Aftermarket alloy question - Mercedes Benz SLK Forum
  • 1 Post By hugy
  • 1 Post By curro101
#1 Old 03-26-2015
Vehicle: 2006 SLK 55 AMG
Hi Guys,
I'm thinking about getting a set of these wheels in 18" and I need some advice on wheel width and offset for my 55.I would like a lower offset on front and rear than the stock 18" wheels.
These Cades wheels are 18x8 with ET 45 offset and 73 mm center bore(5x112) for the front and the rear's are 18x9 ET 40.
I have 225/40/18 and 255/35/18 tires on my AMG wheels at the moment,will these fit the Cades wheels?
http://www.cadeswheels.com/tora.html
Thanks.
Robbie Hare likes this.
hugy is offline
#2 Old 03-26-2015
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
You can check the offsets here , but the offsets you've quoted seem a bit much :
Mercedes-Benz Fitting Chart and Wheel Fitment Guide | Alloy Wheels Direct
The tyre sizes should be ok ..
You can check tyre/rim width here :
http://www.lvvta.org.nz/documents/in...lity_Guide.pdf
clown likes this.
curro101 is offline
#3 Old 03-28-2015
Lovely,thanks.
hugy is offline
#4 Old 03-28-2015
Col
Col's Avatar
Quoted: 739 Post(s)
Hugy, I always use the configurator on this website to compare wheel and tyre combinations. The set up will work on the car with the existing tyres but they may not look much different poke wise i.e. how far out they come.
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
- SmartTOP
- Chrome Bonnet Fins
- Front Camera (Kerb Cam)
- Dash Camera (Hard Wired)
- Gel Resin Number Plates
- Acrylic Wind Deflector
- Ambient Lighting
Col is offline
#5 Old 03-31-2015
Thanks Col.
hugy is offline
#6 Old 01-17-2016
I'm now thinking of these alloys in 19X8.5 and 19X9.5 OZ Racing Superturismo LM in Matt Graphite.
Just not sure about the offset.
I want the wheels to fill out the arches.
The offset options are ET 30 or ET 38 front.
Rear are ET30 or ET 35.
What do you guys think?
hugy is offline
#7 Old 01-17-2016
Col
Col's Avatar
Quoted: 739 Post(s)
I'd go 30 on the front and 35 rear
- SmartTOP
- Ambient Lighting
Col is offline
#8 Old 01-17-2016
Quoted: 549 Post(s)
I second that.
With 8.5J and ET30 the fronts go 6 mm more inwards and 20 mm more outwards than the original 7.5J and ET37.
With 9.5J and ET35 rears go 18 mm more inwards amd 8 mm more outwards than the original 8.5J and ET30.
Choosing ET30 for rears results in 13 mm more both in-and outwards compared to the original setup.
Don't know how much play you have but I think they will certainly fill out the arches. But I think that's about max you can do with work on the arches.
Sneaky Pete is online now
#9 Old 01-17-2016
Yeah,that's what I was thinking.
hugy is offline
#10 Old 01-17-2016
Originally Posted by Sneaky Pete View Post
I second that.
Thanks Pete,
That sounds good,my car has stock suspension so it should be fine.
hugy is offline
#11 Old 01-23-2016
Does anyone know what the lowest offset is for front and rear wheels for a 55?
hugy is offline
#12 Old 01-23-2016
Col
Col's Avatar
Quoted: 739 Post(s)
Depends on a couple of things, like wheel size and tyre size. My 8.5 wide fronts are 30 offset and I wouldn't want any lower than that. My 9.5 wide rears are 40 although originally I was trying to get 35. It looks like I could use a 10mm spacer on the rear to end up at et30 but I reckon any more would rub and look daft!
- SmartTOP
- Ambient Lighting
Col is offline
#13 Old 01-23-2016
curro101's Avatar
Quoted: 528 Post(s)
This might help you out...
curro101 is offline
#14 Old 01-23-2016
Lovely,thanks guys.
hugy is offline
Aftermarket Alarm, I think I MIGHT! onixxf SLK R170 General Discussion 10 07-01-2013 08:08 AM
Lowering question Oszy Performance MODS for the R171 4 10-31-2012 02:50 PM
Best aftermarket Head Unit??? Yepega SLK R171 General Discussion 9 08-20-2012 10:57 PM
Aftermarket Head Unit question J3NNxFTW SLK R170 class DIY 3 05-07-2012 07:27 AM
Question about HID RetroFits CedarZ4 General Discussion 1 03-27-2012 06:59 PM
