New brake pads need new rotors???? - Mercedes Benz SLK Forum
 6Likes
#1 Old 04-30-2012
Vehicle: 2012 SLK 350
Question New brake pads need new rotors????
Hello,
I want to change my break pads to minimize dust. Have read most of the threads about it and i decided to go with Porterfield R4S Pads.
I called the shop today to ask for a quote to install them and they told me i need to get new rotors as well if i am changing the pads.
Is this true?
Aranofly is offline
#2 Old 04-30-2012
No.
They should do the measurements first on the rotors with a caliper and see if it is within the specs or not, then the mechanic can recommend if a rotor/disc change is needed or not. Do a search on the different values of the brake disc as measured by caliper (in mm) for the different R171 models (do a search on threads started by Easty).
#3 Old 04-30-2012
Here's the link: https://www.slkworld.com/80276-post2.html
The Following 2 Users Say Thank You to etyu For This Useful Post:
#4 Old 05-01-2012
Vehicle: 07SLK350
If your mileages close to 40K MB recommend to change pads and rotors.most probably you just need the front axle only. Also you may as well change your brake fluid to get a fresh start.
QSHIP is offline
#5 Old 05-01-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
AFAIK Mercedes does not recommend a change of rotors at any specific mileage. Rotors are changed when they are near their minimum spec or are warped, overheated, etc. That can vary widely in mileage from driver to driver. Measure them and make your decision. Brake (not break) fluid should be done every two years regardless of any brake work that you do or don't do.
Len
Len
1999 E300D 215,000 miles
sokoloff is offline
#6 Old 05-02-2012
Thank for the replies guys.
My car only has 17,000 miles so i dont believe it needs new rotors. -- What i understood from the guy at Meineke is that if i was going to put new ceramic pads, i needed to put new rotors as well since they wear differently???
Just want to make sure i'll be ok just changing the pads
Aranofly is offline
#7 Old 05-02-2012
IIRC, Arno (PropDr) has Porterfields on his 55 and I don't recall him mentioning a change of the rotors/discs.
#8 Old 05-02-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
Never heard of that before - rotors either wear evenly, or don't - if they are warped, they need to be replaced - or if they are below minimum spec, which as I recall was 3mm.
UK-C200 is offline
#9 Old 05-02-2012
Mustang Sally's Avatar
Vehicle: 2010 SLK 350 Sports Pkg
Other Toys: OS Max 55 AX
Get the Akebono Euros. Amazon has them. You can easily eyeball the rotors to determine if they need replacement. Usually if you haven't worn the old pads down to the metal, the rotors will be OK.
Mustang Sally is offline
#10 Old 05-03-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
That's typically the minimum specs on pads, 2 or 3 mm. Rotors are much more, typically in the 25mm range. I can look it up if anyone really needs to know. Just going by my sedan, pads are 2mm all around, front rotors are 25.4, rear rotors are 8.3 - all in mm.
Len
Len
sokoloff is offline
#11 Old 05-03-2012
Vehicle: 2006 SLK 280 Black
Other Toys: None
Quoted: 101 Post(s)
If rotors are flat and greater than the service limit (for my R170, the spec says 23.5mm is the service limit), then fitting new pads does not require new rotors.
Of course, if the rotors are scored they should be resurfaced for the new pads, which might bring them under the service limit if they're close. For instance, my pads have 50% material left but at 123K miles, the rotors are at the service limit—the next time I put pads in, I'll change the rotors too.
Any service shop telling you differently is trying to make an extra buck, IMO.
Godfrey is offline
#12 Old 05-03-2012
Len
See post #3 with link above.
#13 Old 05-04-2012
Vehicle: 07SLK350
What I have noticed about the MB rotors installed on mine was like pre-matured grooves showing on the rotors like it was coming from the pads and this was as early as 2k.
QSHIP is offline
#14 Old 05-09-2012
MidLifeSolution's Avatar
Vehicle: 2004 SLK 320
Other Toys: 2011 Mercedes E350
Rotors don't wear unless serviced?
I thought rotors don't wear, just the pds wear? To my (limited) knowledge, the only way a rotor will reduce in thickness is if they are "turned" (aka "planed" or "shaved") to remove grooves. This is when you have to pay attention to the minimum thickness since turning the rotor removes surface.
Do I misunderstand?
MidLifeSolution is offline
#15 Old 05-09-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Yes, you misunderstand.
Pads rub against the rotors wearing both parts. Typically rotors will last two or more sets of pads, but the rotors do wear, faster with some pads. The general rule of thumb is that Mercedes rotors should never be turned because they typically don't ever need to be turned plus they hardly have enough "meat" on them to make turning worth it. I have owned Mercedes cars for 30 years and have never had to have a rotor turned. So there are specs for both pads and rotors. You can see the wear on the rotor by observing the little ridge that forms near the edge.
Len
Len
sokoloff is offline
#16 Old 05-09-2012
The Outer Limits
Thanks for clarifying! It all comes back to me - the outer ridge that forms is the clue!
#17 Old 05-18-2012
porscheguy944's Avatar
Vehicle: 2005 SLK55 AMG
Other Toys: LOTUS ESPRIT TWIN TURBO V-8
What are available for brake pads other than the factory pads?
I have a 2005 SLK55 AMG with out the optional w030 performance option.
I have called around today and found out the high dusting factory pads from MB are exspesive and make alot of black dust that sticks to everything.
I went on line and saw EBC yellow pads and bunch of other options out there.
BUT WHICH ONES TO BUY??????
WHO HAS HAD GOOD LUCK WITH ANY OTHER PAD??
Where did you get them and what part numbers? At what price point?
Were they any better worse or the same as factory pads??
porscheguy944 is offline
#18 Old 04-14-2016
Vehicle: 2001 SLK 230
Chats: 2
Quoted: 7 Post(s)
What are the Specs for Rotors?
Len
I'd like to know the spec for rotors for my 2001 R170 449. I saw you mentioned the rotor specs in a communication (quoted) that there are rotor specs but I can't find them anywhere in my book and online. (Pelican Parts didn't know and told me to ask in the SLK Forum.)
Please tell me what they are and where to look for information like this. Thank you!
CushyCouple is offline
#19 Old 04-14-2016
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Here are the specs for my 2003. I would think yours ought to be the same.
Front rotors - 22.4 mm
Rear rotors - 7.3 mm
Pads - 2 mm for all
Brake sensor will typically trip about 3 mm.
Len
sokoloff is offline
#20 Old 04-14-2016
Gordosoar's Avatar
Vehicle: 2001 SLK 320
Other Toys: 1100 Yamaha customized.
Quoted: 107 Post(s)
Originally Posted by Aranofly View Post
Hello,
Is this true?
If I shop tells you that you need new rotors after 17,000 miles they are trying to sell you something you don't need. This is typical of almost every shop I know of. As long as they are not warped, and you will know this if you feel the car braking unevenly as you come to a slow stop, you most likely don't need rotors.
And if you did the car would tell you so anyway.
For pads,, go with the red or green from EBC.
Just my 2 cents.
lovemyslk likes this.
Gordosoar is offline
Tags
breaks, pads, rotors
Replace ROTORS and PADS 05 SLK mrdougie SLK R171 Class DIY 27 01-11-2015 10:49 AM
SLK 350 replacement Brake pads & rotors SuzaFan Performance MODS for the R171 12 04-14-2014 06:20 PM
Wagner pads and rotors for 98SLK230 garricks Tires, Wheels, Brakes & Suspension 1 05-21-2011 08:40 AM
SLK 230, break pads... HBK SLK R170 General Discussion 4 11-07-2008 04:44 PM
Break Pads not changed in Service C GregoryGR SLK R171 General Discussion 6 11-29-2007 08:23 PM
