Rear uneven tire wear - Mercedes Benz SLK Forum
#1 Old 06-06-2015
Addy64nl's Avatar
Vehicle: 2003 230kompressor
Other Toys: Capri26 sailboat
Quoted: 7 Post(s)
The outside of the tires look like there is another 10k miles life left in them. When I jacked the rear up to install new fuel pump I noticed tires are worn on inside. So much worn that the tire cord is showing. This is the same for both left and right rear tires.
What would be the cause for such an uneven tire wear? Can this be a DIY fix or a re-alignment when I have new tires installed?
Thanks, Ad
Addy64nl is offline
#2 Old 06-07-2015
Vehicle: 2010 SLK 300, AMG Sport Pkg
Quoted: 25 Post(s)
the camber on the rears are set so that you will get that uneven wear, on the R171
Have you tried a search on the subject?
bobl is offline
#3 Old 06-07-2015
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
Suggest you get new tires and have a wheel alignment done. There is a bolt package you might need to get to change the chamber of the rear tires to reduce the inside wear.
Gbarringer100 is offline
#4 Old 06-07-2015
Mensra's Avatar
Quoted: 397 Post(s)
I have a tire guy that I've known for years, he put my car up on the rack and told me that it's within spec. Mercedes set it up that way to improve its handling. My car eats rear tires, and so does most everybody else who drives their car "spirited"! The inner shoulder wear is far more rapid than the outer, the only thing I've seen to give me a slightly longer wear is to raise the pressure a bit.
Mensra is offline
Altitude and tire pressure Just1MoreDave Tires, Wheels, Brakes & Suspension 9 06-26-2015 11:32 PM
HELP on Rear Tire exchange jecjr Tires, Wheels, Brakes & Suspension 3 07-19-2014 04:41 PM
Rear Tyre wear wikingblue SLK R172 General Discussion 25 03-11-2013 12:17 AM
Letters and Numbers QSHIP Tires, Wheels, Brakes & Suspension 2 10-30-2010 05:04 AM
Wrong tire on Rear '55 rim nmslk SLK R171 General Discussion 26 03-21-2007 07:39 PM
