Front tire wear - Mercedes Benz SLK Forum
 6Likes
  • 1 Post By jbanks15
  • 1 Post By etyu
  • 1 Post By Clareymark
#1 Old 12-06-2015
Vehicle: 07 SLK55, green filters, eurocharged headers, eurocharged tune, secondary cat delete, x-pipe
Quoted: 15 Post(s)
Front tire wear
Hi. I have a 2007 SLK 55 with 38,000 miles. I purchased it a year ago with 32,000 miles. It has Michelin Pilot Sport tires in original size (front and rear). I don't know how many miles are on the front tires but they still have about 1/16" of tread above the wear indicators. Yesterday while changing the oil I noticed that the insides of the front tires are severely worn (tire cord showing in one place). The car drives great, does anyone know if this is typical?
The Carfax report shows several alignments a few years ago.
Clareymark is offline
#2 Old 12-06-2015
Quoted: 6570 Post(s)
typical if you need a 4 wheel alignment! mine had that and needed one real bad. MB tests em free when you go in for service. of course they want your money. complete test - toe, camber and caster and whatever else
http://www.tirerack.com/tires/tirete...e.jsp?techid=4
#3 Old 12-06-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
Such wear is not normal if car is exactly to manufacturer's specs. Causes:
1. Poor alignment.
2. If the tread is 'feathered' as well to the outside, then alignment and suspension bushings.
3. If you have spacers, the camber is accentuated and inner wear is - to an extent - normal. But still check alignment.
Hal Adams is offline
#4 Old 12-06-2015
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Having the same problem on my 06...on relatively new Yokos... I'll have it aligned after spring thaw (and hope to swap them right to left; cheap pilot/scot/irish).
FUN 4 2
Der Flieger is offline
#5 Old 12-06-2015
Not unheard of, and not necessarily related to alignment issues. It's about the OEM camber.
There is an old thread on this IIRC: https://www.slkworld.com/tires-wheels...ide-walls.html
#6 Old 12-07-2015
Quoted: 15 Post(s)
Thanks to all for the very timely replies! The attachment from etyu was especially helpful. So... If the root of the problem is the negative camber specification from AMG I would expect all SLK 55 owners to have this problem, but apparently some owners (J Banks) have resolved it with a re-alignment. Did you request a reduction in negative camber?
#7 Old 12-07-2015
me? nope. it passed the test after the alignment and I got to buy 2 new front tires.
ichris93 likes this.
#8 Old 12-07-2015
The lesson I learned here is to check not only the tread wear on the tyres but also visually inspect the inner and outer side walls for damage, front and rear tyres, probably at least once a month.
Moreover, I check the tyre pressure for proper inflation every week or at least fortnightly.
This is important not only for safety but helps get the best mpg.
#9 Old 12-07-2015
Quoted: 15 Post(s)
So are you now getting even tread wear? I am meticulous with maintaining proper tire pressure. However I suspect that the wear on the inside of the tires may have been substantial prior to my purchase of the car. Maybe the previous owner did not watch the tire pressure!
#10 Old 12-07-2015
me? yes!......
(use the quote button under anyone's or my post so i/we know who you are directing the questions to)
I also, like Dr Eddy, check my pressure weekly.
#11 Old 12-07-2015
Yes.
I think my fault was trying to "stretch" the interval between tyre change on the fronts as they were the OEM Pirellis. I haven't noticed the same thing reoccur with other tyre manufacturers I've used since: Yokohama S. Drive, Goodyear F1 Aymmetrics, and Michelin Pilot Super Sport.
I change the tyres when they are around 3/32 in tread wear and so far I like the Michelin Pilot Super Sports the best, in terms of tread life, noise and handling. (personal preference, others may disagree)
#12 Old 12-07-2015
me? yes!......
You should check both tyre and blood pressure weekly and keep a log of the numbers
#13 Old 12-07-2015
Quoted: 15 Post(s)
me? yes!......
I'm learning! Yes, I was asking you if your problem was eliminated after the alignment. Thanks again for all of your help / suggestions.
#14 Old 12-07-2015
my problem was cord showing through tire
that was the 1st wheel alignment
I needed another one the following year. But my last name is Banks so I can handle it. No bad tires this time.
#15 Old 12-08-2015
ichris93's Avatar
Quoted: 89 Post(s)
me? yes!......
Come on, you don't do it daily?
ichris93 is offline
#16 Old 12-08-2015
daily? it says weekly
i detail daily among other things
#17 Old 12-08-2015
Quoted: 15 Post(s)
I may need to change my name!
#18 Old 12-10-2015
Quoted: 15 Post(s)
I'm getting a 4 wheel alignment December 22. I'm going to show them the tires and see what they say.
Altitude and tire pressure Just1MoreDave Tires, Wheels, Brakes & Suspension 9 06-26-2015 11:32 PM
Rear Tire Wear in Wintry Conditions CapitolSLK General Discussion 13 07-07-2012 09:10 PM
Excessive Tire Wear SLK320 MBSLKLVR New Members Introduce Yourself Here 13 07-26-2010 06:34 PM
Tire tread wear issues on SLK 350 (all?) honkingAntelope Tires, Wheels, Brakes & Suspension 26 03-14-2010 08:03 PM
