Wheel Nuts - Mercedes Benz SLK Forum
 22Likes
#1 Old 12-04-2015
Chrissy Landar's Avatar
Vehicle: Mercedes SLK 350 R171. 2010.
Other Toys: Honda 16" lawnmower.
Quoted: 77 Post(s)
Wheel Nuts
Hi, I`ve read a few time in these forums that rusty wheel nuts are a problem, does anyone know of an aftermarket wheel nut that is made of stainless steel.
That would surely be the answer rather that my first fix of painting them.
55russamg and Avel Du like this.
Chrissy Landar is offline
#2 Old 12-04-2015
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
I've painted mine a couple of times, and the rust comes back..
I'm trialing a wheel with the nuts sanded back to bare metal and covered with clear coat to see how that goes ..
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#3 Old 12-04-2015
Quoted: 77 Post(s)
Stainless Steel Wheel Nuts
Just found these on eBay
High Chrome Stainless Steel Wheel Nut Covers 17mm for MERCEDES SL SLK SLR | eBay
#4 Old 12-04-2015
Quoted: 77 Post(s)
Wheel nuts
If the chrome finish covers aren`t suitable then also found these on eBay.
16 x ALLOY WHEEL BOLTS FOR MERCEDES BENZ SLK (R170) 1996-2004 LUG NUT [1K] | eBay
#5 Old 12-04-2015
Quoted: 6580 Post(s)
see my album
$20 from Amazon
Avel Du and Chrissy Landar like this.
#6 Old 12-04-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
********DO NOT UNDER ANY CIRCUMSTANCES EVER, EVER USE STAINLESS WHEEL LUGS. NEVER!*********
Stainless does not have the properties required to deliver the tensile strength that wheel lugs require.
Hal Adams is offline
The Following 2 Users Say Thank You to Hal Adams For This Useful Post:
#7 Old 12-04-2015
WarwickThumbNT's Avatar
Vehicle: 2005 SLK200 Obsidian Black Beige leather, Vavona wood. Airscarf, Comand, heated seats...Smart top :)
Other Toys: Various basses including Warwick, Fender and Electric Upright Bass
Quoted: 159 Post(s)
WarwickThumbNT is offline
#8 Old 12-04-2015
raymond.harper's Avatar
Vehicle: SLK 230 2001
Quoted: 21 Post(s)
The ones on Ebay have poor feedback with many negative complaints about the quality. On such an important part for the car use only factory lug bolts not cheap aftermarket bolts. You can fit covers over the lugs but these can be a problem when it comes to taking them off. Anway I suggest that you use a copper grease product on the threads to stop rust and also on those stainless steel covers. I also would not use stainlesss steel bolts on a wheel.
Chrissy Landar likes this.
raymond.harper is offline
#9 Old 12-04-2015
Elmer Fudd's Avatar
Quoted: 190 Post(s)
just dont go hog-wild with the auto-lard
A little dab on the thread at end that goes into the hub first is enough. On no account grease the rounded shoulder of the bolt, or the rounded seat in the wheel. That's where they grip each other, and greasing there could lead to you losing more than a wheel.....
etyu and Chrissy Landar like this.
Elmer Fudd is offline
#10 Old 12-04-2015
Quoted: 549 Post(s)
True that.
On the head of the bolt is usualy a marking that denominates the strength of the bolt. For metric bolts it is in the form xx.y, xx gives the tensile strenght of the bolt and y the yield strenght. You need at least 10.9 or even better 12.9 class bolts meaning you can fasten with the required torque of 110 Nm.
Like Hal said stainless steel bolts don't even come close, meaning you could overstress them. If you're lucky they break while fastening them, if you're unlucky while you're cruising........
Sneaky Pete is online now
#11 Old 12-04-2015
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
Like has been said, Stainless steel is made to prevent rust, but the things that you give up in gaining that property are machinability and strength. Thus we have to "fool Mother Nature" to achieve our ends. It is altogether possible that someone has solved this problem (Clad bolt heads, high tensile stainless, etc.) but I am not aware of it. I just have ugly rusty bolts because I haven't taken the time to use one of the solutions described above.
Gene
REB_TN_06 is offline
#12 Old 12-04-2015
55russamg's Avatar
Quoted: 684 Post(s)
Cool
Hammerite Smooth Metal Paint
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is online now
#13 Old 12-05-2015
Vehicle: SLK55 AMG R171 (2007)
Other Toys: Corvette C6 Z06
I wish Santa would bring me these :
Mercedes Titanium Lug Bolt Set - TiKORE INDUSTRIES
Pyry1975 is offline
#14 Old 01-16-2016
cockneyrick's Avatar
Vehicle: SLK 230 03MY
Quoted: 34 Post(s)
And Alloy bpolts are an absolute disaster waiting to happen.
Maybe Marine grade Stainless might work, but i doubt anyone makes em?
cockneyrick is offline
#15 Old 01-18-2016
Quoted: 271 Post(s)
For heavens sake, I spelt it out pretty clearly above - DO NOT USE STAINLESS STEEL. Whatever grade it is! I sincerely hope no one does make them, but in this day of fakes and cons, I bet someone does - to appeal to the bling market.
#16 Old 01-19-2016
Quoted: 34 Post(s)
I have used Marine grade bolts/nuts all over both my motorcycles. One of which is a Drag bike. Never had a problem AT ALL & i doubt very much a car can put the same stresses on the part like my bikes can!
#17 Old 01-20-2016
Quoted: 549 Post(s)
You're comparing apples and oranges. Unless you've completely modified the rear suspension of your Suzuki's they have a double-sided suspension. The way the wheel is attached to the bike is completely different from the way a wheel is attached to a car. They are both round but that's where the comparison ends.
For a car clamping force is essential to safely mount a wheel. Like it has been said before, to achieve enough clamping force a bolt has to have e minimum yield and tension strenght. Stainless steel bolts just don't have that. Afaik the only difference between marin grade and ordinary grade is the resistance to corrosion. Like Hal said, DO NOT USE STAINLESS STEEL.
If not for your own good then for that of your fellow road users.
#18 Old 01-21-2016
Quoted: 34 Post(s)
Both bikes have been heavily modified, Inc 6" over swingarm. The stress factor of the bolts is nearly as good as stock.
I do get what you are saying, but there are Marine grades up to the job.
But as said, i doubt anyone actually makes them?
#19 Old 01-21-2016
Quoted: 271 Post(s)
In actual fact, 'marine grade' stainless steel, despite how it might sound is weaker than industrial stainless due to the increased amount of nickel in the alloy. But hey-ho, if you are happy using stainless where there are sheer forces, then go for it!
#20 Old 01-21-2016
Quoted: 549 Post(s)
I respectfully disagree with you on the bolt issue, but the bikes look great!!
As you already guessed mine's more of the classic English style. Meriden look Triumph from Hinckley. Complete stock.
Changing the steering wheel, or otherwise know as I like a challenge now and then… Seanhump General Modifications R171 127 03-01-2019 07:08 PM
Chosing New Wheel Rims. Woolly Tires, Wheels, Brakes & Suspension 16 04-30-2017 06:31 PM
calipers and wheel nuts Rextter SLK R171 Class DIY 2 09-22-2011 03:40 PM
