Brake Squeak - Mercedes Benz SLK Forum
  • 1 Post By FreddyC
  • 1 Post By jbanks15
#1 Old 09-18-2015
Vehicle: 2005 SLK 350 with proper Manual Tranny
Quoted: 12 Post(s)
Brake Squeak
A couple months ago my brother and I change the front rotors and all the pads on my 'O5 SLK. Instead of the OEM Mercedes pads, we put on ceramic pads. Now I have a horrible brake squeak when I first apply the brakes. After hitting them once or twice it goes away. Not sure if it is due to the ceramic brakes or not putting enough copper grease on the backs. Either way, I'm going to have to get in there and redo. Any thoughts?
FreddyC is offline
#2 Old 09-18-2015
Quoted: 6580 Post(s)
https://www.slkworld.com/tires-wheels...s-smoking.html
#3 Old 09-18-2015
Quoted: 12 Post(s)
They are not smoking Jeff, just squeaking. And only when I first apply the brakes.
FreddyC is offline
#4 Old 09-18-2015
I know. my thread link was that the poster's brakes eventually 'settled' in and were then fine
u_2504 likes this.
#5 Old 09-18-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
There are as many ideas as people posing them on brake squeel. Despite these, squeel is high frequency vibration. The problem is finding it and isolating it.
If the squeel is momentary and only when first applying the brakes, then the vibration is quickly taken care of with full pressure of the caliper pistons. Your copper grease - did you apply it only to the piston contact area? If so, try smearing some in the grooves where the pad backing plate sits in the calipers.
Hal Adams is offline
#6 Old 09-19-2015
Vehicle: 2005 SLK 55 AMG
Quoted: 257 Post(s)
Hi All
Yes put some copper grease along the edges top & bottom on the brake pad as this area rubs on the inner face of the caliper
Andy
ZeroZero is offline
#7 Old 09-26-2015
vinnypt's Avatar
Vehicle: 2006 Mercedes SLK 200 Kompressor
Other Toys: Audi A6 V6 2.5L 203 BHp
Quoted: 46 Post(s)
Send a message via Skype™ to vinnypt
Hi FreddyC,
Your anwser is here: (ATE Catalog)
http://www.ate-brakes.com/www/ate_de...en.html?page=2
Technical Information
Technically it is possible to combine ATE Ceramic brake pads with the PowerDisc or with perforated brake discs. The braking power with such a pairing is the same as with an original ATE brake pad or OE brake pad. However, when the two components interact they can generate more noise in braking. ATE Ceramic brake pads were developed for comfort-oriented drivers. We therefore recommend using them with normal brake discs, i.e. smooth ones.
vinnypt is offline
R172 Rear Brake Pad Replacement WhiteRabbit SLK R172 Class DIY 33 02-13-2019 09:48 AM
Removing & Replacing the Brake Light Switch on the R170 Series sckothmann SLK R170 class DIY 12 01-06-2019 02:23 PM
New Front Brakes 2000 SLK230 SLK R170 class DIY 20 12-28-2014 01:46 PM
High Pitched Squeak Brake Sound sky SLK R171 General Discussion 16 10-30-2008 07:05 PM
