pad wear sensor - Mercedes Benz SLK Forum
  • 1 Post By Mustang Sally
#1 Old 11-06-2011
D&LW's Avatar
Vehicle: 2009 SLK300
pad wear sensor
When replacing brake pads on an SLK300, it is a requirement to replace the pad wear sensors? I'm wondering if they get destroyed along with the pads and require replacement or can be reused.
D&LW is offline
#2 Old 11-06-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
If they are "activated" they need to be replaced - if not, you can re-use them. I seem to recall they are only $14 or so.
UK-C200 is offline
#3 Old 11-06-2011
D&LW's Avatar
I see, if they have been triggered by wear, then they're no good. Mine aren't so I guess I'll just reuse them. They are pretty cheap though. thanks.
D&LW is offline
#4 Old 03-29-2012
Vehicle: 2006 SLK280
I want to confirm. I have an R171. I am looking to replace the two front pads. As I understand it, there is one sensor for the front pads and one for the rear.
The sensor has not been triggered (I do not see anything on my dash). Do I need to replace the sensor? My guess is No
lastchild01 is offline
#5 Old 03-29-2012
Quoted: 6497 Post(s)
lastchild,
#6 Old 03-29-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Do they work by grounding out on the disk? Just curious.
FUN 4 2
Der Flieger is offline
#7 Old 03-29-2012
North American models may only have one (at the right front) and none in the rear.
#8 Old 04-08-2012
D&LW's Avatar
I finally got around to replacing brake pads on the SLK Friday. I expected to find sensors on all four pads but was surprised to find only one installed - front left pad.
D&LW is offline
#9 Old 04-08-2012
there is only one front and one rear on my 350. I made the comment that its very cheap skate of MB for the sake of a few pounds. When mine gave me a brake warning the one without a sensor was dangerously close to the disc. Maybe as mentioned that American models only have one ?
JonB is offline
#10 Old 04-08-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Brake checks are part of every A and B service and those are supposed to be done every 10 - 12,000 miles. That's why it's so important that those services be done and done correctly. Whether you DIY or have it done professionally, they need to be done. In that case you probably don't need any wear sensors.
Len
Len
1999 E300D 215,000 miles
sokoloff is offline
#11 Old 04-08-2012
Len
I still reckon my 68 Camaro had the best brake sensors ever
JonB is offline
#12 Old 04-08-2012
Mustang Sally's Avatar
Vehicle: 2010 SLK 350 Sports Pkg
Other Toys: OS Max 55 AX
Well my Akebono pads came with a new sensor, but I didn't replace it.
The sensor is just grounded when it touches metal. That's is getting close to the edge, but then you'll get maximum wear out of your pads!
I see the Akebonos are referred to as ceramic, but I can't find any indication of that in their literature. I think they are semi-metallic, but in any case, they work well. Unfortunately, they don't quite have the stopping power of the MB pads, but then I don't travel the Autobahn at 150!
JonB likes this.
Mustang Sally is offline
#13 Old 04-08-2012
"I don't travel the Autobahn at 150!"" MPH or KPH
JonB is offline
#14 Old 04-08-2012
D&LW's Avatar
Len
We've been through 3 A/B services and the pads were never an issue so I wasn't surprised at 30K miles that half of the pad was still left. I replaced them because of the dust and squeel.
D&LW is offline
sun sensor and light sensor are the same ?? s8636166 SLK R171 General Discussion 3 07-05-2015 06:04 PM
brake wear sensor Der Flieger SLK R171 General Discussion 9 05-26-2011 02:05 PM
check engine light on - oxygen sensors out? benz_bolek General Discussion 12 07-27-2010 10:19 AM
