Caliper pin problems - Mercedes Benz SLK Forum
  • 1 Post By frogfoot
#1 Old 06-02-2015
Vehicle: 2009 SLK350
So I'm trying to swap out front pads and rotors and I'm have a hell of a time removing the pins holding the pads in place. Everything I've read said it's easy with a nail punch or screwdriver and a hammer. Mine however will not budge. I'm wondering if anyone else had this problem or if anyone has any solutions because I've run out of ideas.
Marf is offline
#2 Old 06-02-2015
Roy350's Avatar
Vehicle: SLK 350 2005
Quoted: 26 Post(s)
I had the same PIA issue, I broke two 3mm pin punches. I finally did it with a large heavy duty 10mm punch, I had to grind the end of the punch down to fit but the longer heavier punch allowed me to stand back and get a decent swing at the head of the punch. Before you try knocking the pins thro give them a clean and a smear of grease, this helps the pin slip thro the rear 'pin hole' more easily. When I refitted I deburred the pins and used some anti seize 'copperslip' on them...hopefully they'll be a bit easier next time.
Roy350 is offline
#3 Old 06-02-2015
Thanks! I broke a punch already too and I thought that was the last straw. Maybe I'll just have to hit harder. I tried to delicately use some pb blaster but the holes are just too deep for it to get to the "problem" area I feel like.
Marf is offline
#4 Old 06-02-2015
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 337 Post(s)
wd40 left overnight , they can be a rite pig to get out. I take mine out at least once a year and put them back in with a bit of copper slip on
ZeroZero likes this.
frogfoot is offline
#5 Old 06-02-2015
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
PB Blaster will get in there. Soak the area and give it some time. Some anti-seize when going back together.
DSSG is offline
#6 Old 06-04-2015
I tried wd40 and pb blaster the other day. I'm gonna give it another shot today. Thanks for the tips
Marf is offline
R171 : Install Aftermarket radio to replace Audio20 ghostdunks SLK R171 Class DIY 329 11-24-2018 10:39 AM
Rear Brake Caliper Piston Compression Tool WhiteRabbit SLK R172 General Discussion 26 07-13-2015 07:33 AM
slk350 05 front caliper pin kit frogfoot Where to get R171 SLK Items 0 07-06-2014 04:43 AM
U.S. auto industry quality slips for first time in 16 years: survey jbanks15 Off Topic 0 02-12-2014 11:32 AM
Caliper paint and caliper decal? Wallance Where to get R171 SLK Items 20 02-18-2010 10:21 PM
