Rear wheel removal - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By REB_TN_06
  • 1 Post By curro101
  • 3 Post By DSSG
  • 1 Post By ponia003
  • 1 Post By Beppi
  • 1 Post By Beekster
#1 Old 04-17-2015
Beppi's Avatar
Vehicle: 2006 Mercedes-Benz 200slk
Other Toys: Boats
Quoted: 144 Post(s)
Send a message via AIM to Beppi
Rear wheel removal
Hi there, can anyone tell me why I can't get my rear wheel off. I removed the bolts and screwed in the peg to guide the wheel but the wheel will not move. I don't want to knock it too hard because I don't want the jack to shift and drop the car. Is there something I am omitting to remove the wheel? The rear tires are 225/50 R16 92V they are wider than the front ones.
Beppi is offline
#2 Old 04-17-2015
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
It's just stuck. Woolly has the best strategy. Put the lug bolts back on and lower the car. Loosen all five bolts on that wheel one turn or so. Drive the car back and forth a couple of times, braking sharply, and it will break the wheel loose. Then it will come off easily.
Best Wishes
Beppi likes this.
Gene
REB_TN_06 is offline
The Following User Says Thank You to REB_TN_06 For This Useful Post:
#3 Old 04-17-2015
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
No need to put the peg in as a guide to remove the wheel , it's more for putting it back on .
Sometimes if they haven't been removed in a while you'll need to knock the wheel in varios points either inside or outside to loosen it up .
If you can put some blocks under the car in case the jack fails and then try a few light kicks to the tyres in a few different spots .
Once i had to hit the wheel on the inside with a block of wood and hammer , they were that stuck on !
Beppi likes this.
curro101 is offline
#4 Old 04-17-2015
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
Dissimilar metals weld themselves together! I smear a bit of anti-seize on the hub before reassembly.
etyu, ponia003 and Beppi like this.
DSSG is offline
The Following User Says Thank You to DSSG For This Useful Post:
#5 Old 04-17-2015
ponia003's Avatar
Vehicle: 2006 SLK280, 2005 E500 (W211)
Other Toys: Horses
Quoted: 29 Post(s)
You can put a little anti-seize on the area where the wheel meets the hub to prevent corrosion and sticking. It will make it easier to remove next time. Just don't get any on the lugs or the threaded holes in the hub.
Beppi likes this.
Dan
2006 SLK280
Engine: 272.942 V6
Options: Iridium Silver Paint, Harmon Kardon Sound System, Heated Seats, Air Scarf, Vavona Wood Trim
Modifications: 18" AMG wheels, Brembo Sport Pack Front Rotors and Calipers, 290 mm Rear Rotors and Calipers, SmartTop, Akebono Ceramic Brake Pads, Mid-Size R171 Facelift Antenna, Clear Sidemarkers, Chrome Turn Signal Bulbs, Mercedes Star Valve Stem Caps, Custom Cabin Air Intake Screen, AMG Tinted Tail Lights and 3rd Brake Light, Xenon Low Beams, OEM Sport Air Cleaner with Custom Port Screens, LED License Plate Lights, LED Parking Lights, Lamin-X Fog Light Films
ponia003 is offline
The Following User Says Thank You to ponia003 For This Useful Post:
#6 Old 04-17-2015
Beppi's Avatar
Other Toys: Boats
Quoted: 144 Post(s)
Thanks guys
Thanks guys I'll try all what you have suggested, must get them to come off easterly, can you imagine if you get stuck with a flat tire and you can't get the wheel off.
I was about to bleed the brakes and I could not get the wheel off. I will try tomorrow to get the wheels off.
Beppi is offline
#7 Old 04-18-2015
Beppi's Avatar
Other Toys: Boats
Quoted: 144 Post(s)
Job done.
Hi guys, got the wheels off by using a rubber mallet. I hit the inside rim of the wheel and the wheel popped off and held on with the guide peg. The cause was the rim of the hub, which corroded onto the mag of the wheel. I presume this happens because water collects on the rim of the hub when the car is washed, hence the reason why the manual suggests to drive the the car after washing it so the brake pads and I presume the hub can dry out from the heat of the discs when the brakes are applied. I also sanded away the corrosion from the hubs and the mags and applied copper grease before refitting the wheels, careful no to get any grease in the holes where the bolts hold the wheel. I tightened the bolts to 110 newton, is that the correct torque?
curro101 likes this.
Beppi is offline
#8 Old 04-18-2015
Beekster's Avatar
Quoted: 164 Post(s)
Correct; 110 Newton-meters or 80 lb/ft for the lug bolts. You're good to go!
Beppi likes this.
Beekster is offline
The Following User Says Thank You to Beekster For This Useful Post:
#9 Old 04-19-2015
Beppi's Avatar
Other Toys: Boats
Quoted: 144 Post(s)
Calliper nipple
Anyone know if it is ok to put grease on the thread of a calliper nipple, will it turn loose.?
Also I bleed my brakes today and the nipples on the front wheels point up, is it ok to leave the brake fluid in the nipple due to them pointing up and just put the rubber cap on or does one have to stick something in the nipple to absorb the excess fluid before putting the rubber cap on? Will the fluid corrode the nipple if it is left in there with the cap on?
Beppi is offline
r170 Sport rear wheel never2late99 SLK Parts Wanted 1 08-19-2014 10:25 PM
Wheel nut cross threaded (Rear) HZ123 SLK R170 General Discussion 12 05-15-2013 03:23 AM
Rear wheel bearing bad at 25,000 miles bob58 SLK R171 General Discussion 5 05-10-2013 05:24 PM
Rear brake disc removal SLK55AMG Paul Nickless Tires, Wheels, Brakes & Suspension 0 05-01-2010 03:26 PM
