Brake Judder SLK55 - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By 55russamg
  • 1 Post By dbgrn
  • 1 Post By Seanhump
  • 1 Post By Hal Adams
#1 Old 07-08-2015
55russamg's Avatar
Quoted: 684 Post(s)
Cool Brake Judder SLK55
Hi all,
I have a slight Brake Judder when braking, it seems to be the Front Brakes.
Would Skimming the Discs help? There is a local Garage that can Skim the Discs on the car. The cost is around £50 - £80.http://www.skimmydiscs.co.uk/
Does anyone know the minimum thickness of the Disc?
Also what are the best Pads for normal driving?
Russ
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is offline
#2 Old 07-08-2015
55russamg's Avatar
Quoted: 684 Post(s)
Cool Thickness
Found this in a Post
Measured my Disks and they are very good for thickness at nearly New size.
Very little Lip, I am now wondering if they are new'ish and were never Trued Up?
Front brake disks
New: 32mm
Wear limit: 30mm
wear limit for maintenance service: 30.6mm
Rear brake disks
New: 26 mm
Wear limit: 24mm
Wear limit for maintenance service: 24.6mm
Mercedes Benz SLK Forum - View Profile: etyu
Cheers Russ
SmartTop
#3 Old 07-08-2015
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
Try warming them up and then a few very hard stops - 70 to 0 .....
Failing that, a skim won't hurt ...
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#4 Old 07-09-2015
55russamg's Avatar
Quoted: 684 Post(s)
Cheers Sean,
I have tried some heavy stops etc, trying to remove any glaze etc.
No real change. I have booked it in for Friday so will Post the results.
Cheers Russ
SmartTop
#5 Old 07-09-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
If you have it booked in, then yes, wait and see why.
From a textbook angle, judder is due to disc run-out, thickness variation on the disc or caliper piston[s] sticking. Gas build up will also do it, but if you have drilled and vented discs, then unlikely.
Interested to see result.
Hal Adams is offline
#6 Old 07-12-2015
55russamg's Avatar
Quoted: 684 Post(s)
Cool Skim
Not had them done yet as they need to remove the Calipers,
They could not get the whole machine in.
Going back on Monday 20th for an on-car Skim and MOT.
It was a nice day, so the Dog and I walk to a Pub down by the Canal
dbgrn likes this.
Cheers Russ
SmartTop
#7 Old 07-20-2015
55russamg's Avatar
Quoted: 684 Post(s)
Cool Skim
Car has been dropped off this morning for a MOT and Disk Skim
Cheers Russ
SmartTop
#8 Old 07-20-2015
55russamg's Avatar
Quoted: 684 Post(s)
Thumbs up Done
No Judder As smooth as a babies bum.....
Passed the MOT and the guy looked all over it as he is interested in the car and says it looks perfect and is as tight as new.
I should have purchased new Pads.....
Can anyone recommend Front Pads for normal road use please?
dbgrn likes this.
Cheers Russ
SmartTop
#9 Old 07-20-2015
dbgrn's Avatar
Quoted: 1035 Post(s)
Great news!
I'm still on whatever pads were fitted when I bought the car (probably OEM), but I'm sure I've read in several places that EBC red stuff pads are the way to go, especially if you want to reduce the amount of brake dust created:
• https://www.slkworld.com/tires-wheels...rake-pads.html
• https://www.slkworld.com/tires-wheels...-question.html
There are more threads out there too... search is your friend!
55russamg likes this.
- Dave
Mods:
wind deflector
• Post-FL wing mirrors
• CF-effect interior trim
• AMG LED puddle lights
• Piecha DRLs
dbgrn is offline
The Following User Says Thank You to dbgrn For This Useful Post:
#10 Old 07-20-2015
55russamg's Avatar
Quoted: 684 Post(s)
Cheers Dave,
I searched ont Tinternet and EBC Yellow are recommended although they say for Road and Race.
I will look for Red ones.
Cheers Russ
SmartTop
#11 Old 07-20-2015
Seanhump's Avatar
Quoted: 424 Post(s)
I've stuck with OEM pads .. they work for me, and the dust gets cleaned off when I wash the car!!
Sean
Mods so far...
Seanhump is offline
#12 Old 07-20-2015
Quoted: 271 Post(s)
Redstuff certainly for cleanliness, but they do require some effort at the pedal. Also you should match them at the back.
Yellowstuff is the one making its mark now - originally brought out for trackday, but getting a big following for daily drive use. I am using them and certainly a lot less effort than the Redstuff I am used to. Dust is ok - much less than OEM.
The Following User Says Thank You to Hal Adams For This Useful Post:
#13 Old 07-20-2015
55russamg's Avatar
Quoted: 684 Post(s)
Thank you,
I have been looking at Bedding in procedure and will try and do it correctly.
I have also contacted EBC for their recommendation.
If nothing comes of that I will put OEM on.
I can only assume that the Brakes where never Bedded in.
The Discs are 30.5mm thick even after the Skim.
I am away for a few days so the car will not be used so i have time to get some new Pads.
Cheers Russ
SmartTop
#14 Old 07-25-2015
55russamg's Avatar
Quoted: 684 Post(s)
Cool
This was the recommendation from EBC
EBC Brakes Yellowstuff Car Brake Pads 'Axle Set'
Cheers Russ
SmartTop
A 'Who's Who' in SLKWorld.com Woolly New Members Introduce Yourself Here 2 3 Days Ago 04:15 PM
R172 Rear Brake Pad Replacement WhiteRabbit SLK R172 Class DIY 33 02-13-2019 09:48 AM
Removing & Replacing the Brake Light Switch on the R170 Series sckothmann SLK R170 class DIY 12 01-06-2019 02:23 PM
R171 SLK55 vs Corvette C6 specifications jameslk55 AMGs 1 05-08-2014 05:34 PM
