Emergency question, about to buy alloys off ebay! - Mercedes Benz SLK Forum
  • 1 Post By Hal Adams
#1 Old 08-09-2015
Swagman's Avatar
Vehicle: 12' SLK55 AMG
Other Toys: 15' HYUNDAI SANTA FE
Quoted: 36 Post(s)
So my AMG has a wobble... attributed to a 'out of round' front wheel, and I found some nice replacement AMG wheels on Ebay taken off another SLK...
Mercades SLK 18" Rims And Tires R172 AMG | eBay
But I guess these AMG wheels are just the AMG kit wheels as the tyre sizes and ET are different... are these just AMG looking wheels for non AMG cars?
I'm just trying to decide if I should buy them and if they will fit or rub somewhere, this ET thing confuses me.. I need to find a cheap way of seeing if this wobble will be cured by a new set of alloys without spending £2000 on AMG ones.
So the standard fitment for my AMG is
Front Axle 8J x 18 ET 43 235/40/18
Rear Axle 9J x 18 ET 42 255/35/18
The wheels I'm looking at
Front Axle 7.5J x 18 ET 42 225/40/18
Rear Axle 8.5J x 18 ET 36 245/35/18
What damage will this do?
Swagman is offline
#2 Old 08-09-2015
Quoted: 548 Post(s)
My intuition would say none, but if you look at the official MB documentation Mercedes-Benz Deutschland - Reifen und Kompletträder - Rad- und Reifenkombinationen | Mercedes-Benz Pkw
MB explicitly says that they are not allowed 1) Nicht zulässig (Not allowed) as opposed to 2) Nur zulässig (Only allowed for). So if you want to be absolutely sure, then no, pass on them.
Sneaky Pete is online now
The Following User Says Thank You to Sneaky Pete For This Useful Post:
#3 Old 08-09-2015
Nickb7035's Avatar
Vehicle: SLK 250 CDi 2012 AMG Sport
Other Toys: Mercedes B200 Turbo
Quoted: 12 Post(s)
Hi Mark.
I'm with Sneaky Peak in that the wheels you are looking at should not cause any problems due to the slightly different ET, although the rears are quite a bit different. My main concern would be wheel width. You are looking at wheels that are half an inch thinner, so you will loose the corresponding amount of rubber to road contact!
I have always replaced stock with aftermarket that match size and width as well as offset (ET) and stud pattern (PCD) just to be safe.
No chance you can get a single wheel from somewhere?
2012 SLK 250CDI. Obsidian Black. AMG Sport.
Mods and additions so far...
Cup Holder. Aftermarket reversing sensors. Smart Top. Becker Map Pilot. Debadged. LED Star. Yellow Stitch Leather Seatbelt Pads. Yellow Stitch Leather Seatbelt Button Covers. Carbon Fibre and Alloy Door Pins.
3D Carbon Fibre covering rear window pillars.
Nickb7035 is offline
The Following User Says Thank You to Nickb7035 For This Useful Post:
#4 Old 08-09-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
ET = Offset. Simply explained here:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Those wheels are a good price - especially with £40 off if you buy all four. The tyres are a tiny bit puny compared to what you would normally run though. I am sure you could easily sell them on if you establish your problem is solved allowing you to then spend the cash on the real thing.
I too do not think any damage - there is quite a bit under the wheel arch to play with and you would only be widening by 7mm plus you will be gaining more space from having an 8.5J over the 9.
I think the MB sheet says 'nicht' because they have to be well within the theory of all this stuff. I had much the same with the 55 rear calipers I fitted to my car, and on talking to TRW on another matter, mentioned that the 55 calipers were way too beefy and I had to grind off 3mm from the bridge, they went a bit apoplectic and refused to talk to me any further!
Hal Adams is offline
The Following User Says Thank You to Hal Adams For This Useful Post:
#5 Old 08-09-2015
Swagman's Avatar
Quoted: 36 Post(s)
I'm looking round at all the Ebay sites germany / France etc, I could buy 1 wheel from MB @ £530+VAT but that seems excessive for a test....
I'll keep hunting...
Swagman is offline
#6 Old 08-10-2015
Quoted: 271 Post(s)
Swagman - I can confirm that you will be perfectly ok with those off ebay!
I am playing with brake pads at present, and during fitment of some this morning, I offered up my spare 8.5J ET 36 and there is oodles of room between the caliper (I have the same caliper as you) and spokes as per photo:
I had to take 3mm off the edge of my caliper to accommodate the deeper dish wheel I am using, but even without this reduction there is a good 12mm clearance.
Swagman likes this.
#7 Old 08-10-2015
ZeroZero's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 257 Post(s)
Hi All
Did you think about having the rims made round again , I had 3 out of 4 rims out of round & the company I used to refurb my rims (perfection group uk) did the lot ,stripped back to bare alloy ,diamond cut edge ,powder coated , I did notice the difference after refurb .
Andy
ZeroZero is offline
#8 Old 08-10-2015
Swagman's Avatar
Quoted: 36 Post(s)
Hi All
Andy
Well I had just had them refurbed, which is when all the trouble started..
They were fine, but a little kerbed etc, but the car ran smooth, they refurbed them, and ever since, I've not been able to get them balanced, despite several goes at different garages
So I'm thinking, instead of getting them all done again, if I can just find a cheap set that will work, I'll live with them...
Swagman is offline
#9 Old 08-10-2015
ZeroZero's Avatar
Quoted: 257 Post(s)
Hi All
@ Swagman well I have never heard of that before , That ok but buyer beware on Ebay , someone was just up in court for selling poor quality rims online .
Maybe give Perfection a ring & see if they could help .
Andy
ZeroZero is offline
Group Buy #2 - SLK R171 Sport Fenders by Xclusive Car Concepts Stinger General Modifications R171 111 05-09-2014 06:49 PM
12 SLK To Buy or Not Buy that is the ? kank New Members Introduce Yourself Here 8 08-27-2011 06:38 PM
multispoke alloys - buy or trade thomson_adam SLK Parts Wanted 21 03-18-2010 06:10 PM
