wheel bearing - Mercedes Benz SLK Forum
  • 1 Post By Galo
#1 Old 03-31-2012
Vehicle: 1999 slk230 kompressor 170
Other Toys: BMW R1200c motorcycle, ML350 mercedes benz
Quoted: 9 Post(s)
Send a message via Skype™ to rogermursick
wheel bearing
does anyone know how tight the hub nut should be tightened after replacing front wheel bearings (inner and outer bearings were replaced). I hand tightened my hub nut and then locked down the allen screw. I am getting a rubbing noise now, like the bearing is not quite locked down tight enough.
I don't want to over tighten it.
thanks,
roger
rogermursick is offline
#2 Old 03-31-2012
Vehicle: 2005 AMG SLK 55 - currently for sale
Other Toys: 2011 Mustang, Ford F-150 lightning, Hilux 2.8 V6, CRV, Aprilia RSV Millie
Quoted: 17 Post(s)
Hi, I read there should be a small amount of play when it is correct. I guess the proper way is the dial gauge but I ended up doing it by feel. I think I went slightly too tight but its been ok.
Marct is offline
The Following User Says Thank You to Marct For This Useful Post:
#3 Old 03-31-2012
Quoted: 9 Post(s)
Marct, to begin with; I had an odd noise coming from the right front wheel when breaking (especially after the wheel heated up in traffic etc.) this went on for some time (2 years) MB didn't know what it was, I couldn't figure it out, so I changed the rotors and pads on March 27 2012 and the noise persisted. I changed the inner and outer bearings and drove around the block but had a noise still (whirring,rubbing) re-tightened the hub bolt and allen screw and the noise went away for a day. last night it was back slightly. so i believe the problem lies with the proper torquing of the nut etc.
Hellllp!
thanks
Roger
#4 Old 04-01-2012
Chats: 2
Quoted: 13 Post(s)
Roger, as near as I can tell from the SSM, torque is not the measurement, play in the hub/disk is. You need to use a dial indicator to measure play in the disk/hub and tighten the nut accordingly. You really need to get the Star Service Manual(look here for info; https://www.slkworld.com/diy-section/...y-awesome.html ) if you're going to do this type of work on your car.
rogermursick likes this.
Think outside the box!
Galo is offline
#5 Old 04-01-2012
Quoted: 9 Post(s)
Galo...thanks for the star address. Much appreciated!
#6 Old 04-01-2012
Chats: 2
Quoted: 13 Post(s)
My pleasure Roger. It really is a good "manual" and well
worth the price. Some digging is required to get all the
info needed, but there is a lot of info to find!
Galo is offline
Rear Wheel Bearing Replacement halcyon0 SLK R170 General Discussion 3 01-22-2016 10:14 PM
Clunking, wheel bearing? jperfect SLK R170 General Discussion 2 08-19-2009 06:27 AM
