Tire Size for OEM Rims - Mercedes Benz SLK Forum
  • 1 Post By Gbarringer100
#1 Old 02-13-2015
Vehicle: 2011 SLK 350
Other Toys: GL550/ML55AMG/1949 Ford F1
On another thread I read that for rear tires, the max you can go on the OEM rims are: 255/35R18.
What about front rims? Whats the max that will fit on front OEM rims?
mdyod is offline
#2 Old 02-14-2015
Beekster's Avatar
Quoted: 164 Post(s)
More information please...what generation of SLK are you working with and what rim diameter and width? You mention a tire size for 18s, but is that what you actually have? For some models, 18s are standard and for others either an intended factory option or a +2 fitment that has been shown to fit properly.
Beekster is offline
#3 Old 02-14-2015
Quoted: 6490 Post(s)
That size is true as I have 255/35zr18xl 94y on my amg rears
#4 Old 02-14-2015
The vehicle in question is - 2011 SLK 350
here's the tires i have now....
Front: 225/40 ZA 18
Rear: 245/35R18
mdyod is offline
#5 Old 02-19-2015
Front: 225/40 ZA 18
Rear: 245/35R18
Anyone know the biggest ( tallest and widest ) tires that will fit on front rims?
mdyod is offline
#6 Old 02-20-2015
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
this might help you a little ..
Mercedes-Benz Fitting Chart and Wheel Fitment Guide | Alloy Wheels Direct
curro101 is offline
#7 Old 02-20-2015
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
The real questions is what rim width is necessary for the size of tire you intend to select?
Given a known rim width, there are quite a few tires that'll fit on it, but it is a mistake to assume all brands of a tire of a particular dimension will fit. The the inflated tire needs room to spread out on the rim to perform at its full potential, and the rim might not be wide enough. On the other hand, you may find a much fatter tire will fit on your stock rim.
Obviously, most petrol heads want the fattest, measured by section width, tire on the rear while a somewhat skinnier tire on the front. BTW, don't assume the tread width increases with section width. You have to check this number out too.
Tire Rack has your answer in the tire specification table which will tell you the range of rim widths a particular tire will fit on. But there is a correct way to select your tire:
1. First you should select your brand. Again TR will provide you with tons of data comparing the performance of various tires. For me, I simplify the process as just choose the top rated brand as determined by Consumer's Reports which always is Michelin!
2. Next starting with the stock tire size, I start examining different tires by section width. Unfortunately, it starts getting complicated due to the the overall diameter of the tire changing depending upon section height. An example:
Consider a 245/35/18 tire. The first number is section width, don't confuse this with tread width, and the second is section height. To find overall height or diameter do 2(245 X .35) + 457.2 = tire diameter in millimeters.
Now you have to compare the height of the rear tire to the height of the selected front tire. If you aren't careful, the nose of your car will be pointing uphill rather than down hill! Don't laugh, it happens all the time.
After a little effort, you'll be immensely happy!
DSSG is offline
#8 Old 02-20-2015
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
You need to watch the Circumference the difference can not be greater than 3%. If greater than 3% you can have problems with the cruse control not working.
Monk likes this.
Gbarringer100 is offline
Tire Basics for Dummies carid CARiD.com 0 09-05-2013 09:01 AM
Staggered vs same size 17in rims CO-SLK320 General Modifications R170 20 06-03-2013 01:05 PM
Max tire size for 18 inch rear tires on SLK55 AMG netmiami AMGs 9 06-07-2010 12:37 PM
Tire size for new Rims TIMETODOIT SLK R170 General Discussion 2 11-24-2008 05:08 AM
