SLK 280 tire change out questions - Mercedes Benz SLK Forum
#1 Old 03-04-2012
lowinsure's Avatar
Vehicle: 2007 SLK 280
Other Toys: Chevy Avalanche, Acura MDX, Sky Supreme, Itasca Sunova
I have a 2007 SLK 280. Want to do something about tires and I think I want to go to a wider tire with a lower profile.
Front: from 205/55/19 to 225/50/16 .09% diameter difference
Rear: from 225/50/16 to 245/45/16 .69% diameter difference
From what I can figure it should not mess with the ASR system (I think) Anyway I can find out?
lowinsure is offline
#2 Old 03-04-2012
Check out your tire size selection on this site: http://www.miata.net/garage/tirecalc.html
#3 Old 03-04-2012
I like this one more: http://www.1010tires.com/tiresizecalculator.asp
#4 Old 03-05-2012
lowinsure's Avatar
Thanks for the links... I know the tire sizes are close. .09% and .69% difference between OEM and the lower and wider tire. I need to know if the change will cause any problems with the electronic balanced braking system in the car because they are not the same size.
#5 Old 03-05-2012
Based on gesstalt: probably not. Perhaps the engineers in the forum may chime in and give us a definitive answer.
#6 Old 03-07-2012
nakulan7's Avatar
Vehicle: 08 SLK 55 AMG
Other Toys: Lexus IS250
Chats: 2
Quoted: 33 Post(s)
Wont be a good look with 16 inch rims IMO. Also your ride wont be any better with side wall flex i would imagine.
Your profile is not changing much as you are just going wider and the fraction becomes smaller [sidewall/width of tyre]. 225/45/17 and 245/40/17 are standard fitments in UK for 17 inch rims in R171. Looks fine.
nakulan7 is offline
#7 Old 03-08-2012
lowinsure's Avatar
Thanks again! I made a choice today and ordered the Bridgestone Potenza RE-11's in the stock size. I am going to get the Bilstiens as soon as I find out what the difference in between the shaft length on the 6's and 8's. I would prefer the stiffer dampening of the 8's but want to make sure that the stock springs will "play nice". Either way I will be better off that with the OEM.
01 280 SLK bumper fit a 01 230 Slk? ziagroup SLK R170 General Discussion 4 07-25-2008 05:14 PM
2006 280 SLK vs 2007 350z? Paison SLK R171 General Discussion 39 07-06-2008 07:29 PM
Z4 vs 280 vs 350 vs SLK facelift z33 SLK R171 General Discussion 16 01-28-2008 03:41 PM
