Inside frt. Tire wear - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By nakulan7
  • 1 Post By AZ_JC
  • 1 Post By AZ_JC
#1 Old 05-05-2012
Vehicle: FIREMIST,2006,350,SLK,19,245 MILES: FRT. INSIDE EDGE OF TIRES ARE WORN/CUPPING & OUTSIDE EDGE OK
Other Toys: 2 CARS
My 17,500 mile slk 350, 2006, frt. Tires are worn and cupping on the inside edges. The out side edges show normal wear.
I have been told that this is common for mercedes and bmw as the factory aligns the frt wheeles to "tip" in at the top so that as deiven at hi speeds on the auto bohn the wheels become verticle due to "airlift" at hi speeds, thus the wheeles are verticle and both tire edges wear even at the hi speeds.
Could this be ppossible and/or true............or even reasonalbe???
THANK YOU,
DEEDUBYA MCMILLAN
[email protected]
DEEDUBYA MCMILLAN is offline
#2 Old 05-05-2012
nakulan7's Avatar
Vehicle: 08 SLK 55 AMG
Other Toys: Lexus IS250
Chats: 2
Quoted: 33 Post(s)
The tyres do have a tendency to wear the insides more if you drive them normally.
DEEDUBYA MCMILLAN likes this.
nakulan7 is offline
#3 Old 05-05-2012
Other Toys: Reynard SF88
Toe out (tires pointed out) will cause inside tire wear along with too much negative camber (top tire in). I've not checked the specifications but would suspect the car should have a bit of toe in (stability) along with a bit of negative camber (grip). Race / track car... toe out for response & turn in, more negative camber for better grip.
AZ_JC is offline
#4 Old 05-05-2012
Chats: 2
Quoted: 13 Post(s)
Just for information, are you stating the tires have 17,500 miles, or the SLK has 17,500 miles?
Anyway, get the car to an alignment shop(either an MB dealer or an alignment shop) and have the front end checked-out, for wear and alignment specs.
Think outside the box!
Galo is offline
#5 Old 05-06-2012
It's the way performance cars are (from the suspension geometry). Here's link to my experience: https://www.slkworld.com/tires-wheels...ide-walls.html
#6 Old 05-06-2012
THANK YOU,
DEEDUBYA MCMILLAN
[email protected]
That I've never heard.... If anything you are looking for down force at speed which would compress the suspension and give (in most cases) more negative camber. Red Bull F1 ran into a bit of trouble last season running too much negative camber with the purpose being that less of the tire is in contact with the road, giving less resistance / drag from the tire - and they run a lot of downforce!
Unless an extreme I'd say negative camber would not cause a tire wear issue, not enough toe in would be more common. Other issues would be suspension components such as bushings being worn.
Negative camber is there to evenly load the tire from side to side during cornering, too little would wear the outside, too much (and it would have to be extreme) would wear the inner edge. On older MB & BMW's with semi-trailing arms the rear tires would quite often show inner wear, due to the negative camber produced during acceleration as the rear end squatted down.
Simple for a good tire store to give you a printout of the alignment results along with the recommend settings.
AZ_JC is offline
Tire wear and camber bobl General Discussion 7 02-24-2012 04:31 PM
Tire wear smcdammitt General Discussion 3 06-23-2011 02:06 AM
Front Tire Wear Norm rosros SLK R171 General Discussion 10 05-02-2011 08:17 AM
Letters and Numbers QSHIP Tires, Wheels, Brakes & Suspension 2 10-30-2010 05:04 AM
Tire tread wear issues on SLK 350 (all?) honkingAntelope Tires, Wheels, Brakes & Suspension 26 03-14-2010 08:03 PM
