Wheel Spacers- any experience? - Mercedes Benz SLK Forum
#1 Old 06-28-2015
Vehicle: 2016 BMW M4 Convertible
Quoted: 40 Post(s)
Never had them on a car before and I know it's not to everyone's taste on here but I can't help but think that the SLK would look a lot more agressive with a bit of wheel poking out of the arches some more.
The kits seem to be about Ł90-130 per axle depending upon the size of the spacers.
Anyone used them before? Pros & cons? And most importantly what sort of size do you guys think my car could take without any rubbing etc.
Even if you think it'll look crap opinions would be great!
Sorry for the massive pic dump but I thought I'd post as many angles as possible to give a point of reference as my SLK is a bit lower than most
Maurauth is offline
#2 Old 06-28-2015
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
I have 5mm on the front and 10mm on the rear , but mainly they're there because the ET of my wheels is not the exact ones for the car , the wheels come out nicely just to the edge and the stance looks great in my opinion .
I've had them on there for at least a couple of years without problems ..
curro101 is offline
#3 Old 06-28-2015
Quoted: 40 Post(s)
Last few pics of the current stance.
Maurauth is offline
#4 Old 06-28-2015
Quoted: 40 Post(s)
Is your suspension stock? Do you have any rubbing on full lock or on bad roads / speed bumps / potholes etc when the suspension bottoms out?
Do you think you could go to 10mm front / 15mm back or maybe even 15mm / 20mm without any issues?
I'm thinking 15mm / 20mm but not sure if it would be possible with my setup?
Are your wheels any wider than the stock ones meaning they stick out more than just 5mm / 10mm spacers would on stock wheels?
Maurauth is offline
#5 Old 06-28-2015
curro101's Avatar
Quoted: 528 Post(s)
My car's 2nd hand and I think the previous owner changed the suspension to some point as it's stiffer than other Slks I've tried , but not especially lowered and no bottoming out ...
I have aftermarket wheels with width 8J and ET37 , if I remember rightly , and I put the 5mm spacers on the front because the centre cap hit the hub cover , the 10mm rears I put on to line up the rears with the fronts . I could probably put a bit more on both , but I wouldn't want to over stress/stretch the original distances for fear of causing damage .
With the amount you've lowered your car , I wouldn't over do it , for fear of rubbing on the wing/fender over bumps/holes ...
Might I suggest you get a pair ( rather than spending out on all four ) of 10mm ones and try and see what they look like and do front and back , then you can get something smaller for the front if and use these on the rear , if 10mm is too much , or something bigger for the rear if it's ok , if you understand what I mean ?
curro101 is offline
#6 Old 06-28-2015
Quoted: 40 Post(s)
That's a good shout, 10mm might be the best starting point then and if they're not quite big enough for my tastes I could run 10mm front / 20mm back until I can try 15mm front.
Although I'm struggling to find any spacers smaller than 12mm, might have to ring H&R and Eibach customer services and see what they've got.
Maurauth is offline
#7 Old 06-28-2015
curro101's Avatar
Quoted: 528 Post(s)
I got mine from eBayDe ...
curro101 is offline
Another wheel inquiry Mr.Antwerp Tires, Wheels, Brakes & Suspension 0 04-21-2014 10:15 PM
Wheel spacers - To use, or not to use.... dougrobling SLK R171 General Discussion 9 01-10-2014 06:42 AM
For Sale SLK Paddle Shift Leather Steering Wheel philh SLK Parts For Sale 5 12-30-2011 09:16 AM
Spacers? N4PWJ SLK R171 General Discussion 5 10-26-2006 01:30 PM
