ZeroZero is offline
#13 Old 12-12-2015
Col
Col's Avatar
Quoted: 739 Post(s)
Thanks Andy. Sounds like I've had some duff information! Did you have half inch or 3/8 drive socket with male hex key from a std set that fit then, or did you manage with an Allen key? I can feel another tool purchase coming on!
I'll hopefully have time tomorrow morning to get a better look at my rear discs.
- SmartTOP
- Ambient Lighting
Col is offline
#14 Old 12-12-2015
Quoted: 257 Post(s)
Hi All
@Col If the cap head bolt requires a 10mm allen key then yes I used a 1/2"drive male socket ,If not I used an Allen key (its was a few months ago) , As I only have the 10mm socket in my box .
Andy
ZeroZero is offline
#15 Old 12-12-2015
55russamg's Avatar
Quoted: 684 Post(s)
Question
Col if you require a Torq Wrench let me know NM, I may have one in the Garage.
Col likes this.
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is online now
#16 Old 12-12-2015
Col
Col's Avatar
Quoted: 739 Post(s)
Thanks Russ I have a torque wrench. Ordered some male hex key sockets now too. Looking forward to getting my hands dirty while I'm off over Crimbo!
- SmartTOP
- Ambient Lighting
Col is offline
#17 Old 12-13-2015
Col
Col's Avatar
Quoted: 739 Post(s)
Did a reccie this morning to check out a few bits and pieces. This involved jacking the front of car up and removing one of the wheels.
I wanted to check a couple of things out before I do the full job.
Wanted to try out my jacking strategy which involved the OEM jack a trolley jack and some axle stands that I modified a while back to fit in the sill jacking points.
Used the OE jack to get the car high enough to get the wheel off and gain access to the central jacking point with the trolley jack. Jacking centrally then enabled getting the modified axle stands into the sill jacking points.
Got some motor home levelling ramps on the way that allow me to get the car high enough to get straight to the central jack point next time round. Good little tip I found on another thread.
Solved the mystery of the recommended 18mm socket. Turns out that is for the hex headed bolts that hold the caliper mounting bracket to the hub carrier. Confirmed 10mm Allen key or male hex socket for the actual caphead bolts for the caliper.
Rear discs although ok on thickness appear to have worn unevenly and are lipped badly on the inside face. Going to order these from the U.S. me thinks!
A couple of bits left to get/arrive and I'm all set. 😀
Seanhump, dbgrn and 55russamg like this.
- SmartTOP
- Ambient Lighting
Col is offline
#18 Old 12-13-2015
55russamg's Avatar
Quoted: 684 Post(s)
Planning makes all the difference.
Have you organised a tray for your Christmas Dinner?
Col and dbgrn like this.
Cheers Russ
SmartTop
#19 Old 12-20-2015
Col
Col's Avatar
Quoted: 739 Post(s)
@Terminal as requested here are some pics of the Redstuff pads. If you need dimensions there are diagrams on EBCbrakesdirect's website.
I now have most of the bits I need for my brake job rear discs should be arriving this week.
55russamg and Terminal like this.
- SmartTOP
- Ambient Lighting
Col is offline
#20 Old 12-22-2015
Vehicle: 05 55
Quoted: 540 Post(s)
^^ That's useful. MBUK, at my free winter check, declared my front pads 25%, discs 'fine' and rear pads 60%, discs excellent. So I've probably got about 2k miles worth of leeway with my fronts. Oil change planned for Sunday...
BTW, Euro will sell at set of Eicher front pads for < 8 free delivered. I'm almost that tight, but not quite that brave...
DIY Brake job dsb SLK R171 Class DIY 39 01-17-2015 06:01 PM
Front Brake Job Pricing ssteinjr SLK R171 General Discussion 11 10-03-2013 08:03 PM
SLK55 front brake rotor mileage pre 2008 imducati AMGs 15 01-11-2013 03:02 AM
Mushy brake pedal SLK55 AMG MarconiQ AMGs 24 08-28-2009 05:53 AM
SLK55 Brake Job near Irvine, CA sumdumfoo United States 0 04-29-2009 06:58 AM
