brake job - Mercedes Benz SLK Forum
#1 Old 01-24-2012
Vehicle: slk280
Other Toys: jeep wrangler
brake job
looking to do my first brakes on my slk280.....what is a list of everything that im going to need from good pads down to the fluid.....not very mechanical.my shop quoted my a little over 600.00
paulz is offline
#2 Old 01-24-2012
Vehicle: 2006 SLK55
Depends on what you plan on doing with the car. If you're just a "daily driver" then there's no reason to burn a ton of money. Go to Napa auto and get pads. Check your rotors by running your finger across them. If they're not smooth, you'll need to correct that. Some can be "turned" (machining the surface) but some can't and have to be replaced. Stock ones from Mercedes are expensive. You can get 'slotted/drilled' rotors fairly cheap off ebay. Before the nay sayers pop in, I've been using those on my vette which has seen the track a couple times.
Same goes for fluid. Dot 4 if you're going to autocross/track the car. Dot 3 if a daily driver.
You'll also need some Brake Clean (spray can). Keep everything CLEAN CLEAN CLEAN.
Have someone there that has done it before to watch over your first time. Remember, those things have to work the next time you drive!
Todd157k is offline
The Following 2 Users Say Thank You to Todd157k For This Useful Post:
#3 Old 01-24-2012
Quoted: 6496 Post(s)
paulz,
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last.
Thank you,
Founding Member/Moderator
#4 Old 01-24-2012
Welcome from New Hampshire
#5 Old 01-24-2012
Vehicle: slk280
Thumbs up
thanks for the quick reply
paulz is offline
#6 Old 01-24-2012
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Welcome Paul from NE England.
To re-iterate what Todd said, if you're not very mechanically minded, do not consider working on your brakes by yourself especially if you've never confidently undertaken anything like that before. Not only does your life depend upon them working correctly, other peoples lives do as well.
Woolly is offline
#7 Old 01-24-2012
Vehicle: 1999 Slk 230
Other Toys: 2000 BMW
Great advice by all here!! If you want to do it, go for it! Get all the advice, parts and tools. I always do my own brakes. Don't trust anyone on my life! You need good advice, tools, Jack and a pair of stands. Metric tools of course. As a minimum you also need, a small metric socket set, 3/8 drive, a breaker bar, and metric allen set. As Todd157K stated, also get one can of brake clean. How many miles/Kms on your car? Is this the first brake job? Ask for advice; a lot of us can help!
airjose is offline
#8 Old 01-24-2012
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by airjose View Post
Great advice by all here!! If you want to do it, go for it! Get all the advice, parts and tools. I always do my own brakes. Don't trust anyone on my life! You need good advice, tools, Jack and a pair of stands. Metric tools of course. As a minimum you also need, a small metric socket set, 3/8 drive, a breaker bar, and metric allen set. As Todd157K stated, also get one can of break clean. Ask for advice; a lot of us can help!
And, don't forget a torque wrench, a set of torx bits & sockets and a set of speed bleeders or easibleed system. A dual circuit, servo assisted abs system is a goodie for your first attempt.
Woolly is offline
#9 Old 01-24-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Check your owners manual. It likely calls for DOT4 or even DOT4+. I doubt very much if DOT3 is approved. You really need to look at some of the DIY posts about brake jobs. Some even have pictures. Is your low brake pad light on? Brakes generally don't need to be replaced until they reach mnimum specs. Even once your warning light comes on, you still have time, usually at least a thousand miles.
Len
1999 E300D 215,000 miles
sokoloff is offline
#10 Old 01-24-2012
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by sokoloff View Post
Check your owners manual. It likely calls for DOT4 or even DOT4+. I doubt very much if DOT3 is approved. . . .
You are correct, DOT4+ is specified for all R171s.
Woolly is offline
#11 Old 01-24-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
You might try autohausaz for parts...there are a number of good online parts warehouses these days.
Also, use search to find the link for the service CD's (anyone have it at their finger tips) as they will take you through it step by step and tell you what tools you DO need.
FUN 4 2
Der Flieger is offline
#12 Old 01-24-2012
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
I think that this is what you're referring to.
The STAR Service Manual Library
https://www.slkworld.com/diy-section/...y-awesome.html
REB_TN_06 is offline
The Following User Says Thank You to REB_TN_06 For This Useful Post:
#13 Old 01-24-2012
Quoted: 123 Post(s)
http://www.startekinfo.com/StarTek/o...stedDocId=8638
select the numerical access...then 2700-171
FUN 4 2
#14 Old 02-13-2012
Vehicle: 2005 SLK350 MT
Quoted: 19 Post(s)
Hey Der
You trust a service manual spelled with 3 sss's "STAR CLASSSIC SERVICE"
GDB
gdb069 is offline
#15 Old 02-26-2012
Mustang Sally's Avatar
Vehicle: 2010 SLK 350 Sports Pkg
Other Toys: OS Max 55 AX
The job is a piece of cake.
Go to Amazon and get a set of Akebonos, or I'll sell you a complete set for all four corners for $75!
After you remove the wheel(s), the only tools you'll need are a hammer and a punch or a nail to drive out the two front pins holding the pads in place. The back only has one pin. You may need a big screw driver to push back the piston to get the new pads in (remove the cover on the master cylinder).
If you haven't worn the pad down to the metal (your sensor should have alerted you), your disks should be OK. If not, you can get them off Amazon. Good place that Amazon!
Mustang Sally is offline
The Following User Says Thank You to Mustang Sally For This Useful Post:
#16 Old 08-18-2012
Autozone Duralast Gold Brake Pads
Hey guys,
I recently replaced my front pads and rotors. I used Duralast Gold pads from Autozone and they squealed terribly. After 200 miles the squealing would not let up so I replaced them with pads from Mercedes. Not a peep from the brakes now.
poinde is offline
#17 Old 08-18-2012
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
You might check NAPA Auto Parts for Akebono Euro Brand pads. They ceramic which are quite and smooth. They come in a kit with new sensor. Do a search on them many posts on them. They are 99% dust free or better.
Gbarringer100 is offline
DIY Brake job dsb SLK R171 Class DIY 39 01-17-2015 06:01 PM
Front brake pads job GusSLK SLK R170 General Discussion 14 08-30-2014 06:08 PM
SLK55 Brake Job near Irvine, CA sumdumfoo United States 0 04-29-2009 06:58 AM
