Front Rotors and Pads 2012 SLK 250 - Mercedes Benz SLK Forum
  • 1 Post By gregorywilliams100
#1 Old 06-16-2015
Vehicle: 2012 SLK 250 R172
I really have used the search feature and looked for several hours regarding my issue. I just bought my 2012 SLK 250 and it has the "sport" package, but appears to be the bodywork only and it still has the 1.8 liter turbo. However, it does have the 18 inch AMG rims. To the issue at hand.
I have not received a brake wear warning, but the front pads look pretty thin. The rotors look great except for there appears to be a slight edge around the perimeter of the rotor. With 36,000 miles, I would not think this is the second set of pads, and I don't think you "turn" these rotors. So, did the original pads wear the rotors this much? Also, do I need to replace the rotors every pad change, and if so, exactly what rotors and pads do I need. I looked at online sites and they list sport package and non-sport package. The original window sticker indicated this was a "sport package" but is it really? I will contact a retail seller of brake components, but would rally appreciate some thoughts if someone has actually completed this task.
I would love to find a repair manual or photos of the change of the pads and rotors. Any knowledge of wear to find either? Thanks for reading this long post.
gregorywilliams100 is offline
#2 Old 06-16-2015
Other Toys: Traded them all!!
Quoted: 124 Post(s)
Do you have a data card. I would think this would be a place to define what your car is by the VIN.
From there you can figure out what parts to order.
The rest should be straight forward.
Alex 3 is offline
#3 Old 07-02-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
If you have the sport package and AMG 18s, then you will have the larger type.
I agree, you HAVE to order by VIN to ensure the correct ones.
You do not necessarily need to change disc at each pad change - all depends on condition.
Pity you are so far away! I have just taken off a virtually new sport set in favour of an oversized 360mm set, that will probably sit under the bench gathering dust..!
Hal Adams is offline
#4 Old 07-02-2015
Quoted: 6576 Post(s)
He has his datacard.
#5 Old 07-02-2015
Front rotors n pads
#6 Old 07-03-2015
The data card is really useful. I do have the 18" AMG wheels, and my data card states AMG sport package US 951. However, I was slightly confused because I knew I did not have an AMG motor, just the appearance package, and was not sure when ordering brake components if they were referencing the AMG sports appearance package or an actual AMG performance. I went to Pelican Parts and they referenced the brake components as "950, 951, 952" so I guess that answers my question since my data card states "951." My rotors are not scored so should be fairly easy I hope. Thanks for the assistance and the schematic is truly appreciated.
#7 Old 01-26-2017
fasttr's Avatar
Vehicle: 2014 SLK 250
Other Toys: Bennington Pontoon Boat
Where did this VIN specific parts list come from? My build sheet indicates that I have "486 - Sport Suspension". I assume this is not the Sport Package that requires the larger pads but is it possible to get a part sheet for my specific car?
fasttr is offline
#8 Old 01-26-2017
LeonardoDaBenz's Avatar
Quoted: 1066 Post(s)
My thoughts as well. Maybe Jeff gets this stuff the same place he gets the data card itself?
LeonardoDaBenz is online now
SLK55 front brake pads and rotors replacement WoOZY Performance MODS for the R171 60 05-16-2018 03:00 PM
how to replace rotors and pads on front of my 2011 slk 300 [email protected] Tires, Wheels, Brakes & Suspension 6 04-26-2015 11:28 AM
Performance brakes, pads & rotors for your Mercedes SLK class carid CARiD.com 2 03-18-2015 08:17 AM
Replace ROTORS and PADS 05 SLK mrdougie SLK R171 Class DIY 27 01-11-2015 10:49 AM
SLK 350 replacement Brake pads & rotors SuzaFan Performance MODS for the R171 12 04-14-2014 06:20 PM
