Bilstein B6 Or B8 Shocks With Sports Suspension? - Mercedes Benz SLK Forum
#1 Old 04-30-2015
Vehicle: Black 2005 SLK350
Other Toys: BMW K1300R Dynamic, Honda Fireblade
Quoted: 14 Post(s)
Hi all.
I called Bilstein UK yesterday to enquire about the availability of B6 shocks to fit my SLK350.
I was asked if I had the sports suspension, which I have, option 486 on my data card.
I was then told I would be better off fitting the B8 shocks instead of the B6 shocks.
My criterior is I do not want the car lowered, I will be using the existing springs, so therefore which shocks do I order?
I want the car to remain at the same height, will the B8 shocks lower the car and will the B6 shocks raise the car?
Grandpa Munster is offline
#2 Old 04-30-2015
Beekster's Avatar
Quoted: 164 Post(s)
The shocks will neither raise nor lower the car, it's the height of the spring that does that. The ride height and rake can be dialed in to your liking by altering the spring pads, which are different thicknesses. The shocks are dimensioned and valved to work with particular spring heights and spring rates, so if the B8 is recommended then that is the one that has the characteristics which best match the Sport package springs. The B6 is probably softer and longer, for the standard springs. It may still be a stiffer shock than stock, but intended to work with the stock spring.
The spring pads are supposedly to be selected according to a points system that's detailed in the shop manual, which broadly speaking tends to use thicker pads for cars with more options and thus more weight. But they can be used to establish a higher ride height with sport springs. If the spring kit says that it lowers from 1" to 1.3", you can use thicker pads to push the drop towards the lesser drop rather than the greater one. It all depends on the look you want; thicker pads won't affect anything other than ride height.
Beekster is offline
#3 Old 05-01-2015
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
You should go with the Bilstein recommendation. The B8 is obviously valved to match the spring rate of the Sports Pkg springs. For a further check, you might check with your Mercedes dealer. Here, my MB dealer used Bilsteins to replace the OEM. Finally, you could check with this:
Home
DSSG is offline
#4 Old 05-01-2015
Serious's Avatar
Vehicle: 2005 SLK350 MT
Other Toys: 2014 Maserati GTS, 2004 Kawasaki 636, 2006 Kawasaki 636, 2001 Honda 929
Speaking from experience, the B8's on a 350 with sports package suspension did not work well. The shortened length of the piston did not match well with the spring rate on the sports suspension. The springs were too tall for the B8 shocks especially in the rear. Since the rear springs on a standard 350 are the same the sport package SLK 350, you’d be better off with the B6’s, if keeping the standard ride height is important.
Serious is offline
#5 Old 10-01-2018
LeftyS7's Avatar
Vehicle: 2010 SLK350, Moda MD20 rims, Deflectair, Clearbra, SmartTop, Piecha accel Mod, B6 shocks
Other Toys: '95 Suzuki Sidekick
Quoted: 67 Post(s)
Slightly off topic, I replaced the stock Bilsein B4s on my standard SLK350 with B6s to help the handling and it did not help. Just made the ride harsher. Would not do it over again. I'm wondering if Sports suspension anti-sway bars will help handling w/o further degrading the ride.
LeftyS7 is offline
#6 Old 11-29-2018
Vehicle: 2010 Silver SLK 350
Other Toys: BMW 135i and big fat grouchy black cat!
Quoted: 108 Post(s)
You are exactly right! I found out from the horse's mouth, Bilstein, that the only difference between the B6 & B8 is the latter has a shorter stroke. Otherwise, they are identical, ie, physical dimensions, damping, etc.
This is a common mistake. For example, my BMW has the M-Sport Pkg option, and owners of this model rush to install the B8. Wrong! Bilstein recommends the B6. Bilstein will cross reference your stock part numbers to determine the B6 or B8. In most cases, it'll be the B6.
SilverSLK2010 is offline
#7 Old 11-29-2018
Quoted: 2283 Post(s)
SilverSLK2010's thread: https://www.slkworld.com/tires-wheel...597-b6-b8.html
Some tips and costing for this kind of work.
Avel Du is online now
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Time for a new suspension? conleyjb Performance MODS for the R170 19 06-03-2019 12:07 AM
Shocks replaced at 90k - Bilstein B6 HD - $1300 OTD slk350ncls63 SLK R171 General Discussion 7 04-22-2015 07:52 AM
Bilstein Shocks Which of Three???? gringott SLK R170 General Discussion 2 11-01-2013 06:12 AM
FS: R170 F & R Bilstein Shocks - Almost New twowheelin SLK Parts For Sale 0 11-01-2009 07:49 PM
Sports suspension (486) and lowering springs ?? kalani Performance MODS for the R171 13 11-20-2008 02:14 PM
