HELP! Rear hub won't come out - Mercedes Benz SLK Forum
#1 Old 06-26-2015
kenji187's Avatar
Vehicle: 2001 SLK 320 6-speed Manual
Other Toys: Cars: SLK, Solara, Sienna, 328i Bikes: z1000, CBR1000RR, SR50, NSR250R, GSXR1000
Trying to do my rear bearing swap for the 1st time.
Pelican Technical Article - Mercedes SLK 230 - Rear Wheel Bearing Replacement
According to this page they used a bearing separator (or called bearing splitter) to pull the hub.
For some reason mine doesn't wanna move at all and instead it bent the tool (Harbor Freight large Bearing Splitter).
Also tried 3-leg puller, hub puller, harbor freight 3 lbs slide hammer, and a big ass 20 lbs slide hammer borrowed from a friend.
All of these have failed.
How did you guys do it? Did you have to remove half axle before you pull the hub? Mine are stuck on pretty good.
Any one of you managed to remove half axle bolts without stripping or breaking? I can't get them to move with my 450 lbs air impact wrench with long extension. Can't do it with hand tool the axle keep spinning.
Thanks.
kenji187 is offline
#2 Old 06-26-2015
kenji187's Avatar
kenji187 is offline
#3 Old 02-05-2016
Vehicle: 99 SLK230
Did you ever finish this job? What did you do? I am having the same problem -- can't get the hub off!
Katz is offline
Rear hub bearing change binn SLK R170 General Discussion 3 12-22-2013 11:25 AM
Is Missing the Rear Axle Hub Grease Cap Normal? WhiteRabbit SLK R172 General Discussion 1 10-12-2011 09:25 AM
Help replacing rear wheel hub! anthonyliZardi SLK R171 General Discussion 5 01-24-2010 01:23 AM
Rear hub nut and bearing work twowheelin SLK R170 General Discussion 2 08-20-2009 12:02 PM
