SLK350 Suspension fitted, 2 Broken Springs. - Mercedes Benz SLK Forum
 13Likes
  • 1 Post By Grandpa Munster
  • 1 Post By DSSG
  • 1 Post By Delucas
  • 2 Post By i860
  • 3 Post By ps33fount
  • 1 Post By i860
  • 1 Post By Delucas
  • 1 Post By jet_fl
#1 Old 07-05-2015
Vehicle: Black 2005 SLK350
Other Toys: BMW K1300R Dynamic, Honda Fireblade
Quoted: 14 Post(s)
I had been planning on replacing my suspension due to age.
Over the last few months I had noticed a clanking/chinging noise from the near side when going over pot holes and man hole covers, so last weekend my Brother and I jacked up the n/s/f to see what the problem was.
"There's the problem" my brother says, and pulled out nearly an entire coil of broken spring, the part which locates at the bottom of the shock.
So this week I ordered the following,
2 X front springs, yellow-blue-blue colour code (Merc. dealer). Sport option.
2 X rear springs, white-grey-grey colour code (Merc. dealer).
2 X front shock top mounts, in case bearings were shot (Merc. dealer).
2 X Bilstein B6 front shocks (Bilstein direct).
2 X Bilstein B6 rear shocks (Bilstein direct).
The shocks were delivered within 2 days and the stuff from the Mercedes dealer were picked up yesterday. Whilst at the dealers I also bought 2 X gas struts for the boot lid, for the sake of about Ł22 + vat for the pair I thought I would try them, I now know they were definitely needed, so a cheap and simple fix.
Saturday afternoon we replaced the front suspension, or I should say, after getting stopped in our tracks we replaced the front suspension.
My spring compressors would not compress the springs enough, so a dash to Machine Mart and we bought this spring and strut compressor, https://www.machinemart.co.uk/shop/p...rut-compressor
Today we replaced the rear suspension, as we have not got the Mercedes type rear spring compressor we had to lower the lower control arm to clear the spring.
When we dropped the lower control arm on the o/s/r we found that spring was also broken.
My ramblings are just a reminder to perhaps have a check of certain components as I had no idea one of the rear springs was also broken.
I now intend to get the suspension checked over and have a full alignment carried out by a specialist. There also appears to be a height difference of 15mm from the near side to the off side. Possibly the suspension needs more time to settle?
ps33fount likes this.
Grandpa Munster is offline
The Following User Says Thank You to Grandpa Munster For This Useful Post:
#2 Old 07-05-2015
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
It's very rare to break a coil spring, and you broke two or three? You must have giant pot holes in England.
That's a very nice spring compressor for little money. It's the perfect unit for this job. BTW, if you have the Sports Pkg, 0.5" drop in the front, the correct shock is the B8. There isn't any difference in the rear regarding the shock & coil.
15mm is a bit over 0.5", and that's unacceptable. At most, the variance shouldn't exceed 0.25" I'm not sure if you are talking about the front or the back. Anyway, I suspect the coils aren't seated properly in the upper and lower spring seats, or one or both are missing.
When checking ride height, do it on a level floor and measure from the inner lip of the fender, using a yard stick, to the floor.
DSSG is offline
#3 Old 07-06-2015
Quoted: 1138 Post(s)
Very rare !!??
Its so common over here in uk land .
You see the coil spring broken sections at roundabouts at the kerb at traffic lights .
Its such a common thing .
Its like coming across headlight bulbs gone .
The roads here are absoultlely SH.T !!
Its common practise to swerve to avoid them .
So common to se cars fail mot because of them .
The state of british roads and seems to be getting worse .
Delucas is offline
#4 Old 07-06-2015
Quoted: 14 Post(s)
The height variance is across the front axles from near side to off side.
I know the B8 shocks are recommended but I did not want suspension that was too harsh, as said, the roads over here are in a shocking state.
After test driving the new suspension I'm more than happy with the results.
#5 Old 07-06-2015
DSSG's Avatar
Quoted: 198 Post(s)
This is a a common mistake when picking shocks. It is the spring not the shock that determines the quality of the ride. All the shock does is damp the oscillations of the spring.
When you lower the ride height, in this case 0,5", the height of the spring has to be shortened. To make up for the reduced movement in the spring, it is made stiffer so it won't allow the suspension to bottom out on a bad bump. Also there is a rubber "bump stop" contained within the coil to help prevent this too.
The result is a stiffer spring requires a higher rate shock, or in your case, the B8. Your ride would have actually been better with the B8 shock. In any case, most of the improvement you are feeling is due to the replacement of the coils.
As far as the difference in ride height, it is always a good idea to measure the height of the coils. Sometimes they are different. Also the coils have to fit into the spring seats a certain way along with the lower and upper spring seats. Again this is a common mistake not fitting the coils correctly.
I'll have to worn you that unless you have a G-Wagon, no car can handle pot holes at speed. You'll do serious damage to your suspension.
DSSG is offline
#6 Old 01-08-2018
Vehicle: 2008 RHD SLK 280 with Sport Pack, paddle shifters. 18inch Alloys.
Send a message via AIM to Angela Whurr
Hi, I am just about to remove / replace front shocks on my SLK280 R171 - Removing the Struts is fairly straightforward - I am considering buying the: https://www.machinemart.co.uk/p/strut-compressor/
Which I think is the same one you mention - will this be right for my SLK R171??
Many thanks in anticipation, And (New Member)
Angela Whurr is offline
#7 Old 01-08-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 988 Post(s)
Yes, my mechanic has one of those.
You will need those as well
1/2-Inch Drive Tx-Star Socket Bit
I manage to snap 3 while removing my struts.
Avel Du and ps33fount like this.
i860 is online now
#8 Old 01-08-2018
ps33fount's Avatar
Vehicle: 2005 SLK55 AMG
Other Toys: too many things to take care of and use properly
Quoted: 83 Post(s)
Breaking tools is so much FUN!
Seanhump, i860 and Avel Du like this.
ps33fount is offline
#9 Old 01-08-2018
i860's Avatar
Quoted: 988 Post(s)
Nooooooooooooooooooooooooooo
i860 is online now
#10 Old 01-08-2018
There is a knack of undoing them
Angela Whurr likes this.
Delucas is offline
#11 Old 01-08-2018
Quoted: 14 Post(s)
Sadly this is one of those tools that you will most likely only use once.
It is a shame you do not live closer to me. I would have fitted the springs for you.
#12 Old 01-08-2018
Quoted: 217 Post(s)
That is why you use an impact wrench. Throw a torx socket on the 1/2 impact and it comes right off. Normally you only have to use the inner torx when you are putting the new one on.
jet_fl is offline
A 'Who's Who' in SLKWorld.com Woolly New Members Introduce Yourself Here 2 2 Days Ago 04:15 PM
Softer Suspension on standard SLK350 - thoughts ? SpeedFerret SLK R171 General Discussion 14 04-12-2016 04:59 AM
slk350 suspension rear springs sports spec bikes & cars Tires, Wheels, Brakes & Suspension 1 02-18-2013 05:02 AM
FS: SLK350 Sport Suspension (springs only) jameslk55 Where to get R171 SLK Items 2 07-27-2007 10:07 AM
